Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 01-24-2011, 20:30   #1 (permalink)
Member: 696662
Unhappy Can't write rpl to 5230 rm-593 [ Solved ]
Hi i have a problem with phone from title.
I flashed it with rm-588 trying change product code(now i know that was stupid) and it didn't work.
Then i flashed back to rm-593 but still didn't work so i did "downgrade fast repair"
Sending User Abort Signal...
CBUS Request Error -> User abort
Failed to read info -> Phone not detected
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103
CMT_EM_ASIC_ID:  00000296
CMT_EM_ASIC_ID:  00000B22
CMT_PUBLIC_ID:  15200005E5208E5277623334729F793B5E22C983
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.34.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 053CA748F933E7C497F9DD5EF7A999E9B90BA153
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Backing up simlock...
MCU Version V ICPR72_09w44.17
MCU Date 07-04-10
Product  RM-593 (Nokia 5230)
Manufacturer (c) Nokia
IMEI  12345610654321?
Simlock backup OK, saved to RM-593_12345610654321_2011-01-24_151317.SLBackup.PM
Backup simlock thread finished, continuing...
Applying downgrade patch...
Apply downgrade patch failed -> Failed to write patched PM 308
Failed to BB5 Downgrade Repair -> Failed to Patch PM 308
And phone is working but it has wrong imei and keeps restarting every 10 mins or so.
I don't have cert backup anymore so i had to buy rpl from imei-server.com but i can't write it...
Local mode set
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Simlock...
Handling as SL1/SL2 Simlock Data
Simlock NOT ACCEPTED !
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key NOT ACCEPTED !
Writing WMDRM PD Data...
WMDRM PD Data NOT ACCEPTED !
Processing FLASHBUS Part...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE Subsystem Not Found
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Failed to Write RPL File -> Phone not detected
Pls help
Old 01-25-2011, 07:27   #2 (permalink)
adytuuxx's Avatar
Member: 1223870
Sonork: ..............
RM -593 ,find the same product code as under battery,same version or highter flash file it was at the beghining,flash with that,if everithyng go well i think you will just need to do a unlock by rpl method and sx4 autorize for a good pm,..try flashing also with phoenix usb dead as last resort,avoid downgrade,,try same version or up.
i think your solution is to do in -reverse-whatever you done,first problem=wrong firmware
second=downgrade
Old 01-26-2011, 00:09   #3 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Sonork: 100.1624864
rm-593 is SL3 phone man and we can not write pm even with sx4 because is "write protected" and so on unlock by rpl???
Old 01-26-2011, 03:48   #4 (permalink)
Member: 696662
So how can i repair this phone?
Old 01-26-2011, 08:21   #5 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Just start from zero which means
erase the phone (you can use the 5800xm erase file)
full flash it with the last version of firmware realted to its own product code (the one on the lable under the battery)
Write in the phone the nokia rpl
sx4 and suggested pm
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
Old 01-28-2011, 09:37   #6 (permalink)
Member: 696662
Thumbs down
Call me stupid but i can't erase my mobile.
Please help me supporters.
Here's my log:
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.50, (Dec 24 2010 18:30:25, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00035EA
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40
Initializing security card...
Card Serial Number: DA0001EA
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4,97v PASSED
MCU Voltage 3,29v PASSED
Core Voltage 1,80v PASSED
VBAT Voltage 1,55v PASSED
VBAT Voltage 5,01v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: FALSE
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing 5800_Erase_256MB_kashi4gul (CMT)...
Processing 5800_Erase_256MB_kashi4gul (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Date 07-04-10
IMEI Spare 1A32541660452301
IMEI SV  1332541660452311F6000000
PSN  MIK771591
Product Code 0592823
Module Code 0204379
Basic Product Code 0585852
PSD  0000000000000000
LPSN  0
APE SW  V 12.2.082
APE Variant V 12.2.082V 12.2.082 12.2.082.343.02
APE Test  rm593_ENO_x_09wk43v0.050
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
DSP  simon_ICPR72_09wk43
Failed to read info -> Failed to read SP info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Scanning avaiable products...
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\...
Found 2 products, Filtering BB5 Products - wait...
2 Products left after filtering. Ready.
Retrieving Variants for Product RM-593 (Nokia 5230) - wait...
