08-10-2013, 17:50 | #151 (permalink) |
No Life Poster Join Date: Feb 2009 Location: nicaragua
Member: 980307 Status: Offline Sonork: 100.1649165 Thanks Meter: 173 | please karwos help me Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0004218 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: DF000117 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,04v PASSED MCU Voltage 3,31v PASSED Core Voltage 1,77v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,02v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,97v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 510.128MB Avaiable Virtual Memory: 1.906GB Avaiable Pagefile: 1.948GB Initializing FBUS... All initialized - Ready to work i have 59 credits::: |
The Following User Says Thank You to daryl007 For This Useful Post: |
08-12-2013, 13:39 | #153 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Most Age: 50
Member: 129904 Status: Offline Thanks Meter: 55 | Hi Karwos, Please how to flash the original Nokia factory boot back into the phone after unlock? I dont want to let customer erase eMMC. Thanks in advance. Petr P.S. thanks for good job |
08-12-2013, 21:05 | #154 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 226 | Quote:
It's the same question! How to recover, after unlock? So do not go onto original flash.... | |
08-13-2013, 15:07 | #155 (permalink) |
Freak Poster Join Date: Feb 2006 Location: MOSTAGANEM Age: 41
Member: 232928 Status: Offline Thanks Meter: 124 | i need to activate my box i have 67 credit Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000290D HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: D0090433 Card Firmware Revision: 010A Card is activated Box is activated Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 500.988MB Avaiable Virtual Memory: 1.878GB Avaiable Pagefile: 797.400MB Initializing FBUS... All initialized - Ready to work |
08-14-2013, 06:32 | #156 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2008 Location: around the globe...
Member: 677681 Status: Offline Sonork: 100.1590886 Thanks Meter: 232 | HI , what does this mean i have no cridets on my box i bought cyclone reloaded with zero cridets does mean i need to buy activation ??? Timestamp: 2/17/2012 9:40:05 PM OSBL Bootloader Ready USB&UART Tracing set Write Root Data Failed -> Box is NOT ACTIVATED for Lumia NO TP! Failed to Root Phone -> Rooting Failed |
08-14-2013, 07:50 | #159 (permalink) |
Junior Member Join Date: Oct 2007 Location: Pasay City Phillipines
Member: 616276 Status: Offline Thanks Meter: 0 | Already pay credit sir for Cyclone Box Card Serial Number: D3000108 Payment details :Your transaction ID for this payment is: 6P605309N6240740S. thank you. |
08-14-2013, 08:47 | #160 (permalink) |
Member: 677681 Status: Offline Sonork: 100.1590886 Thanks Meter: 232 | 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [USB Composite Device]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.1 Version: v257.6 Build: 12 Timestamp: 2/17/2012 9:40:05 PM OSBL Bootloader Ready USB&UART Tracing set RSA Signature Calculated for QCB Boot, Writing... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 9/28/2011 10:52:12 PM Signer S/N: 23 Signer User ID: 10046114 Auth Level: Care Data Encryption: 0 Image Index: 0 Asic Index: 0 Type: Image Write Hashtable Parsed OK Certificate Accepted [ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200 Write taken 1.156s (Average speed: 6027.35kBits/s) Restoring Modem from |
08-14-2013, 12:24 | #162 (permalink) |
No Life Poster Join Date: Sep 2006 Location: 102 quy nhơn BĐ Age: 14
Member: 347720 Status: Offline Sonork: xxx Thanks Meter: 204 | sry but seem not fair old box and key have credit but reloader not have ,if i know this problem i will not buy more reloader box |
08-15-2013, 13:19 | #165 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | Can the Lumia 520 be rooted? And subsequently unlocked with Cyclone? Or is it still expensive codes only for this model? PS Yes I did use search! |
