12-06-2010, 06:16 | #31 (permalink) | |
Junior Member Join Date: Jan 2010
Member: 1217562 Status: Offline Thanks Meter: 10 | Quote:
"Cyclone Nokia Application v01.49, should if you've managed to" Cyclone Secure Bootloader v2.12 | |
The Following User Says Thank You to S h i f u For This Useful Post: |
12-06-2010, 06:52 | #37 (permalink) |
Insane Poster Join Date: Aug 2006 Location: philippines
Member: 333797 Status: Offline Sonork: hardmuscles Thanks Meter: 5 | i have a question cyclone team,, is this update can fix like this problem 5130c auto shut off???? heres the logs: Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Failed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 29, Tests passed: 27, Tests not passed: 2 |
The Following User Says Thank You to hardmuscles For This Useful Post: |
12-06-2010, 07:11 | #39 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | no single phone booting in new version First of all thnx for new verssion iam finding still problem in new version no single phone booting log 5130 Box Firmware: Cyclone Nokia Application v01.49, (Dec 2 2010 13:37:45, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C00001A0 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Initializing security card... Card Serial Number: D1000350 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.05v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.82v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 8.26v PASSED Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 316 products, Filtering BB5 Products - wait... Failed to Substitue INI Variant Data -> Access violation at address 00614DD4 in module 'Cyclone.exe'. Read of address 00000000 194 Products left after filtering. Ready. Retrieving Variants for Product - wait... Failed to retrieve BB5 Variants -> Unexpected error, no VPL or neither INI files found inside Product Directory Retrieving Variants for Product RM-495 (Nokia 5130 XpressMusic) - wait... 2 Variants Retrieved Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-495_356040036722177_1262010_111759 AM.SecurityBlock.PM" WARNING: "1EC0000AAC2E7F56DB573EF315460394E83D466F.C00001A0 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1EC0000AAC2E7F56DB573EF315460394E83D466F CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "1EC0000AAC2E7F56DB573EF315460394E83D466F.C00001A0 " Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Backing up simlock... MCU Version V 07.97 MCU Date 13-09-10 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 356040036722177 Mastercode 02323267 Simlock backup OK, saved to RM-495_356040036722177_1262010_111821 AM.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm495__07.97.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm495__07.97.mcusw 2nd 3310c ............................. Processing C:\Program Files\Nokia\Phoenix\Products\... Found 316 products, Filtering BB5 Products - wait... Failed to Substitue INI Variant Data -> Access violation at address 00614DD4 in module 'Cyclone.exe'. Read of address 00000000 194 Products left after filtering. Ready. Retrieving Variants for Product RM-237 (Nokia 3110c) - wait... 9 Variants Retrieved Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Prepare phone failed with message -> Failed to Boot CMT Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone NOW LOG IN UFS BOOTING OK NOKI3310C ................................. ST BOOT : C0,07 [Rm-237] [2.1.0.1] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0E30010ED1116F562CD554B953100F0DDD8163D7 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent PASUBTOC : PA_SL Rebooting Mobile NOW 5130 SAME PHONE BOOTING IN UFS 1ST BOOT : C0,07 [Rm-495] [2.1.0.1] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 1EC0000AAC2E7F56DB573EF315460394E83D466F RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT KSIG0 : 0C917F11196FDB7378C18EF7260698CA4489DCA0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent PASUBTOC : PA_SL3 Rebooting Mobile WHAT WRONG YESTERDAY I FLASHED ALL PHONE ALL WAS OK |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
12-06-2010, 07:48 | #42 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Box Maintenance procedure started at 12:13:36 PM Handling device: [Cyclone Team], [Cyclone Box] Handling device: [Cyclone Team], [Cyclone Bootloader] Bootloader: Cyclone Secure Bootloader v2.12, (Jul 1 2010 01:06:33), Type: Signed Production Application, Added Clip Support Service Tag: F22030E1C43DCC39FC6C04C7124A3029 Connecting to Cyclone Server Cyclone Server (1.0.0.651), Cyclone Box Team 2008, 2009, 2010 - Ready. ========= Box Info ========= Box SN: C000019D HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D0000092 First Name: Nazmul Surname: Rasel Nickname: Rasel.net Address: Gajipur,Bangladesh Country: Bangladesh E-Mail: [email protected] Reseller: JHON_DREAM, Bangladesh Warranty Start Date: 2009-05-19 Warranty Period (months): 6 Warranty Stop Date: 2009-11-19 Warranty active: No ============================ Updating Security Area... Security Area Updated, Took: 0.125s Updating Main Firmware... Main Firmware Updated, Took: 15.157s Updating COM Emulator Firmware... COM Emulator Firmware Updated, Took: 1.296s Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Firmware: Cyclone Nokia Application v01.49, (Dec 2 2010 13:37:45, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41 Server Challenge Accepted, Bootloader Upgraded! Commiting changes on server now... Commited OK! All OK! Secure Bootloader Upgraded OK! Disconnected from Cyclone Server Box Maintenance finished successfully |
The Following User Says Thank You to [email protected] For This Useful Post: |
12-06-2010, 07:50 | #43 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: KABUPATEN SLEMAN
Member: 714648 Status: Offline Sonork: 1609640 Thanks Meter: 931 | Quote:
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support | |
The Following User Says Thank You to mr.omphonx For This Useful Post: |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
Upload & Download Eprom | Lousangeles | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-24-1999 05:45 |
