Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 06-24-2009, 22:51   #46 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
@Cyclonebox
thank.......you
Old 06-25-2009, 08:17   #47 (permalink)
MiH
MiH's Avatar
Member: 18876
Thanks Meter: 27
My PCB layout is in picture bellow.
Old 06-25-2009, 10:03   #48 (permalink)
Member: 288754
Thanks Meter: 63
Originally Posted by MiH View Post
In schematic below is Vpp voltage generator from
5V input (USB) voltage. Output stabilised voltage
9,75V / 100mA is connected to "external power input
connector". Idle power current is only 6mA.
Almost all needed components to build a generator is
used from low cost common 12V car mobile phone charger
(IC,diode, capacitors, resistors).
Generator is fitted inside cyclone box and is connected
via 3 wires (input 5V usb, GND, output Vpp)
Parameters:
Input voltage : 3,0 - 7,5V
Output volage : 9,75V (+/- 10mV, adjusted by R1/R2)
Efficency : 89%
Idle curent : 6 mA
Max. out curent : 100 mA (adjusted by R4)
you are very attentive it's great trick !
Old 06-26-2009, 11:17   #49 (permalink)
randy_d4's Avatar
Member: 71246
Thanks Meter: 40
@Cyclonebox
What about my problem here and here?One month without clear answer!!Do U actually know how many pcb revision is made for your CODE? Why mine pcb(and mine's friend also) are with low power voltage regulators?Pls as u may know hardware is also so important as software!!
Pls take a time to answer me this time!
Old 06-26-2009, 22:38   #50 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
The box has 6 month warranty... contact your reseller....
Old 06-27-2009, 13:33   #51 (permalink)
Member: 226457
Sonork: No more used
Thanks Meter: 14,934
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.03v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.82v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
Internal Box VPP Enabled
VPP Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 8.33v PASSED
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Old 06-27-2009, 17:18   #52 (permalink)
Member: 565487
Sonork: 100.1590618
Thanks Meter: 35
I'm use AC ADAPTOR of Smart-Clip 9v -500mA
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
problem ...ich spreche turkisch help
Old 06-27-2009, 21:50   #53 (permalink)
Member: 48933
Thanks Meter: 104
you should use DC power supply
br,A
Old 06-28-2009, 09:14   #54 (permalink)
Member: 624576
Thanks Meter: 6
hi all! if i open my box to modify will i lose waranty?
Old 06-28-2009, 10:16   #55 (permalink)
Member: 894224
Thanks Meter: 96
please help me after commanding erase all chips 1202 with cyclone now contact service and when i flash it remains the same
Old 06-28-2009, 10:22   #56 (permalink)
Member: 894224
Thanks Meter: 96
Old 06-28-2009, 22:00   #57 (permalink)
ivanx's Avatar
Member: 59404
Thanks Meter: 20
i have the same problem,then i use use fully stabilised 9.5v DC supply
this is how i solve my problem.
Old 06-29-2009, 16:04   #58 (permalink)
.::TR_LAZ::.'s Avatar
Member: 178227
Sonork: 100.1597371
Thanks Meter: 176
thanks ...
Cyclonebox
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC
Box Serial Number: C0000EB0
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06
Initializing security card...
Card Serial Number:********
Card Firmware Revision: 0****
Card is activated
Box is activated
USB Voltage 5,06v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,76v PASSED
VBAT Voltage 0,68v PASSED
VBAT Voltage 5,02v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
VPP Voltage 4,92v PASSED
Box VPP disabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Found 89 products, Filtering DCT4 Products - wait...
11 Products left after filtering. Ready.
Retrieving Variants for Product RM-298 - wait...
253 Variants Retrieved
Processing pre-flash tasks...
Backing up Flash IMEI...
RPL is Stored in PM...
Flash IMEI Backup OK
Pre-flash tasks finished
Booting UPP...
UPP ID: 3162 [HW_UNKNOWN]
rm298__05.20.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x0020881C @ 0x01000000, ST, SectorSize: 128kB, Ext: 00009221
FlashChip[1]: 0x0020881C @ 0x02000000, ST, SectorSize: 128kB, Ext: 00009221
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 51Kbits
u3_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x0020881C (256Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,04V
MSID-Crypted: 84755AE59ED3765A7DD7AAE595
MSID-Plain: 2C40BAE9005F3C7CA8000000
FAID-Crypted: 7CB36FEE212661031CCB4781
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01C3FFFF]
Erase taken 58.374s
Writing 343 blocks...
