cyclone always says box is not in need mode cyclone always Initialization has failed -> No connection was established, or box is not in needed mode ive done the procedures,, uninstall reinstall after that it will work,, the window will say in " main mode" then i unplug my box after a few minutes i plug it again den the window will say in bootloader mode,, again it won't connect,,, how is that,, where is the problem is it in the box,, and one thing do i have to always plug the ac adaptor everytime i use the cyclone already did this procedure but still not working http://forum.gsmhosting.com/vbb/showthread.php?t=797559 |
Reinstall drivers or the whole app , uninstall , go to the folder location and delete any leftovers o cyclone , run instaler again and drivers will install correctly , the problem will be solved Hitec |
already did that it works only after the installation,, when it detect the drivers but when you unplug the box and wait for 5 minute then plug it again it the window will say in bootloader mode,, and it will not connect again |
bro chek link cyclone always says box is not in need mode http://forum.gsmhosting.com/vbb/showthread.php?t=797559 |
Try using a different USB cable or using another USB port BR Alex |
Start team viewer (if you don't have it you can download from HERE ) and PM me your ID and password, so we can have a look at the problem together. BR Alex |
