Member: 962029
Sonork: OEM Lock : ON Thanks Meter: 4,127 | press write flash
insert usb w/o battery
insert battery Quote:
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
[Nokia USB Flashing Generic]: Port opened OK!
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_10.46_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00898982, Intel, Size: 64MBytes
Processing "rm761__11.56.mcusw_ebl_psi.fls"...
Sending Certificate...
Certificate Accepted
Erasing 0x40000000-0x4001FFFF...
Flashing at 0x40000000...
Flashed 131072 bytes OK
Erasing 0x40040000-0x4005FFFF...
Flashing at 0x40040000...
Erasing 0x40060000-0x4015FFFF...
Flashing at 0x40060000...
Flashed 1048576 bytes OK
Erasing 0x40280000-0x41A7FFFF...
Flashing at 0x40280000...
Flashed 25165824 bytes OK
Erasing 0x43E20000-0x43E5FFFF...
Processing rm761__11.56.ppm_ea2 (XGold2)...
Checking rm761__11.56.ppm_ea2...
Flash file sorted Okay.
1 file(s) embedded into image.
Processing "package_ea2.ppm_ebl_psi.fls"...
Erasing 0x41A80000-0x421BFFFF...
Flashing at 0x41A80000...
Flashed 5414300 bytes OK
Processing rm761__11.56.image_ea2_059P3Z2_001 (XGold2)...
Checking rm761__11.56.image_ea2_059P3Z2_001...
Processing "package_ea2_059P3Z2.image.fls"...
Erasing 0x421C0000-0x43E1FFFF...
Flashing at 0x421C0000...
Flashed 14942208 bytes OK
Erasing 0x43E60000-0x43F3FFFF...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
[Nokia USB Phonet]: Port opened OK!
Factory defaults OK
Reading info...
MCU Version V 11.56
MCU Date 26-03-12
Product RM-761 (Nokia RM-761)
Manufacturer (c) Nokia
IMEI 359348043722446
Mastercode 1260611340
IMEI Spare 3A95430834274204
IMEI SV 3395430834274204F7000000
PPM V 11.56, 26-03-12, RM-761, (c) Nokia , EA2
CNT Content: ea2_059P3Z2, V 11.56, 26-03-12, RM-761, (c) Nokia
PSN 0021DD0BI
Product Code 059J4K8
Module Code 0204895
Basic Product Code 059F7N6
PSD 0000000000000000
LPSN 0
HW 2000
RFIC Dummy RFIC version
LCD TPO
BT 19e2-47026
Asic 11
HW Signature 3CE8119A512B29D7
Simlock Server SIMLOCK SERVER
Simlock Key 0010100000000000
Simlock Profile 800000000003000B
Simlock Aux 000B0000
Simlock IMEI 00003593480437224400
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
