Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-19-2009, 09:14   #1 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 35
Can't flash with cyclone box
i'm a new user to cyclone box, i've been trying to flash bb5 phones with it but without success. Pls help, here is log:
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 04F0011169497D56B969CFCA023E61ADB94F06C6
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_ROM_ID: 273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: D93826B23E9B093BE4DD7304FBAA6778996AE60B
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Failed to Write Certificate -> No file(s) assigned
Booting RAP...
CMT_PUBLIC_ID: 1740011493F17C56BA06ED08BD8D60D50248BDF9
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Restarting MCU...
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm436__05.61.mcusw (CMT)...
Booting RAP...
rm436__05.61.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0119FFFF, NOR
EraseArea[0,CMT]: 0x011A0000-0x0133FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 77.343s
Writing all blocks...
Writing CMT NOLO Certificate...
Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error
Processing Flash Image Failed -> Failed to write all blocks
Failed to Process all Image files -> Failed to process rm436__05.61.mcusw
Old 09-19-2009, 10:45   #2 (permalink)
.:houssam:.'s Avatar
Member: 1041022
Thanks Meter: 45
selec corrt files , mcu pmm , cnd in ur disk
Old 09-19-2009, 10:46   #3 (permalink)
Member: 1041022
Thanks Meter: 45
selec corrt files , mcu ppm , cnd in ur disk
Old 09-19-2009, 10:59   #4 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,174
2 Errors
Error 1) TX2 error.. Are You using the TX2 Adapter And the Correct Cable or Jig?
Error 2) Are you Using A Cable 8 pins? you Should Select as VPP phone Internal 5V if You are using an UFC cable connected Directly To The TX2 Adapter And jig 3 or 5 (Depending the size of the pinout)
lg bl20 can't flash with Octopus box software version 1.0.5.2!!!plz check! NO.7 Octopus LG/Octoplus LG 3 01-08-2010 13:49
I can't flash with this **** box anything!!! digitalgsm_cora Cyclonebox 1 12-19-2009 19:54
N 95 8gb white can't flash with cyclone mcclinic Cyclonebox 1 08-29-2009 11:41
7370 can't unlock and can't read simlock status with cyclone box !! wgmmmx Cyclonebox 10 05-21-2009 13:13
k750 can't flash with mt-box lhakkaoui MT-BOX 2 11-15-2006 13:12
Page generated in 0.24983 seconds with 8 queries
