05-18-2012, 09:03 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: jakarta
Member: 434480 Status: Offline Thanks Meter: 14 | Help Need Backup full rpl E5 RM-632 [SOLVED] Code: Dynamic Camera Configuration Analyze/Repair Finished! Started Phone Security Analysis... MCU Version V ICPR82_11w16.3.10 MCU Date 13-03-12 Product RM-632 (Nokia E5-00) Manufacturer (c) Nokia IMEI 354859041143307 Mastercode 1176126510 Reading Security Block... Security block OK and saved to "RM-632_354859041143307_5182012_25153 PM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits !!!!! HWC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! !!!!! CCC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48.C0002BA8" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder. Last edited by ptt; 05-18-2012 at 11:39. Reason: ADD [CODE] [/CODE] TAG TO THE LOG |
05-18-2012, 09:26 | #2 (permalink) |
Freak Poster Join Date: Mar 2012 Location: LAND of *****
Member: 1742117 Status: Offline Thanks Meter: 35 | brother you need pm file1-309 backup :d....................................... |
The Following User Says Thank You to ..::G$M-UNLOCK::.. For This Useful Post: |
05-18-2012, 09:50 | #5 (permalink) | |
Member: 1742117 Status: Offline Thanks Meter: 35 | answer is in log Quote:
To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder. Last edited by ptt; 05-18-2012 at 11:42. Reason: CHANGE FONT SIZE & COLOR - NOBODY IS BLIND HERE | |
05-18-2012, 10:12 | #6 (permalink) |
Member: 1742117 Status: Offline Thanks Meter: 35 | if not solve brother you need E5 without NPC DATA.rpl did u copy hwc and ccc to ur backup rpl? if not before do any think make copy of rpl and open in note ped edit and save and write after that write rpl and write pm 1-309 Last edited by ptt; 05-18-2012 at 11:42. Reason: CHANGE FONT SIZE & COLOR - NOBODY IS BLIND HERE |
05-18-2012, 10:25 | #7 (permalink) | |
Member: 434480 Status: Offline Thanks Meter: 14 | Quote:
Code: MCU Version V ICPR82_11w16.3.10 MCU Date 13-03-12 Product RM-632 (Nokia E5-00) Manufacturer (c) Nokia IMEI 354859041143307 Mastercode 1176126510 Reading Security Block... Security block OK and saved to "RM-632_354859041143307_5182012_41945 PM.SecurityBlock.PM" SX4 Status: Authorized [1,0] Written, Length: 116 bytes, Status: OK [1,2] Written, Length: 12 bytes, Status: OK [1,4] Written, Length: 112 bytes, Status: OK [1,6] Written, Length: 12 bytes, Status: OK [1,7] Written, Length: 216 bytes, Status: OK [1,8] Written, Length: 112 bytes, Status: OK [1,13] Written, Length: 12 bytes, Status: OK [1,16] Written, Length: 208 bytes, Status: OK [1,18] Written, Length: 208 bytes, Status: OK [1,20] Written, Length: 208 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,26] Written, Length: 112 bytes, Status: OK [1,28] Written, Length: 12 bytes, Status: OK [1,29] Written, Length: 12 bytes, Status: OK [1,31] Written, Length: 208 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 376 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 184 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 184 bytes, Status: OK [1,45] Written, Length: 184 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 4 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,3] Written, Length: 36 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 35, Record written NOT OK: 0 !!!!! HWC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! !!!!! CCC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48.C0002BA8" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder Last edited by ptt; 05-18-2012 at 11:43. Reason: ADD [CODE] [/CODE] TAG TO THE LOG -- CHANGE FONT SIZE & COLOR IN QUOTED PART | |
05-18-2012, 11:49 | #11 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Do you have also *.crt files? You need write all of them. They will be named like: 1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48.CMT.NPC.C RT |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