1 Variants Retrieved
Processing RM-593_12.2.082_prd.core.C00 (CMT)...
Booting CMT...
CMT Ready!
RM-593_12.2.082_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5
Flashbus Write baud set to 650Kbits
RAPIDOv11_XSR17_alg.fg, Type: Algorithm, Rev: 512.10.34.1, Algo: XSR 1.6
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.889s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 104.614s
Flashing Speed: 7168,61 kBit/S
Restarting MCU...
Processing RM-593_12.2.082_prd.core.C00 (APE)...
Processing RM-593_12.2.082_prd.rofs2.V17 (CMT)...
Booting CMT...
CMT Ready!
RM-593_12.2.082_prd.rofs2.V17, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x06D60000-0x08D5FFFF, ONENAND
Erase taken 0.188s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 30.46s
Flashing Speed: 6446,80 kBit/S
Restarting MCU...
Processing RM-593_12.2.082_prd.rofs2.V17 (APE)...
Processing RM-593_12.2.082.343.02.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-593_12.2.082.343.02.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x08D60000-0x09E5FFFF, ONENAND
Erase taken 0.109s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 8.627s
Flashing Speed: 6619,85 kBit/S
Restarting MCU...
Processing RM-593_12.2.082.343.02.rofs3.fpsx (APE)...
Processing RM593_12.2.082_001_U343.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM593_12.2.082_001_U343.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F47FFFF, ONENAND
Erase taken 0.484s
TurboCache Loaded!
All blocks written OK! Time taken 17.894s
Flashing Speed: 6646,12 kBit/S
Restarting MCU...
Processing RM593_12.2.082_001_U343.uda.fpsx (APE)...
Factory defaults OK
Reading info...
MCU Date 07-04-10
PSN  MIK771591
Module Code 0204379
LPSN  0
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
Failed to Write RPL File -> No RPL File Provided by User
Handling as Universalbox Backup
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Old 01-28-2011, 10:20   #7 (permalink)
torpedo_seluler's Avatar
Member: 368629
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
MCU Date 07-04-10
Local mode set
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Pls help
If you Flashing using cyclone box,, it will be automatical backup the RPL..
unless you untick the backup rpl and simlock section..
try to Search by Windows Search and type in like this
*imei number*.rpl
Old 01-28-2011, 10:27   #8 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Looks like something is wrong on the npc certificate.
Make read all certs off the mobile
click afterward on erase all certs
then click on write certs and restore all apart the npc and see if the mobile get again the local mode.
Alex
Note: please, report
Old 01-28-2011, 19:40   #9 (permalink)
Member: 696662
Alex
Yes mobile gets local mode but it keps restarting.
Here's log:
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Ok
CMT HWC Ok
CMT CCC Ok
CMT R&D Ok
CMT VARIANT Not Found
CMT PAPUBKEYS Ok
CMT KEYS Ok
Restarting MCU...
Read all certificates finished
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT HWC Erased
CMT CCC Erased
CMT R&D Erased
CMT VARIANT Not erased
CMT PAPUBKEYS Erased
CMT KEYS Erased
Restarting MCU...
Erase all certificates finished
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Processing 15200005E5208E5277623334729F793B5E22C983_2011-01-28_142740.CCC.CMT.crt...
CMT CCC Erased
CMT CCC Written
Write CMT CCC Certificate finished
Restarting MCU...
All files processed OK!
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Processing 15200005E5208E5277623334729F793B5E22C983_2011-01-28_142740.HWC.CMT.crt...
CMT HWC Erased
CMT HWC Written
Write CMT HWC Certificate finished
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Processing 15200005E5208E5277623334729F793B5E22C983_2011-01-28_142740.KEYS.CMT.crt...
CMT KEYS Erased
CMT KEYS Written
Write CMT KEYS Certificate finished
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Processing 15200005E5208E5277623334729F793B5E22C983_2011-01-28_142740.PAPUBKEYS.CMT.crt...
CMT PAPUBKEYS Written
Write CMT PAPUBKEYS Certificate finished
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Processing 15200005E5208E5277623334729F793B5E22C983_2011-01-28_142740.R&D.CMT.crt...
