03-23-2009, 13:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | *** Cyclone Box - Download - Installation - First Steps *** 1. Download final installer from: http://www.**********/CycloneBoxInstaller.exe and Install it. While installing agree to install box drivers, etc. 2. Connect box to PC. PC should detect new device - "Cyclone Bootloader". Simply do automatic driver installation, till installer installed them in Win32 INF already. 3. Run Start -> Programs -> Cyclone Box -> Cyclone Box At bottom, you should see "Connected [Bootloader Mode]". That means your box was detected by software, and you can proceed with box registration - needed step to activate your box. 4. Run Box Registration Wizard, click Prepare Box. Select your reseller from list, and fill all needed data. If you see "Box registration status: Registered OK" that means all passed ok. You can proceed with box activation. 5. Run Box Maintenance Wizard, and click Maintenance box. In 1-2 minutes your box will be initialized. **** VERY IMPORTANT : During box upgrade, please DON'T disconnect your box, even if software may act as hang ! We use ciphering on few layers during upgrade, and if you have slower PC, decrypting RSA and other ciphers, may take quite more time !! And then, if you disconnect your box, it will not be upgraded. It is no problem, because it will not be damaged, but You will lose YOUR time and OURS time, asking for next update credit !! 6. Your box is registered and activated. Now your security card needs be initialized. To initialize security card, box needs be activated! Run Security Card Manager. Read your card, and click Fill Credits. Box should change its mode to Cyclone Box and Windows should install new drivers again (same steps as for Bootloader). On bottom of screen you should see "Connected [Main Mode]". 8. All is done. You can run DCT4/WD2/BB5 tool and check if necessary selftests will be passsed, so you can enjoy using your Cyclone Box One note: security card having 1000 credits at initialization. Each card operation tooks those credits, so after some time you need to reinitialize card (when counter reachs 0). This operation is of course free and realtime, using server. Code: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.9912 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.45, (Jul 6 2010 19:20:51, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Box Serial Number: C0000005 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D0000001 Card Firmware Revision: 0108 Card is activated Box is activated Started box selftests procedure USB Voltage 4,99v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,73v PASSED Box VPP disabled VPP Voltage 0,02v PASSED Internal Box VPP Enabled VPP Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Enjoy your box! Note : Mirror for installer and exe : Index of /downloads Last edited by karwos; 01-12-2012 at 22:01. |
The Following 238 Users Say Thank You to karwos For This Useful Post: |
03-24-2009, 04:05 | #2 (permalink) | |
No Life Poster Join Date: Jun 2008 Location: Wish i was on Mars Age: 40
Member: 789089 Status: Offline Sonork: 100.1617*** Thanks Meter: 267 | Quote:
well said honey...they expect the product developer to predict their own future.. | |
03-24-2009, 06:58 | #4 (permalink) |
selective member algo bruteforce SL3 Join Date: Dec 2007 Location: IRELAND
Member: 665113 Status: Offline Sonork: 100.1583029 Thanks Meter: 1,165 | I think support have missed my question (or maybe there is nothing to say - no advantages...?) I will just repeat myself once again. Please give us some good reasons why we should buy it? Most of us have plenty tools for nokia phones nowadays... I have 5 different tools that does all my needs for now... so whats so special with CycloneBox ? (P.S. - Im one of the customers who is interested in your new product, so make a good comparison between your tool and others, advantages and disadvantages please...) BR (PLEASE REPLY WITH AN ANSWER - NOT WITH AN EXCUSE AS U ARE TOO BUSY) |
03-24-2009, 19:53 | #5 (permalink) | |
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
Nothing is missing. THe ppls which using this device should post their feedback about advantages or disadvantages, that is all. | |
03-24-2009, 22:06 | #6 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Cali Colombia Age: 43
Member: 181405 Status: Offline Thanks Meter: 249 | manual instalation cliclone box by OROBAS Quote:
LINK Manual in Spanish full http://www.4shared.com/file/94775835...spaol__2_.html | |
The Following 8 Users Say Thank You to hector bermudez For This Useful Post: |
03-27-2009, 10:31 | #9 (permalink) |
No Life Poster Join Date: Apr 2008 Location: GSM Philippines Age: 38
