08-10-2013, 07:10 | #137 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
08-10-2013, 07:14 | #138 (permalink) |
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | so why we spend our credits? i dont understand your point, i f you have classi and you spent (sl3, lg, broadcom or iphone xperia) You paid credits and got something. In this solution doesnt eat any credits-even one! and u can activate it! |
08-10-2013, 07:26 | #139 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0006300 HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48 Initializing security card... Card Serial Number: D0090790 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.97v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.825GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work i hve 49 credit still same after update |
08-10-2013, 08:12 | #140 (permalink) | |
08-10-2013, 10:56 | #143 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1998346 Status: Offline Thanks Meter: 0 | Hi, There are four things I don't understand, could someone clarify them for me? - Is it totally free? - Do we need a cyclone box? - Is it permanent? - When will it be avalaible for lumia 900? Thank you in advance. |
08-10-2013, 11:30 | #144 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
answer: 1. No you need 60credits on cyclonebox account to get activation. 2. Yes you need CyloneBox 3. No is not permament after flash with other firmware need unlock phone again that got windows phone device , same is even with orginal code after flash need enter code again. 4. When will be ready and if noone copy lumia 800 solution that right now Karwos give for cyclonebox. | |
08-10-2013, 13:00 | #145 (permalink) | |
Member: 1998346 Status: Offline Thanks Meter: 0 | Quote:
2. Why does it says it's "no tp"? 3. Ok 4. Less than one week? | |
08-10-2013, 13:48 | #146 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | Quote:
2. Because to root or unlock you dont need disassemble and solder phone. Right now its one and only solution in the world. Just box or key and usb cable. | |
08-10-2013, 17:48 | #150 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1092831 Status: Offline Thanks Meter: 0 | my cyclone box it solved now... i just uninstal my old version, and instal with new version, thanks to cyclone team... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0004E38 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk35 Initializing security card... Card Serial Number: D0030231 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.07v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.02v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.10v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 1.17GB Avaiable Virtual Memory: 1.867GB Avaiable Pagefile: 3.33GB Initializing FBUS... All initialized - Ready to work |
