Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 03-24-2010, 03:04   #1 (permalink)
banalven1's Avatar
Member: 202941
cyclone box can't change to main mode [SOLVED - Thanks HRCO]
Already use more then 7 month,suddenly today my box can't change to main mode only detect as bootloader mode~~
i already try to reinstall the setup & driver so what is the problem ??
is it chip damage ??
Old 03-24-2010, 06:39   #2 (permalink)
dawah telecom's Avatar
Member: 868940
Bro......where is shot screen error ?????????
br
Old 03-24-2010, 09:40   #3 (permalink)
hrco's Avatar
Member: 15506
Change crystal 12MHz(12.000 is mark) both, and all will be ok!
The Following User Says Thank You to hrco For This Useful Post:
Old 03-24-2010, 10:00   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
post some logs before anything.. may be as well a firmware problem
Alex
Old 03-29-2010, 05:09   #5 (permalink)
banalven1's Avatar
Member: 202941
problem solved after change the crystal 12MHz,thk to hrco~~
now box work 100%~~
Old 03-29-2010, 09:34   #6 (permalink)
hrco's Avatar
Member: 15506
now box work 100%~~
I'm so glad that you fixed the box by my instructions.
My misfortune was that I bought a box and did not worked ok one day.
But with an oscilloscope and multimeter on my luck I fix the problem.
A lot of users think that will fix this bug with a firmware update.
They may even want but, if after the first firmware update no results, the only option is to open the box and try hardware option.
But many users think, it was a bad first update, so I ask the administrator please allow me one more update, pls,pls,pls etc....then begins confucion for him.
I think that the administrators and product supporter should announce that it is one of the biggest mistakes in this box.
But luckily can fix an average user.
Take care,
cyclone box do not change to normal mode smarpc Cyclonebox 6 01-22-2010 07:36
cyclone box can't flash 5630 rm-431 [SOLVED LONG TIME AGO] slim05 Cyclonebox 7 12-24-2009 14:17
I have problem with my cyclone box. Only bootloader mode - No main mode [SOLVED] ivanrlobato Cyclonebox 6 08-30-2009 21:16
nokia3230 can't change to LOCAL mode raymondhee HWK 2 08-10-2006 02:33
Page generated in 0.42849 seconds with 11 queries
