06-24-2011, 23:25 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: spain
Member: 1092309 Status: Offline Sonork: 1001606496 Thanks Meter: 52 | Cyclone is a hard rock and best tool of nokia if you have one dead phone or hang in nokia logo or ...many problemes and you haven·t corrupted IMEI .HERE in version 1.15 of cyclone you have the solution. Best team with best box cyclone Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.62, (Jun 5 2011 22:22:07, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: Cxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: Dxxxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,90v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work After make RPL from phone and read PM (0-512) Do full eras Code: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 20A00117C42B625078398B41973722E9FF5017BB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x03FFFFFF, NOR Waiting 640s for erasure finish... Erase taken 210.828s Restarting MCU... BB5 Full Erase Finished! After Full Eras you can flash with any software(flash) no probleme Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm495__06.94.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 20A00117C42B625078398B41973722E9FF5017BB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__06.94.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 4.891s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 79.875s Flashing Speed: 1908,22 kBit/S Restarting MCU... Processing rm495__06.94.mcusw (APE)... Processing rm495__06.94.ppm_ag (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 20A00117C42B625078398B41973722E9FF5017BB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__06.94.ppm_ag, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR Waiting 320s for erasure finish... Erase taken 2.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 31.421s Flashing Speed: 1838,38 kBit/S Restarting MCU... Processing rm495__06.94.ppm_ag (APE)... Processing rm495__06.94_ISM_003.image_ag_blu_movi_es_blue (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 20A00117C42B625078398B41973722E9FF5017BB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__06.94_ISM_003.image_ag_blu_movi_es_blue, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 7.828s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 66.484s Flashing Speed: 1973,79 kBit/S Restarting MCU... Processing rm495__06.94_ISM_003.image_ag_blu_movi_es_blue (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! Don·t worry. with writing RPL saved ago all will be ok Code: MCU Version V 06.94 MCU Date 21-07-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452341F2000000 PPM V 06.94, 21-07-09, RM-495, (c) Nokia , AG CNT Content: ag_blu, Movistar Spain, 21-07-09, RM-495, (c) Nokia , , PSN 0 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 RFIC 06540601 DSP ICPR72_09w04 LCD SHARP BT 2222-143C Failed to read info -> Failed to read SP info Code: Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-495_12345610654321_24062011_232759.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 20A00117C42B625078398B41973722E9FF5017BB CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! Code: SX4 Authorization / SD Repair Procedure Started.... "20A00117C42B625078398B41973722E9FF5017BB.C0001DF4" Exists, That is good... MCU Version V 06.94 MCU Date 21-07-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 358006037xxxxxxx Mastercode 524011366 Reading Security Block... Security block OK and saved to "RM-495_358006037627663_24062011_233103.SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 12 bytes, Status: OK [1,1] Written, Length: 70 bytes, Status: OK [1,2] Written, Length: 70 bytes, Status: OK [1,3] Written, Length: 70 bytes, Status: OK [1,4] Written, Length: 70 bytes, Status: OK [1,5] Written, Length: 276 bytes, Status: OK [1,6] Written, Length: 276 bytes, Status: OK [1,7] Written, Length: 276 bytes, Status: OK [1,8] Written, Length: 276 bytes, Status: OK [1,9] Written, Length: 384 bytes, Status: OK [1,10] Written, Length: 384 bytes, Status: OK [1,11] Written, Length: 384 bytes, Status: OK [1,12] Written, Length: 384 bytes, Status: OK [1,13] Written, Length: 384 bytes, Status: OK [1,14] Written, Length: 384 bytes, Status: OK [1,15] Written, Length: 384 bytes, Status: OK [1,16] Written, Length: 384 bytes, Status: OK [1,17] Written, Length: 32 bytes, Status: OK [1,19] Written, Length: 16 bytes, Status: OK [1,20] Written, Length: 32 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 29, Record written NOT OK: 0 Code: Setting factory defaults of: Factory set full Factory defaults set OK http://forum.gsmhosting.com/vbb/f528...eased-1291726/ Last edited by ptt; 06-25-2011 at 00:20. Reason: Add CODE tag & Change some non readable font colors |
The Following 5 Users Say Thank You to KHAMI For This Useful Post: |
06-24-2011, 23:27 | #2 (permalink) |
Member: 1092309 Status: Offline Sonork: 1001606496 Thanks Meter: 52 | And the and read info .enjoy you phone MCU Version V 06.94 MCU Date 21-07-09 Product RM-495 (Nokia 5130 XpressMusic) Manufacturer (c) Nokia IMEI 3580060376xxxxxxxx Mastercode 524011366 IMEI Spare 3A85000673266706 IMEI SV 3385000673266746F2000000 PPM V 06.94, 21-07-09, RM-495, (c) Nokia , AG CNT Content: ag_blu, Movistar Spain, 21-07-09, RM-495, (c) Nokia , , PSN HEF350072 Product Code 0580572 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 1000 RFIC 06540601 DSP ICPR72_09w04 LCD SHARP BT 2222-143C Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21402F |
06-25-2011, 00:07 | #3 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | seriously it give us more passion to work harder after seeing such nice comments anyway their still lot more to come with cyclone box br SiRoYa |
The Following 6 Users Say Thank You to SiRoYa For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
