Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-07-2013, 04:56   #61 (permalink)
TestCard17's Avatar
Member: 1357650
Sonork: 100.1611843
Thanks Meter: 103
Box Serial Number: B0000AB2
Lumia No TP is NOT ACTIVATED! (1)
Avaiable Physical Memory: 631.836MB
Avaiable Virtual Memory: 1.871GB
Avaiable Pagefile: 2.345GB
Initializing FBUS...
All initialized - Ready to work
bR
Old 08-07-2013, 05:26   #62 (permalink)
digitalgsm_cora's Avatar
Member: 727888
Thanks Meter: 218
So now is posible unlock Lumia 800? After root what we should do for unlock?
Please explain the procedure...
Lumia no TP activated ok :x
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:34:19, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Key Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: A0******
HW Revision: E, Suitable for: Production, Case: Orange Key Casing, MCU Manufacture Time: Green PCB Rev. 4 2012 wk33, MCU 2011 wk09
Box is activated
Started box selftests procedure
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 300.968MB
Avaiable Virtual Memory: 1.889GB
Avaiable Pagefile: 1.641GB
B.R.
Old 08-07-2013, 05:32   #63 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,435
Originally Posted by karwos View Post
Rooting procedure is SAFE. However, after rooting new MMC device will be detected, and Windows will ask you to format it. If you click yes, MMC will be erased. Don't do it, and you're safe.
as u said if we formate that MMC it will eresed
after do root proces if custmer plug USB at home and MMC option come and if he formate it then ??
litile confusion so pz clear it
Old 08-07-2013, 05:34   #64 (permalink)
habibkhoso's Avatar
Member: 407739
Sonork: 100.1603554
Thanks Meter: 203
what about my box i purchase since 2 week ago plz check if not activated , then plz give me gift as others
Box Serial Number: B00020C7
Old 08-07-2013, 05:37   #65 (permalink)
Member: 183390
Thanks Meter: 71
i hope some ******* will not copy or dope this good damn software in the market. Just respect each others work to be precise ...............
this is amazing work man love it...............
The Following User Says Thank You to Qmad3 For This Useful Post:
Old 08-07-2013, 05:39   #66 (permalink)
Member: 183390
Thanks Meter: 71
Means goodbye my precious data is that simple to answer.................
Old 08-07-2013, 06:15   #67 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
B000 means that this is realoeded- account with credits is empty
Old 08-07-2013, 06:22   #68 (permalink)
ferhel's Avatar
Member: 504865
Thanks Meter: 213
can cyclone reloaded can activate LUMIA NO TP.....................................
Old 08-07-2013, 06:43   #69 (permalink)
Member: 921094
Sonork: 100.1603246
Thanks Meter: 317
yes 60 credit you needed for activition its free for cyclone key users
Old 08-07-2013, 07:53   #70 (permalink)
nitin28's Avatar
Member: 309831
Sonork: 100.1601174
Thanks Meter: 14
how to activate my cyclone reloaded
i also done box wizard
i chk my cradit with server tool
Failed to Check Credits -> Failed to connect to Cyclone Server
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B0******
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
USB Voltage 5.03v PASSED
MCU Voltage 3.26v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.96v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Avaiable Physical Memory: 1.607GB
Avaiable Virtual Memory: 1.804GB
Avaiable Pagefile: 3.916GB
Old 08-07-2013, 08:06   #71 (permalink)
Member: 327106
Thanks Meter: 4
Hello! "Failed to connect to server" while a try update box firmware after update. How I can solve this problem? There are no problems with internet connection.
Old 08-07-2013, 08:21   #72 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
check now i restart server
The Following User Says Thank You to kaisak For This Useful Post:
Old 08-07-2013, 08:23   #73 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Initializing box...
Box is activated
Box VPP disabled
Box VPP disabled
Please check on credits tabs that you have enough credits on account (60 needed)
Old 08-07-2013, 08:30   #74 (permalink)
Member: 435806
Thanks Meter: 10
i successfuly updated my cyclone box and sad to say only 40 credits left...how about less than 60 credit how can we avail this wonderful gift unlock without tp?do we need to purchased credit?
Old 08-07-2013, 08:35   #75 (permalink)
Member: 209842
Sonork: 100.93537
Thanks Meter: 3,386
Pls paste your sn I will check Your credits history, This service not "eat" credits event on activation. 60 credits You need have on account, but we will not use this credits, so Your balance shouldnt change.
We gave free, without credits rooting-its first step for unlock without TP.
Why I need rooting my phone, its this same how unlock?
Rooting make that phone is fully opened to unlock simlock and write modified firmware.
No tp means no need soldering or disassembling phone and using JTAG for that.... total time needed is about 5 secs
Just root your phone and patch it by NSS for example ...
if you don't like patching, wait and we will present permanent unlock.
Page generated in 0.40371 seconds with 7 queries