All blocks written OK! Time taken 520.939s
Terminating flash session
Box VPP disabled
Booting UPP...
rm298__05.20.image_ad, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 84B11141F88AB54AACEEA9F6CA
MSID-Plain: D26EBAF1005F3C7CAA000610
FAID-Crypted: 5CE5BF18186A73C7DD575DB2
Erasing NOR Region [0x02000000-0x02DBFFFF]
Erasing NOR Region [0x02DC0000-0x02F9FFFF]
Erase taken 73.366s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 264 blocks...
All blocks written OK! Time taken 180.730s
Extracting Content Package...
CP Extract Failed -> CP Server not exists
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rm298__05.20.ppm_ad, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 845A5365690DD0D51BD79257AC
MSID-Plain: 3E4EBAE9005F3C7CA9000000
FAID-Crypted: 423F9B1C582E13025B4065C6
1 Region(s) to erase
Erasing NOR Region [0x01C40000-0x01FFFFFF]
Erase taken 17.64s
Writing 88 blocks...
All blocks written OK! Time taken 129.687s
Box VPP disabled
Processing post-flash tasks...
Unlocking...
MCU Version V 05.20
MCU Date 06-12-07
Product RM-298
Manufacturer (c) Nokia
IMEI 359**********
Mastercode 373111***
Asic 11
HW Signature 8089070BDFCD66CC
Simlock Server SIMLOCK SERVER
Simlock Key 0010100000000000
Simlock Profile 800000000001000B
Simlock Aux 000B5555
Simlock IMEI 0055***60*****6187300
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Selecting unlock method...
Search in: C:\Program Files\Cyclone Box\UnlockData\
Searching for: RM-298_V 05.20.unlock_img
Asking card to sign HW Signature...
Signed OK (958A4985260507079CD699D88604D48D3C45D6C5)
Writing patch file...
Booting UPP...
shadow, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Using MSID-FAID Cache, Not wasting card
Erasing NOR Region [0x01080000-0x0109FFFF]
Erase taken 1.222s
Writing 10 blocks...
All blocks written OK! Time taken 12.227s
Box VPP disabled
Simlock Security - NOT TAMPERED
Saving Simlock to "RM-298_3595********_29.06.2009_175612.Unlock.PM"
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Unlock thread finished, continuing...
Post-flash tasks finished...
Flash successfully finished!
Old 07-05-2009, 02:43   #59 (permalink)
iwan8818's Avatar
Member: 859702
Sonork: 100.1619060
Thanks Meter: 78
Originally Posted by honyjee View Post
can we use external adopter to box on socket (AC adopter)
yes can, search this power supply,
or u can use cpf box power supply..
input :100-240-50hz, 0.4A
output : +9 --- 2A
Card is activated
Box is activated
USB Voltage 5.05v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.79v PASSED
VBAT Voltage 4.90v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Box VPP disabled
VPP Voltage 8.60v PASSED
Box VPP disabled
Old 07-05-2009, 19:34   #60 (permalink)
Hady_e02@yahoo's Avatar
Member: 326924
Thanks Meter: 31
output : +9 --- 2A
Card is activated
Box is activated
Box VPP disabled
Box VPP disabled
Box VPP disabled
i hv used cpf adaptor..but it's failed selftest vpp...i just hv many2 question about this matter...
1.should we make this jumper of R53?why shall it happen if we do jumper or not?wht's the influence to the tx line?why do supporter say why must deliver it on service pin 10?
2.according to the pic,shall we remove 2 capasitors?if not wht's the problem?
3.why do the factory put the resistor before release to the market..why should we as user must do it?do u know that we can loose our warranty??
i hv jumpered the resistor n plug cpf adaptor..but it's still failed on selftest vpp external..should we jumper it if we want to use vpp external??please somebody help me to explain all my questions..also give me detail in explaination about vpp service pin...coz supporter not give detail manual n explanation..surely many peoples r confused...hopes someone there will clear all this matter..really thx for this kind person
MXKey, PolarBox2, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box shahzaadbutt Main Sales Section 0 03-27-2010 07:33
MXKey, Infinity Box, Z3X, Cyclone Box And Many More Inside This Box shahzaadbutt Main Sales Section 0 02-24-2010 10:51
Bomb!!Bomb!!Wifi box ,Cyclone box and Mx key dongle all is in good price lotusgsm.com Main Sales Section 0 01-19-2010 10:04
Hi siroya nadeem gondal cyclone box and new product supporter AY29!4LYF Cyclonebox 0 07-15-2009 17:47
How is cyclone box and who is behind this project? Mr.3. Off Topic Zone 0 03-19-2009 04:37
Page generated in 0.31230 seconds with 10 queries