CMT R&D Erased
CMT R&D Written
Write CMT R&D Certificate finished
Restarting MCU...
Failed to Write   Certificate -> No file(s) assigned
Old 01-29-2011, 20:30   #10 (permalink)
Member: 696662
Can i repair this phone with cyclone?
Old 01-30-2011, 06:47   #11 (permalink)
Member: 696662
Alex
Finally atfer many tries i have repaired my phone.
@moulnisky thanks for all your help!
Here's complete log:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.10618
Initializing box...
2009, wk40
Card is activated
Box is activated
USB Voltage 5,07v PASSED
MCU Voltage 3,27v PASSED
Core Voltage 1,79v PASSED
VBAT Voltage 1,49v PASSED
Box VPP disabled
VPP Voltage 0,00v PASSED
VPP Voltage 4,97v PASSED
Box VPP disabled
VPP Voltage 0,02v PASSED
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Processing 5800_Erase_256MB_kashi4gul.bin (CMT)...
Processing 5800_Erase_256MB_kashi4gul.bin (APE)...
Factory defaults OK
Reading info...
MCU Date 07-04-10
PSN  MIK771591
Module Code 0204379
LPSN  0
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT HWC Erased
CMT CCC Erased
CMT R&D Erased
CMT KEYS Erased
Restarting MCU...
Processing RM-593_20.2.098_prd.core.C00 (CMT)...
Booting CMT...
CMT Ready!
RM-593_20.2.098_prd.core.C00, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
Erase taken 0.873s
TurboCache Loaded!
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
All blocks written OK! Time taken 104.521s
Flashing Speed: 7194,66 kBit/S
Restarting MCU...
Processing RM-593_20.2.098_prd.core.C00 (APE)...
Processing RM-593_20.2.098_prd.rofs2.V17 (CMT)...
Booting CMT...
CMT Ready!
RM-593_20.2.098_prd.rofs2.V17, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erase taken 0.188s
TurboCache Loaded!
All blocks written OK! Time taken 27.550s
Flashing Speed: 7029,38 kBit/S
Restarting MCU...
Processing RM-593_20.2.098_prd.rofs2.V17 (APE)...
Processing RM-593_20.2.098.343.01.prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-593_20.2.098.343.01.prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erase taken 0.94s
TurboCache Loaded!
All blocks written OK! Time taken 9.860s
Flashing Speed: 6951,12 kBit/S
Restarting MCU...
Processing RM-593_20.2.098.343.01.prd.rofs3.fpsx (APE)...
Processing RM593_20.2.098_001_U343.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM593_20.2.098_001_U343.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Erase taken 0.468s
TurboCache Loaded!
All blocks written OK! Time taken 18.65s
Flashing Speed: 6583,21 kBit/S
Restarting MCU...
Processing RM593_20.2.098_001_U343.uda.fpsx (APE)...
Factory defaults OK
Reading info...
MCU Version V ICPR72_10w04.11
MCU Date 04-10-10
IMEI SV  1332541660452321F6000000
PSN  MIK771591
Module Code 0204379
LPSN  0
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
DSP  simon_ICPR72_10w05
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT HWC Erased
CMT CCC Erased
CMT R&D Erased
CMT KEYS Erased
Restarting MCU...
Started Phone Security Analysis...
Analyze Security Error -> Phone not detected (FBUS)
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT HWC Erased
CMT CCC Erased
CMT R&D Erased
CMT KEYS Erased
Restarting MCU...
Failed to set SW Reset Mode -> Mode not accepted
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT R&D Erased
CMT R&D Written
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT KEYS Erased
CMT KEYS Written
Restarting MCU...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
Restarting MCU...
Write RPL Finished!
Test mode set
MCU Date 04-10-10
CNT  20.2.098_001_U343
PSN  MIK771591
Module Code 0204379
LPSN  0
APE SW  V 20.2.098
APE Variant V 20.2.098V 20.2.098 20.2.098.343.01
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
[308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19
Write PM Finished, Record written OK: 0, Record written NOT OK: 1
MCU Date 04-10-10
Reading Security Block...
29_233737.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
Prepare phone failed with message -> Not found required CMT Secondary Loader
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
Analyze Security Error -> Failed to obtain Phone Unique Data
Working on PM...