Member: 748785 Status: Offline Sonork: KIKO_GSM Thanks Meter: 309 | info good work team........... Description : Cyclone Box is a brand new tool for flashing and servicing of the latest Nokia BB5, DCT-L, DCT4, DCT4+ cell phones. Features * USB BUS powered only, current in idle is 55mA * World's first flexible configurations via software. It can be used TX2 pin on any RJ48 output i/o pin. * First in the world built-in 10 pin diagnostic service for measuring phone damages via: voltage, current, frequency, STI BUS * High speed flasher, real BUS speed up to 10-11Mbit, using 2 data lines * UFS/JAF compatible pinout * Switchable VPP - externally or internally generated signal, high speed flashing/erasing * Advanced self-testing system * Supports both FLASHBUS and USB connections for Nokia phones * Built-in secure smart-card * Cyclone Box uses it's own Smart Card and FTDI drivers so there are no conflicts with other devices * Free 100 ASK-RPL credits are included into Cyclone Box pack to perform RPL calculation for Nokia DCT4 and DCT4Plus. The user does not need to wait for ASK-RPL online calculation. Supported models and features DCT4 Features * Flash software (upgrade/downgrade) * Reset SP SIM locks * Lock phone to any network * IMEI repair for the latest models * Flash Bluetooth * Save user settings * Full factory (UI) defaults * Software upgrade defaults * Reset user lock (security code) Supported DCT4 models 1100, 1100, 1101, 1108, 1110, 1110, 1110i, 1112, 1112, 1112i, 1600, 1600, 2112, 2125i, 2126i, 2128i, 2255, 2300, 2300, 2355, 2600, 2600, 2650, 2651, 2652, 2760 Americas, 2760 Europe/Asia, 3100, 3105, 3108, 3120, 3120, 3125, 3128, 3129, 3152, 3155, 3155i, 3200, 3205, 3205i, 3220, 3220, 3230, 3300, 3300, 3320, 3321, 3360, 3361, 3510, 3510i, 3520, 3530, 3560, 3570, 3585, 3586, 3586i, 3587, 3587i, 3588i, 3589i, 3590, 3595, 3595i, 3600, 3620, 3650, 3660, 5070, 5070, 5100, 5140, 5140, 5140i, 6010, 6012, 6015, 6015i, 6016i, 6019i, 6020, 6020, 6021, 6030, 6030, 6050, 6060, 6060, 6061, 6070, 6070, 6080, 6080, 610, 6100, 6101, 6101, 6101, 6102, 6102, 6102, 6102, 6103, 6103, 6108, 6111, 6112, 6152, 6155, 6155i, 616, 6170, 6170, 6200, 6220, 6225, 6225i, 6230, 6230, 6230i, 6235, 6235i, 6236i, 6255, 6255i, 6256, 6256i, 6260, 6260, 6310, 6310i, 6340, 6340i, 6360, 6370, 6385, 6500, 6510, 6560, 6585, 6590, 6590i, 6600, 6610, 6610i, 6620, 6650, 6651, 6670, 6670, 6800, 6800, 6810, 6820, 6820, 6820i, 6822, 6822, 7200, 7210, 7250, 7250, 7260, 7270, 7270, 7280, 7280, 7360, 7380, 7600, 7610, 7610, 7620, 7650, 7700, 7710, 810, 8310, 8390, 8587, 8800, 8800 Sirocco Edition, 8801, 8910, 8910i, N-Gage, N-Gage QD Supported DCT4+ models 1200, 1208, 1208b, 1650, 1650b, 1680c-2b Classic, 2310, 2610, 2610b, 2626, 2630 Americas, 2630 Europe/Asia, 2670h All ASIC11 models supported Nokia DCT-L Features * Flash software (upgrade/downgrade) * Unlock * Set FAID * IMEI repair * Set UI defaults Supported DCT-L models 9290, 9210, 9210i (communicator) Nokia BB5 Features: * Flash software (upgrade/downgrade) * USB high speed flash supported * Easy RPL service for damaged phones * SIM lock and IMEI rebuild to the factory state * Save user settings * Set product code after flashing * Full factory (UI) defaults * Software upgrade defaults * Reset/read user lock (security code) Supported Nokia BB5 models: 3109 Classic, 3110 Classic, 3120 Classic, 3250, 3500 Classic, 3600 Slide, 3610 Fold, 5200 XpressMusic, 5200, 5220 XpressMusic, 5300 XpressMusic, 5310 XpressMusic, 5320 XpressMusic, 5500, 5500 Sport, 5610 XpressMusic, 5700 XpressMusic, 5710 XpressMusic, 6085, 6086, 6110 Navigator, 6120 Classic, 6121 Classic, 6124 Vodafone, 6125, 6126, 6131, 6131 NFC, 6133, 6135, 6136, 6151, 6210 Navigator, 6212 Classic, 6220 Classic, 6233, 6234, 6267, 6270, 6280, 6282, 6288, 6290, 6300, 6300i, 6301, 6500 Classic, 6500 Slide, 6555, 6555 Classic, 6556 Classic, 6600 Fold, 6600 Slide, 6630, 6631 (NM850iG), 6650 T-Mobile, 6680, 6681, 6682, 7310 Supernova, 7370, 7373, 7390, 7500 Prism, 7510 Supernova, 7610 Supernova, 7900 Prism, 8600 Luna, 8800 Arte, E50, E51, E60, E61, E61i, E62, E65, E66, E70, E71, E90 Communicator, N70, N71, N72, N73, N75, N76, N77, N78, N79, N80, N81 8GB,N82, N85, N90, N91, N92, N93, N93i, N95, N95 8GB, N95 NAM, N95 8GB NAM, N96 Package contains # Cyclone Box - 1 pc. # Cable adaptor - 1 pc. # 100 ASK-RPL credits Weight: 0.2kg Available in Hong Kong stock Buy now Price 139 USD | Suggest your price |
03-27-2009, 19:56 | #10 (permalink) |
Insane Poster Join Date: Feb 2007
Member: 454648 Status: Offline Thanks Meter: 18 | Why is this happening? Cyclone box team... Box SN: XXXXXXX HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Box Maintenance Error -> '2009-03-27' is not a valid date |
03-27-2009, 20:28 | #11 (permalink) | |
The Following User Says Thank You to karwos For This Useful Post: |
MANUAL: FIRST StEPS WITH CYCLONE BOX | Hell-GSM | Cyclonebox | 18 | 08-12-2012 17:51 |
Cyclone box not instaled | CHERIFA | Cyclonebox | 15 | 07-02-2009 21:33 |
6263 Tmobile U.S.A need to flash please help! Team Cyclone box is my first time flash | mymiela0419 | Cyclonebox | 3 | 05-21-2009 11:28 |
Welcome cyclone box india + world first vodafone india strom unlock ready | chiragp | Main Sales Section | 0 | 03-31-2009 07:13 |
