01-03-2010, 13:42 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1166619 Status: Offline Thanks Meter: 0 | Cyclone adaptor not work [ Solved, PC problem ] Sorry for my bath english Last edited by ptt; 01-03-2010 at 20:50. Reason: solved |
01-03-2010, 14:09 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Check / redo the solders of the adaptor. If you want use 10 Pin MT cables you need an adaptor. Read the sticky post "CycloneBox = JAF/UFS = MT-BOX Cable Pinouts Compared " http://forum.gsmhosting.com/vbb/showthread.php?t=750962 BR |
01-03-2010, 14:49 | #3 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | pin 2 = wite pin 3 = blue pin 4= yelo pin 5= orange pin 6= green pin 7= black pin 8= brown pin 9= red pin 10 empty This is the solders on the print of the adaptor. There somewhere is a diagram of the cyclone adaptor? |
01-03-2010, 15:09 | #5 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | I several cables such as the combo FBUS have tried cable 10pin & 8pin. 10pin connect on the cyclone without adapter not at all works. The box is new !! Last edited by motech; 01-03-2010 at 15:18. |
01-03-2010, 15:46 | #7 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | The solderings of the adapter is correct. It must in the box sit because 10 a pin does not work directly on the box also. Only with 8 a pin he something does but gives much error' s |
01-03-2010, 16:00 | #9 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | Okeeee Yes it is a cable with a 10 pin's with label TO MT and a 8 pin's with label TO JAF. Is this cable work with the cyclone adaptor? or another adapor. The cable is MT+JAF065 NK n95-8gb |
01-03-2010, 16:07 | #10 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | JAF / UFS cables works with Cyclone For BB5, use Cable + TX2 adapter ( with your combo cable, you must use the TO JAF conector ) For DCT-4 / DCT-4+ conect cable directly to the Service port BR |
The Following User Says Thank You to ptt For This Useful Post: |
01-03-2010, 16:19 | #11 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | Oke thanks i have connect te TO JAF connector into the tx-2 en the message when i get is PHONE WAS NOT DETECTED AT FBUS INTERFACE............ Read info is also not work. I set the setting to pin1 3 of 10 but is not work And the message CBUS RESPONSE WRONG HEADER Last edited by motech; 01-03-2010 at 16:28. |
01-03-2010, 20:40 | #12 (permalink) |
Member: 1166619 Status: Offline Thanks Meter: 0 | Thanks t5he box connected on a new pc with al the drivers and it work !! Thanks for your help. I have a new problem with unlocken dtv4 plus nokia 7100 supernova MCU Version V 05.41 MCU Date 26-11-08 Product RM-438 Manufacturer (c) Nokia IMEI 356791028479339 Mastercode 524414434 Selecting unlock method... Using Super DCT4 Activation Search in: C:\Program Files\Cyclone Box2\UnlockData\ Searching for: RM-438_V 05.41.sunlock_img Writing patch file... Booting UPP... Box VPP disabled Processing Flash Image Failed -> UPP Not Responding Failed to Unlock DCT4 -> Failed to write patch file Last edited by ptt; 01-03-2010 at 20:51. Reason: initial problem solved, user open new thread about DCT-4 + unlock |
New cyclone hardware not working, registration problem [ Solved ] | ARBSM | Cyclonebox | 1 | 02-09-2010 19:05 |
Cyclone Website not working | Sydney_Unlocker | Cyclonebox | 1 | 10-21-2009 23:44 |
Urgent my cyclone box not working | pablete | Cyclonebox | 3 | 05-21-2009 11:12 |
activation lg i pay and not work!!! // solved , and working !! enjoy | juceca21 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 11 | 12-27-2008 23:01 |
Ub bb5 adaptor not working and y cable not avail pakistan | ayaz ali | Universalbox | 1 | 10-12-2008 13:04 |