Backup!
MCU Date 04-10-10
PSN  MIK771591
Module Code 0204379
LPSN  0
APE SW  V 20.2.098
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
Failed to Write RPL File -> RPL -> TXT Converter not found! Reinstall software!
Booting CMT...
CMT Ready!
Searching for BootCode: Single Line 8Bit
Failed to Check BB5 Flashing Bus  -> Failed to Boot / Prepare Phone
Booting CMT...
CMT Ready!
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Booting CMT...
CMT Ready!
CBUS Request Error -> CBUS Response wrong header
Prepare phone failed with message -> Failed to get CMT Configuration
Booting CMT...
CMT Ready!
Booting CMT...
CMT Ready!
Booting CMT...
CMT Ready!
Security Card Reset Error -> Possible error: OK
Failed to Write RPL File -> Security card was not found!
Booting UPP...
Failed to Erase All Chips -> UPP Not Responding
Booting CMT...
CMT Ready!
Failed to Erase All Certificates -> Failed to Boot / Prepare Phone
Security Card Reset Error -> Possible error: Unknown error 0xC0
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
Failed to Write RPL File -> Failed to Boot / Prepare Phone
MCU Date 04-10-10
PSN  MIK771591
Module Code 0204379
LPSN  0
APE SW  V 20.2.098
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
Booting CMT...
CMT Ready!
Erasing Security...
Booting CMT...
CMT Ready!
Erasing Security...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
Restarting MCU...
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Writing Simlock...
Writing CMLA key...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
Restarting MCU...
Write RPL Finished!
MCU Date 04-10-10
IMEI  359341033955852
Mastercode 13576045
IMEI Spare 3A95430133598505
IMEI SV  3395430133598525F6000000
PSN  MIK771591
Module Code 0204379
LPSN  0
APE SW  V 20.2.098
APE HW  256
APE ADSP 256
RETU  16
TAHVO  22
AHNE  11
HW  0531
RFIC  17141716
Simlock Server SIMLOCK SERVER
Simlock Key 3102000000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310160
Simlock [2,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310200
Simlock [3,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310210
Simlock [4,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310220
Simlock [5,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310230
Simlock [6,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310240
Simlock [7,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310250
Simlock [8,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310260
Simlock [9,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310270
Simlock [10,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310310
Simlock [11,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310580
Simlock [12,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310660
Simlock [13,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310800
Simlock [14,1] State: CLOSED Type: 7FFF6F07FFFFFFFF @ FC00 Data: 310490
Initializing box...
2009, wk40
Card is activated
Box is activated
USB Voltage 4,94v PASSED
MCU Voltage 3,28v PASSED
VBAT Voltage 1,52v PASSED
VBAT Voltage 5,00v PASSED
Box VPP disabled
Box VPP disabled
Box VPP disabled
SX4 Authorization / SD Repair Procedure Started....
read it...
Booting CMT...
CMT Ready!
Failed to obtain Phone Unique Data, Will use Server and Original Card
MCU Date 04-10-10
Mastercode 13576045
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Cyclone Server (1.0.0.653), Cyclone Box Team 2008-2011 - Ready. Merry XMas!
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
"Write PM" Button
Disconnected from Cyclone Server
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 98 bytes, Status: OK
[1,18] Written, Length: 98 bytes, Status: OK
[1,20] Written, Length: 98 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 98 bytes, Status: OK
[1,29] Written, Length: 10 bytes, Status: OK
[1,31] Written, Length: 98 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,37] Written, Length: 4 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[1,45] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 32, Record written NOT OK: 0
Normal mode set
MCU Date 04-10-10
Mastercode 13576045
PSN  MIK771591
Module Code 0204379
LPSN  0
APE SW  V 20.2.098
APE HW  256
APE ADSP 256
APE BT  HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
RETU  16
TAHVO  22
AHNE  11
20.2.098.343.01r20.2.098_001_U343uk rm593_ENO_x_09wk43v0.050
RFIC  17141716
20.2.098.343.01r20.2.098_001_U343k rm593_ENO_x_09wk43v0.050
Simlock Key Cnt 0
Simlock FBUS Cnt 0
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.62821 seconds with 11 queries
