Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 04-06-2012, 16:02   #1 (permalink)
SiRoYa's Avatar
Member: 16107
Cyclone Box USB 3.0 Bootloader v3.00 Released
Hi, new Bootloader for Cyclone Box is ready!
What's new?
- Built from scratch
- More startup stability
- Much better smartcard initialization routines
- 2x faster (previous boot main fw update - ~20secs, new one ~11secs)
- USB 3.0 Compatibility == 4x faster from Initial Bootloader!
Upgrade box using new Boot loader, usb 3.0 mode
Box Maintenance procedure started at 16:21:42
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Bootloader: Cyclone Classic Common Bootloader v3.00, (Apr 6 2012 16:14:55)
Service Tag: 0D1BB140D1F7F2475586D877E7357B6E
Connecting to Cyclone Server
Cyclone Server (2.0.0.4), Cyclone Box Team 2008-2011 - Ready.
========= Box Info =========
Box SN: C000xxx
HW Revision: B, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2009, wk23 / wk19
Set: Classic Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Paired Card SN: xxx
First Name: xxx
Surname: xxx
Nickname: xxx
Address: xxx
Country: xxx
E-Mail: xxx
Reseller: GPGIndustries, China
Warranty Start Date: 2012-02-16
Warranty Period (months): 6
Warranty Stop Date: 2012-08-16
Warranty active: Yes
Updating Security Area...
Security Area Updated, Took: 0.31s
Updating Main Firmware...
Main Firmware Updated, Took: 6.240s
Updating COM Emulator Firmware...
COM Emulator Firmware Updated, Took: 0.390s
Updating Secure Bootloader...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Firmware: Cyclone Nokia/Blackberry Application v01.89, (Mar 29 2012 16:06:54, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41
Bootloader is already Up-to-date
Secure Bootloader Update Skipped
Disconnected from Cyclone Server
Box Maintenance finished successfully
USB 2.0 Mode
Box Maintenance procedure started at 16:24:19
Product: Classic
Box SN: xxx
Paired Card SN: xxx
First Name: xxx
Surname: xxx
Nickname: xxx
Address: xxx
Country: xxx
E-Mail: xxx
Security Area Updated, Took: 0.94s
Main Firmware Updated, Took: 11.575s
COM Emulator Firmware Updated, Took: 0.749s
Boot Agent: Cyclone Secure Boot Agent Server v3.01 (C) KarwosSoft 2010 wk41
Just upgrade your box using Box Maintenance.
Join us on facebook: Cyclone Box | Facebook
CYCLONE BOX - POWER ON AND UPGRADE!
Stay tuned
Best Regards,
CycloneBox Team
Old 04-06-2012, 16:14   #2 (permalink)
Member: 787088
Sonork: 72000
Box Maintenance procedure started at 5:14:50 PM
Box M aintenance Error -> No connection was established, or box is not in needed mode i hew this problem sir
The Following User Says Thank You to flamuri For This Useful Post:
Old 04-06-2012, 16:38   #3 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Bx maintenance again.
The Following User Says Thank You to karwos For This Useful Post:
Old 04-06-2012, 16:50   #4 (permalink)
Member: 1128573
Please clear sir, USB 2.0 MODE is :
USB 2.0 Mode
here USB 3.0 MODE is :
heUpgrade box using new Boot loader, usb 3.0 modeQuote:
please clear sir, thanks for new update.
with best regards,
mahir
The Following 2 Users Say Thank You to mahir ashab For This Useful Post:
Old 04-06-2012, 16:57   #5 (permalink)
Member: 1730381
Cool Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS
Security Area Updated, Took: 0.63s
Main Firmware Updated, Took: 14.742s
COM Emulator Firmware Updated, Took: 0.936s
Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1),
Server Challenge Accepted, Bootloader Upgraded! Commiting changes on server now...
Commited OK! All OK!
Secure Bootloader Upgraded OK!
The Following 2 Users Say Thank You to ScorpiusFX For This Useful Post:
Old 04-06-2012, 17:07   #6 (permalink)
Member: 1730381
I used USB Speed 3.0 on back Panel port from Asus Crosshair V Formula.
The Following User Says Thank You to ScorpiusFX For This Useful Post:
Old 04-06-2012, 17:08   #7 (permalink)
Br.Ihsan's Avatar
Member: 1489021
Sonork: 100.1620946
plz release same setup exe bekaz sam time server not work ok that is will be good deed if u release setup
Old 04-06-2012, 17:13   #8 (permalink)
.:iTRi:.'s Avatar
Member: 240068
i try to updat but software hang will changing t main mode
Old 04-06-2012, 22:14   #9 (permalink)
SMK
Member: 189831
Security Area Updated, Took: 0.62s
Main Firmware Updated, Took: 14.891s
COM Emulator Firmware Updated, Took: 0.937s
Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr  6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed
Old 04-07-2012, 04:57   #10 (permalink)
kalpeshoza's Avatar
Member: 462292
Main Firmware Updated, Took: 14.265s
COM Emulator Firmware Updated, Took: 0.906s
Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Old 04-07-2012, 04:59   #11 (permalink)
mr.omphonx's Avatar
Member: 714648
Sonork: 1609640
Main Firmware Updated, Took: 14.734s
COM Emulator Firmware Updated, Took: 0.938s
Old 04-07-2012, 06:53   #12 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
disable your virus guard and try it again..........
Old 04-07-2012, 08:00   #13 (permalink)
Sucre79's Avatar
Member: 1413902
Sonork: 100.1611698
it is not about virus guard
i had same problem and i turn off antyvir and nothing.
So i turn it on and after 6-7 times to Box Maintenance finaly bootloader update success
Old 04-07-2012, 10:00   #14 (permalink)
Member: 1128573
Boss, my system is ok ? or not. i already update box. but i can't find Bootloader 3.0.
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.90, (Apr 6 2012 17:35:46, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: xxxxxxxxxxxxxxxxx
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32
please reply.
Sincerely Yours'
mahir
Old 04-07-2012, 10:11   #15 (permalink)
amralkareem's Avatar
Member: 153397
Sonork: 113032
Box Maintenance procedure started at 11:10:19 AM
Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support
Service Tag: 2FB6D7A6FC0F58963002CB0BEEFF5485
Box Maintenance Error -> Can't connect to Cyclone Server
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-16-2011 09:59
sp lock 1,2,3,4 removed spterminator Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 08-09-2010 10:20
£2,000 for 5110/6110 unlock software 1 2 3 4 Dean O'Grady Wanted Products 14 03-19-2005 09:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
NHE_8 wont work with NHEK5689.dll v3 steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-23-1999 15:48
Page generated in 0.46012 seconds with 12 queries
