08-07-2013, 17:17 | #106 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | and if you want to want to buy 60 credits you can buy from here Cyclone box - credit & box order system |
08-07-2013, 21:36 | #111 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
08-07-2013, 22:16 | #112 (permalink) |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | @karwos.... urgent matter. Contact me on sonork. I sent request still you didn't accept. Now time to sleep. Therefore pls hurry. Don't ask why here... |
08-07-2013, 22:42 | #113 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: xxxxxxxx HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU Initializing security card... Card Serial Number: xxxxxxxx Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.04v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 598.864MB Avaiable Virtual Memory: 1.806GB Avaiable Pagefile: 1.586GB Initializing FBUS... All initialized - Ready to work Everythings ok? Is it activated successfully? |
08-08-2013, 00:32 | #114 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 435806 Status: Offline Thanks Meter: 10 | Quote:
08-08-2013, 02:45 | #115 (permalink) |
Junior Member Join Date: Feb 2010 Location: SKY:li.daihai
Member: 1242505 Status: Offline Thanks Meter: 1 | Box is activated Started box selftests procedure All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 1.311GB Avaiable Virtual Memory: 1.896GB Avaiable Pagefile: 2.889GB Initializing FBUS... All initialized - Ready to work Lumia No TP Root Procedure Started... If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected. Failed to Boot CMT -> No compatible USB devices detected Prepare phone failed with message -> Failed to Boot CMT Write Root Data Failed -> Failed to Boot OSBL Failed to Root Phone -> Rooting Failed |
08-08-2013, 07:40 | #117 (permalink) | |
Br karwos Hgyhgybg | |
08-08-2013, 07:42 | #118 (permalink) | |
Ask your reseller, or check at www.********** | |
08-08-2013, 07:43 | #119 (permalink) | |
08-08-2013, 10:09 | #120 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Hi, if i rooted unlocked with this update, then again i can update latest version firmware with cyclone or care suite is it possible? and one more thing again is it locked device? BR, Srinivas Reddy. |
