02-24-2010, 01:33 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: inside nck Age: 41
Member: 91558 Status: Offline Thanks Meter: 66 | cant flash n81 8gb please need help cant flash the phone,now is dead after stop at erasing process now phone dead and cant flash Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM179_20.0.056_prd.C00 Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM179_20.0.056_prd.C00 (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1170010AC46700525B262791CFDC86F2F513EE20 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C CMT_BOOT_ROM_CRC: A8C1D671 CMT_SECURE_ROM_CRC: 3E691FF8 RM179_20.0.056_prd.C00, Type: Flash Image, Algo: BB5, XSR 1.5 RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC003000600121, Samsung, ONENAND FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 10 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND EraseArea[0,CMT]: 0x00B80000-0x05F7FFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.516s Writing all blocks... Writing CMT ADA Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process RM179_20.0.056_prd.C00 please need help |
02-24-2010, 02:01 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | TX2 line problem, are you using the TX2 adapter ? Check cable, check ( redo ) solders in TX2 adapter, clean contacts in phone PCB. do an " Check Flashing Bus " to see if TX2 is working properly. BR |
N81-8GB RM179 After Full Flash Cant On!!! - SOLVED | danielkoh | Cyclonebox | 4 | 08-01-2009 05:17 |
error while flashing n81 8gb | M-taheri | Cyclonebox | 3 | 07-13-2009 20:13 |
Flashing N81 8gb with Ipmart rj48 Cables.. Work Perfect!! | bestncheap | MT-BOX | 4 | 01-01-2008 10:13 |
can new suite flash N81 8gb?? | noktune_win | HWK | 0 | 11-03-2007 09:57 |
