03-30-2010, 22:23 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1012895 Status: Offline Thanks Meter: 37 | Cyclone best flasher FIRST I FLASH USE MX KEY N UFS HWK N THIS LOG Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm237__07.21.mcusw as MCU [BB5,BB5 ALGORITHM] size: 14.48 MB Supported RAP Ids: 0103192101001101, 010C192101001101 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 2960010CE9257E563E740D9D2425B74608DF8E17 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS is blank/erased. Storing certificate ...OK Total erase size: 16.37 MB CMT NOR area [00000000-000006BF] erased in 0.781 s CMT NOR area [000006C0-0001FFFF] erased in 0.172 s CMT NOR area [00020000-0007FFFF] erased in 0.875 s CMT NOR area [00080000-000DFFFF] erased in 0.187 s CMT NOR area [00100000-001FFFFF] erased in 0.344 s CMT NOR area [00200000-0031FFFF] erased in 0.360 s CMT NOR area [00320000-0105FFFF] erased in 3.140 s CMT NOR area [01060000-01067FFF] erased in 0.156 s CMT NOR area [01068000-0107FFFF] erased in 0.172 s Flash programming ... Error while programming [00] at 0xFFFFFFFF, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 21.172 s RX Buffer: F372 I TRY CYCLONE SUCCES Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0002DA7 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DA000157 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.90v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.98v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: FALSE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 292 products, Filtering BB5 Products - wait... 148 Products left after filtering. Ready. Retrieving Variants for Product RM-237 - wait... 283 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm237__07.21.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2960010CE9257E563E740D9D2425B74608DF8E17 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 1.656s Writing all blocks... Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Skipping CMT PAPUBKEYS Certificate (already sent)... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 52.797s Restarting MCU... Processing rm237__07.21.mcusw (APE)... Processing rm237__07.21.ppm_x (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2960010CE9257E563E740D9D2425B74608DF8E17 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.ppm_x, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01080000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 24.735s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 11.485s Restarting MCU... Processing rm237__07.21.ppm_x (APE)... Processing rm237__07.21.image_x (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 2960010CE9257E563E740D9D2425B74608DF8E17 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.image_x, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 82.656s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 14.516s Restarting MCU... Processing rm237__07.21.image_x (APE)... All images processed OK! Processing post flash tasks... Reading info... MCU Version V 07.21 MCU Date 05-11-08 Product RM-237 Manufacturer (c) Nokia. IMEI 359309021815214 Mastercode 722537477 IMEI Spare 3A95030912182501 IMEI SV 3395030912182521F5000000 PPM V 07.21, 05-11-08, RM-237, (c) Nokia. , X PSN MSB877472 Product Code 0514950 Module Code 0203291 Basic Product Code 0542523 PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 HW 5007 RFIC 17211721 DSP ICPR61_08w10 BT 06cc-P9.1 Simlock Server SIMLOCK SERVER VERSION 63 Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! CYCLONE CAN DO IT AFTER OTHER FLASHER CANNT DO IT... I HOPE CYCLONE CAN REPAIR SIMLOCK SL3 BEFORE MX KEY CAN DO IT... TQ Last edited by ptt; 03-30-2010 at 22:29. Reason: add code tag |
03-30-2010, 22:30 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi, Thanks for report. You are still using the old version of the software. please look in the sticky post about how to download and install the last updates. BR Alex |
??? Best Flasher & Unlocker For Old Series ??? | dannyogolo | Motorola Old Legacy (EMMI) | 16 | 06-29-2003 18:42 |
Best flasher for BE1 | jacck | Alcatel & TCL Old Models | 1 | 01-14-2003 10:22 |
Best flasher for 3410???????? | ab1009 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-08-2002 15:35 |
Best flasher for new DCT-3 ???????? | ab1009 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 10-25-2002 02:23 |
Looking for best flasher soft for full flashing nokia 3310 with simple lpt cable | reggid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-23-2002 18:41 |
