Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-15-2012, 23:43   #1 (permalink)
Member: 1599541
cyclone & nokia 2760 & nokia 6030, dont detectĦĦĦ
Hi , please if somethign can helpme to unlock these phones with cyclone box, i was instaled a file named: RM-225_0525_6030b.exe
but nothing
thanks
Old 05-15-2012, 23:47   #2 (permalink)
Member: 1727711
Sonork: 100.1590443
do u need to unlock ur 6030b ? u can unlock it without file just click unlock button..
post some results
Br,
Old 05-15-2012, 23:51   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
but nothing
thanks
THAT´S DCT-4 FONE...read info from fone to check comunicacion wed fone...then dct-4 tab press do job (unlock)...easy
Old 05-16-2012, 07:56   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
GO to DCT4 tab / Security
tick Old Asics Method
click direct unlock
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 05-16-2012, 16:41   #5 (permalink)
Member: 1599541
click direct unlock
the cable is new ( i am using a MT & JAF NK 6030 cable )
the cyclone is update
the phone on
but i can detect the phone ....
Old 05-17-2012, 06:55   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Use JAF nokia cable
click check bus
phone will go to local mode after successfully check bus
then make unlock
Old 05-17-2012, 17:10   #7 (permalink)
Member: 1599541
Use JAF nokia cable
click check bus
then make unlock
really sorry but i cant found the check bus option.........
Old 05-17-2012, 18:13   #8 (permalink)
Member: 1599541
the box dont detect the phones: nokia 2760 and nokia 6030
i am using new cables of ipmart. some solution please because i have 40 phones to unlock
thanks
Old 05-18-2012, 00:29   #9 (permalink)
Member: 1599541
i have a lot of nokia 2760 & nokia 6030 to unlock or flash but cyclone cant detect the phones..
i am using ipmart cables compatibles with the models
i dont know to do..
P.D: i unlock with the same box and options a lot of nokia 2600c ( 16 pieces), with nokia 2600c i dont have troubles... thanks
Old 05-18-2012, 00:58   #10 (permalink)
ptt
ptt's Avatar
Member: 348680
If the Box & Software was able to unlock other DCT4 phone, that means the Box & Software are OK, you should check your cables...
Make sure that your cables have UFS/JAF pinout
What you get if you do a "Check Flashing Bus" ?
Old 05-18-2012, 01:06   #11 (permalink)
Member: 1599541
hola, i get this:
Booting UPP...
Failed to Check DCT4 Flashing Bus -> UPP Not Responding
Old 05-18-2012, 01:19   #12 (permalink)
ptt
ptt's Avatar
Member: 348680
Are you using the latest Cyclone Software version ? is your Box FW up to date ?
When you connect the Phone to the Box, is it going to "Local mode" ?
Old 05-18-2012, 11:42   #13 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
One question, do you attach phone to SERVICE PORT?
Also, is it powered on (LOCAL MODE) on display?
Old 05-18-2012, 21:51   #14 (permalink)
Member: 1599541
i was used the box wizard and is update
when i connect the phone to the box, not happen nothing and cant detect the phone.
yes i attach the phone to SERVICE PORT, not display nothing in the display.
i have eset antivirus.. but with the nokia 2300 i dont have any problems
i can unlock and flash lot of nokias 2300
thanks
Old 05-18-2012, 23:24   #15 (permalink)
ptt
ptt's Avatar
Member: 348680
If the Nokia 2300 can be serviced OK, then is NOT the BOx or The Software
Check the nokia 2760 and nokia 6030 Cables
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.33921 seconds with 11 queries
