03-19-2015, 11:40 | #3 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | u need to read phone first via cyclone, if u have any firmware already installed on your PC, then cyclone should pick up the phone model for flash, if u have few diff versions, then just pick the one u want to flash.. Thats all Ps.if u have installed firmware but cyclone didnt picked any, then check the Paths in cyclone tab |
03-21-2015, 16:34 | #5 (permalink) |
Member: 1670851 Status: Offline Thanks Meter: 267 | if its not detected,then select dct4 tab, and choose manually mcsw and other files for flash,then flash the phone had similar issue with 6230 and flashed by manually selecting files |
03-22-2015, 17:17 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: romania
Member: 736359 Status: Offline Sonork: simi Thanks Meter: 23 | i do that with different versions of firmware and now phone start but when must enter the network phone auto shut down. here is problem Converting CNT... Checking image... Unpacking image... Image Unpacked OK, Base Address = 0x1B80000, Chunk Size = 0x4000, Convertion 64kB -> 128kB Unformatting Image... Writing 0 blocks... All blocks written OK! Time taken 0.32s |
03-22-2015, 23:31 | #8 (permalink) |
Member: 1670851 Status: Offline Thanks Meter: 267 | u doing something wrong download and unpack from here: http://mtronicscell.********.ie/2010...ash-files.html once unpacked, u will see 3files in folder: mcusw,image and ppm manually select all 3 and flash the phone.. it should work fine after flash |
