06-06-2013, 15:58 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Pls help need this product code:059C1F7 C5-00 rm-645 after flash dead only vibrate after flash with cyclone now phone dead only vibrate here is the logs Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 25C000179C9C0344F796E32580AEFB2321B23856 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! rm645_071.005_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.14.0, Algo: BB5 Using NEW BB5 FLASHING PROTOCOL Waiting for USB Boot ROM Answer... ROM Ret: 0xFFFD125D ROM CMT dwAddr: 0x10004FF0 ROM CMT dwLength: 0x00627837 Seems ROM Initialized OK! Transmission Mode Requested: Control USB, Accepted: Control USB FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0020004000000031, ST, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.14.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Transmission Mode Requested: Bulk USB, Accepted: Bulk USB Box TX2 Data Pin set to: Service Pin 3 Waiting for FUR Client become avaiable... [Nokia USB Flashing Generic]: Port opened OK! FUR Avaiable! Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Overriding VPP Setting, USB can't use VPP Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND EraseArea[0,CMT]: 0x008E0000-0x0AE3FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 0.781s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 25.594s Flashing Speed: 31674.84 kBit/S Processing rm645_071.005_prd.core.fpsx (APE)... Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part (CMT)... rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x06D40000-0x0A03FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.265s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 8.625s Flashing Speed: 35448.99 kBit/S Processing rm645_071.005_11.01_MEA_C_prd.rofs2.fpsx.part (APE)... Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)... rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0A040000-0x0AE3FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 0.157s Flashing Speed: 417.78 kBit/S Processing rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx (APE)... Processing rm645_071.005_U000.000_prd.uda.fpsx (CMT)... rm645_071.005_U000.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 PAPUBKEYS Hash for CMT: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x0AE40000-0x0F63FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.359s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 0.750s Flashing Speed: 14815.55 kBit/S Processing rm645_071.005_U000.000_prd.uda.fpsx (APE)... Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Phone not detected at USB -> Timeout, no any compatible USB device detected. |
06-07-2013, 09:26 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | backup all certs erase npc full backup pm full erase flash again restore certs restore pm repair sd and let cyclone to write pm |
The Following User Says Thank You to Mr.3. For This Useful Post: |
06-07-2013, 09:30 | #4 (permalink) |
Junior Member Join Date: Aug 2009 Location: kolkata
Member: 1105644 Status: Offline Sonork: [email protected] Thanks Meter: 0 | while in factory set mood ,remove the usb cable and insert within a second ..see what happens |
06-07-2013, 10:00 | #5 (permalink) |
Crazy Poster Join Date: Jul 2010 Location: nigeria
Member: 1351426 Status: Offline Thanks Meter: 8 | pls dnt downgrade i have d solution flash with rm645_071.005_prd.core.fpsx rm645_071.005_12.01_MEA_I_prd.rofs2.fpsx rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx rm645_071.005_U000.000_prd.uda.fpsx RM645_ENO_10wk48v0.001.fpsx just download this files and enjoy 1000000000000000 sure |
