Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-01-2009, 22:22   #31 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Exclamation Free 5V to 9V Step-up DC - DC converter
If you dont want to build the DC -DC converter posted by MiH because dont have the knowledge o are too lazy, you can get ones ready to use, for free.... look for an old 10Mbps ethernet card, the ones that comes with BNC conector, they use an 5V to 9V DC-DC converter.....
Ptt
The Following 2 Users Say Thank You to ptt For This Useful Post:
Old 06-02-2009, 06:00   #32 (permalink)
randy_d4's Avatar
Member: 71246
Thanks Meter: 40
Originally Posted by Cyclonebox View Post
It's internal VPP problem not External.
Can you post picture of your PCB please?
Sorry, my sonork lost
Yes!
Also here is log without External adapter:
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06
Initializing security card...
Card Serial Number: D20000XX
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	4,97v	PASSED
MCU Voltage	3,29v	PASSED
Core Voltage	1,75v	PASSED
VBAT Voltage	0,01v	PASSED
VBAT Voltage	4,93v	PASSED
Box VPP disabled
VPP Voltage	0,07v	PASSED
Internal Box VPP Enabled
VPP Voltage	4,83v	PASSED
Box VPP disabled
VPP Voltage	0,02v	PASSED
External Box VPP Enabled
VPP Voltage	0,04v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
One more thing that i have noticed,when i connect ext adapter 9V consumption rises to more than 500ma and pcb become warmer.
Old 06-05-2009, 14:42   #33 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,053
I think if is in project to modify the PCB of cyclone is to consider this..
If is added this modify to obtain the 9V from a 5V external source we can use the same source to give power to the fone on the Vbatt. Using a power module like the NEO_49 one
it will be powered by a stable 5V power supply solving all the APE problems..
This two modify together coul make of Cyclone the most reliable BOX adding stability in powering the mobile and speed in the flash operation just using only one external power supply 5V 1A.
The only problem left open is the BSI value but this one can be easy solved using Good cable or the Cyclone Cable set when out.. no roblem of course for who is using a UFC.
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 06-05-2009, 23:11   #34 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Hi to all, i think, there is some alternatives an some things to consider:
- Most of power supply issues are related to 5V provided by USB port are related to bad quality PC power supply, most motherboard take the power from 5VSB (stand-by power) for USB ports, and many other ICīs and if it is not good quality you can have troubles
- The power delivered to the Phone is taken from USB port via LM1950T (U3 in Cyclone PCB) it is a switch 750mA continuous 1.4A peak. It`s like Neo_49 power module.
Cyclone team, maybe can:
- Provide the box with a cable like is used in some external 2.5" HDD cages: it have 2 USB A conectors, 1 with te 4 wires, the other only +5V and GND, and 1 USB B (box conector) it is to can use more power.
- Provide the box with an 5V 2A switching power supply like the PSM11R-050 from PHIHONG TECHNOLOGY CO LTD (UL listed E127643) adding a switching step-up converter like MiH`09 but with SMD MC34063 in a daugtherboard (you can contiunes using actual PCB) to obtain the 9V for VPP and not take Power from USB, i think this is the best way to solve both troubles: VPP & Local mode- power suply to phone. But it increase the cost of the Box.
Sorry my bad eng.
The Following User Says Thank You to ptt For This Useful Post:
Old 06-10-2009, 05:18   #35 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
I am using Smart clip Charger 9v- 500mA
VPP Voltage 12.83v FAILED - IGNORED - Probably power supply is not connected
Card Serial Number:---------
Card is activated
Box is activated
USB Voltage 5.03v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.82v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
VPP Voltage 5.01v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Box VPP disabled
Old 06-10-2009, 05:42   #36 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,070
Originally Posted by moulnisky View Post
if is added this modify to obtain the 9v from a 5v external source we can use the same source to give power to the fone on the vbatt. Using a power module like the neo_49 one
it will be powered by a stable 5v power supply solving all the ape problems..
This two modify together coul make of cyclone the most reliable box adding stability in powering the mobile and speed in the flash operation just using only one external power supply 5v 1a.
The only problem left open is the bsi value but this one can be easy solved using good cable or the cyclone cable set when out.. No roblem of course for who is using a ufc.
alex
requred more perfect connection daigram where to wher connect.it is difficult to understand
Old 06-16-2009, 00:20   #37 (permalink)
Member: 499059
mr sawrou how to flach nokia 5800 with cycolone box ime 12345678
Old 06-23-2009, 14:03   #38 (permalink)
Hady_e02@yahoo's Avatar
Member: 326924
Thanks Meter: 31
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC
Box Serial Number: C00003E6
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk32
Card Serial Number: D100038B
Card is activated
Box is activated
USB Voltage 5.02v PASSED
VBAT Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Box Selftests Failed -> VPP Supply Voltage test failed, 0.04v is out of valid range
box failed seltest diagnostic...i measure with avometer it's about 9,5v dc adaptor that i use...what's wrong?i hv jumper R53..please help me..
Old 06-23-2009, 22:11   #39 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,689
Initializing box...
Card is activated
Box is activated
Box VPP disabled
Check LM1950t / CS 8240 power supply ICs.. looks like they might have some problems
Old 06-24-2009, 12:47   #40 (permalink)
MiH
MiH's Avatar
Member: 18876
Thanks Meter: 27
I just tested a flashing speed with and without Vpp connected.
IT SEEMS MY HW REVISION OF CYCLONE DOES'N HAVE VPP PIN (pin 9) CONNECTED !!! Only to capacitor C60 (0,1uF) and from it nowhere !!!
For proper work is need to connect a small wire as is on picture (yellow colour).
(just look bellow on pics)
Old 06-24-2009, 16:28   #41 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Well, It was stated already on forum that some HW revisions haven't placed R53 resistor, In fact you don't need cross,
but you need find "R53" field and make cross on it (or put 0R) resistor
Old 06-24-2009, 17:00   #42 (permalink)
MiH
MiH's Avatar
Member: 18876
Thanks Meter: 27
But in my PCB is not a R53 position, even wire from Vpp pin.9 is connected ONLY to C60 (it is very well to see in photos).
Old 06-24-2009, 20:52   #43 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
R53 What is? thank sir
Old 06-24-2009, 20:59   #44 (permalink)
LIEREN's Avatar
Member: 917576
Thanks Meter: 533
box de DIAGNOSTIC ?? Please answer thanks you....sir
Old 06-24-2009, 22:13   #45 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Check this picture please and compare your pcb
The Following 2 Users Say Thank You to karwos For This Useful Post:
MXKey, PolarBox2, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box shahzaadbutt Main Sales Section 0 03-27-2010 07:33
MXKey, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box shahzaadbutt Main Sales Section 0 02-24-2010 10:51
Bomb!!Bomb!!Wifi box ,Cyclone box and Mx key dongle all is in good price lotusgsm.com Main Sales Section 0 01-19-2010 10:04
Hi siroya nadeem gondal cyclone box and new product supporter AY29!4LYF Cyclonebox 0 07-15-2009 17:47
How is cyclone box and who is behind this project? Mr.3. Off Topic Zone 0 03-19-2009 04:37
Page generated in 0.26982 seconds with 11 queries
