Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-28-2014, 01:53   #1 (permalink)
Member: 1727599
Sonork: alexericsson
Exclamation cyclone bootloader
I have no problem just says boot loader and try to give maintenance wizard box and also I get turned on and off when I try to open and fails that happened since I installed the Installer v1.22 driver are properly installed and tried it on 2 pcs and I hope your help thanks
Old 06-28-2014, 19:52   #2 (permalink)
mubarak2344's Avatar
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 568
hi alex, wats ur problem, pls tell in simple word clearly, we can help u
The Following User Says Thank You to mubarak2344 For This Useful Post:
Old 06-30-2014, 18:33   #3 (permalink)
Member: 1727599
mubarak and sorry but I only speak Spanish because ye used google translator sorry this is the facebook of cyclone where more users have the same problem with Spanish course
Digicell LA Cadena amigo teng una cyclone box q recienla compre, pero al momento se conecta y se desconecta el bootloader, necesito saber si me pueden ayudar,, muchas gracias
Diego Miranda Tengo el mismo problema, con la ultima actializacion no funciona mi box, queda en conectando y desconectando, a diferencia de lo que escribe digicell La Cadena a mi no me da ese log, no hace nada solo pone boot loader mode clasic
Humberto Correa tamvien me pasa lomismo si algien save como solusionarlo porfa
Old 06-30-2014, 21:05   #4 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 568
dear alex,............ use win 7 32-bit for perfect use
1. uninstall coolsand drivers- if u installed
2. install box driver from cyclone box folder....
3. insert cyclone box, now system will auto install ur device..
4. open cyclone .exe file and click box wizard, it take some mins(need internet connection for box wizard)
5. after successful activation,........
6. open nokia tool, now u can see box turned to main mode from bootloader mode.....
7. if u open cyclone.exe every time, it connects in bootloader mode only, but when u open nokia tool it will change to main mode....
alex, try this and post results.......
if u still have problem, pls post screenshots of ur problem... thank u
Old 06-30-2014, 22:02   #5 (permalink)
Member: 1727599
after latest update , say : failed to launch in main mode in box wizard i have windows seven 32 bits the driver are well and launch cyclone .exe in admin mode but no work
Old 07-01-2014, 01:54   #6 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 568
pls post screenshot of ur error br.........
Old 07-01-2014, 01:59   #7 (permalink)
Member: 2001848
Sonork: 100.1658212
Thanks Meter: 568
alex, did u update it from previous version or directly installed the updated version v1.22 ????????????????????
how do u did ??????
Old 10-30-2015, 23:35   #8 (permalink)
mg70brz's Avatar
Member: 18726
Thanks Meter: 26
cyclone bootloader error
Cyclone Box Service Tag: FA13E88D49125D02B8C12EE701A722FB
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00056A6
HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35
Initializing security card...
Security Card Reset Error -> Possible error: Security card is not responding for reset
Initialization has failed -> Security card was not found!
Page generated in 0.27107 seconds with 7 queries
