03-02-2010, 20:13 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Phil. Age: 48
Member: 589712 Status: Offline Thanks Meter: 82 | Cyclone please help unlock 5610..teach me how? [SOLVED] Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0002005 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D6000032 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.29v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.33v PASSED VBAT Voltage 5.20v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.19v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 IMEI Spare 3A45580002620304 IMEI SV 3345580002620374F5000000 PPM V 10.00, 06-03-09, RM-242, (c) Nokia , M2 CNT Content: m2, V 10.00, 06-03-09, RM-242, (c) Nokia , PSN CWB152047 Product Code 0558264 Module Code 0203378 Basic Product Code 0515121 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1201 RFIC 17141715 DSP ICPR71_09w03 LCD SEIKO BT 2222-143 Failed to read info -> Failed to read SP info Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 22A000142F960254920E021F25B464455300E707 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB Testing TX2 Line... Prepare phone failed with message -> TX2 Test Failed! Check cable or yellow TX2 Adapter! Failed to Read All Certificates -> Failed to Boot / Prepare Phone BB5 Unlock Started... MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK and saved to "RM-242_354850020263042_322010_91012 PM.SecurityBlock.PM" Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 22A000142F960254920E021F25B464455300E707 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB Testing TX2 Line... Prepare phone failed with message -> TX2 Test Failed! Check cable or yellow TX2 Adapter! BB5 Unlock Failed -> Failed to Boot / Prepare Phone |
03-02-2010, 20:32 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Use the TX2 adapter (the yellow cable in bundle with the box) The mobile you have has the simlock data corrupted Unlock it selecting the RPL method the click on unlock. Please report BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
03-02-2010, 20:47 | #3 (permalink) | |
Member: 589712 Status: Offline Thanks Meter: 82 | Quote:
hi alex same error.. please more tricks Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0002005 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D6000032 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.28v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.54v PASSED VBAT Voltage 5.19v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.19v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work BB5 Unlock Started... MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK and saved to "RM-242_354850020263042_322010_90929 PM.SecurityBlock.PM" WARNING: "22A000142F960254920E021F25B464455300E707.C0002005" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 22A000142F960254920E021F25B464455300E707 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F Prepare phone failed with message -> Not found required CMT Secondary Loader Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) BB5 Unlock Failed -> Failed to obtain Phone Unique | |
03-02-2010, 20:52 | #4 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Trick n. 2 : Fix your installation Donwload the last installer from the Cyclone website http://www.***************/downloads/...xInstaller.exe afterward download last exe and copy it in the cyclone main folder http://www.***************/downloads/Cyclone.exe Then retry the unlock BR Alex |
03-03-2010, 11:09 | #6 (permalink) | |
Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: C0002005 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: D6000032 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.31v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.23v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.17v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 IMEI Spare 3A45580002620304 IMEI SV 3345580002620374F5000000 PPM V 10.00, 06-03-09, RM-242, (c) Nokia , M2 CNT Content: m2, V 10.00, 06-03-09, RM-242, (c) Nokia , PSN CWB152047 Product Code 0558264 Module Code 0203378 Basic Product Code 0515121 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1201 RFIC 17141715 DSP ICPR71_09w03 LCD SEIKO BT 2222-143 Failed to read info -> Failed to read SP info BB5 Unlock Started... MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 Warning: Failed to read SP Info, Assuming defaults Simlock Server SIMLOCK SERVER Simlock Key 0000000000000000 Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Security block OK and saved to "RM-242_354850020263042_322010_94534 PM.SecurityBlock.PM" WARNING: "22A000142F960254920E021F25B464455300E707.C0002005" Not Exists, Will read it... Reading CYC file from phone... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 22A000142F960254920E021F25B464455300E707 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Readed OK, Saving to "22A000142F960254920E021F25B464455300E707.C0002005" Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: RPL Calculation Asking box to calculate RPL... Received RPL from Box OK! Writing Simlock... Simlock ACCEPTED OK ! MCU Version V 10.00 MCU Date 06-03-09 Product RM-242 Manufacturer (c) Nokia IMEI 354850020263042 Mastercode 5655747045 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 8000000000000006 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Unlock finished! Time taken 28.766s Cyclone is the best...! | |
pls someone teach me how to recover IMEI after damaged by cyclone box | Mr.3. | Cyclonebox | 4 | 05-07-2009 22:42 |
Please teach me how to unlock 820SC using SPT-Box. | tkhs1157 | SPT BOX | 6 | 04-08-2008 10:48 |
Help Can ANy teach me how to Attact 903 with Sharp Cable | Weasley | Cruiser Suite | 16 | 10-31-2005 08:41 |
Teach me how to flash Erase file,please! | Format1 | Griffin | 8 | 03-22-2005 08:35 |
