04-05-2011, 08:20 | #1 (permalink) | ||
No Life Poster Join Date: May 2007 Location: QC FAIRVIEW
Member: 504865 Status: Offline Thanks Meter: 213 | CYCLONE V1.12 Bug on DCT4/WD2 6600 Check Flashing bus Quote:
Unlocking Quote:
But when i tried in CYCLONE v1.12 all Process are Failed i use Tx2 Adaptor and Same cable I think their a bugs in Cyclone v1.12 I hope that Cyclone team fix this in next update BR Ferhel | ||
04-05-2011, 08:53 | #5 (permalink) |
Major Poster Join Date: Nov 2010 Location: chennai
Member: 1432587 Status: Offline Sonork: 1601146 Thanks Meter: 1 | CYCLONE V1.12 Bug on DCT4/WD2 Yes cyclone some bugs on wd2 mobile.i faced problem unlocking nokia 7610.............i request u to plez add wd2 unlock option .thansk in advnce.i hope cyclone team mebers will do this for cyclone customers |
04-08-2011, 19:50 | #12 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | also check this wd2 7610 bus check problem,,loaders , Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.29v PASSED VBAT Voltage 5.02v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V Flash Loading Failed -> Loader is not ready Failed to Check DCT4 Flashing Bus -> Problem with sending Flash Loader now with excuse ,ufs logs with same cable ,same mobile 1st Boot: Ok, WD2, UPP: 1081 [] [2.1.0.1] 2nd Boot: w3_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x01FFFFFF,00ECDDFE,Sam K8S5615ETA Fl1: 0x02000000-0x03FFFFFF,00ECEEFE,Sam K8S5615ETB Fl2: 0x04000000-0x047FFFFF,00EC2250,Sam K8S6415ETB Algorithm: w3_amd_b.fia, Ver: 4.76.0 Rebooting Mobile plz karwos and syroya,,fix this bug,, we hope ,fix will very soon,,,,,,,,,,,,thx |
04-08-2011, 20:14 | #13 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | The first time i bought this cyclone box, the reason, this box is very complete to support nok phone, without using another, this box help much.... So, no other reason, why it is not supported again....... Every update much better than before, not be the worst update.... Btw, waiting for next update br aswancamel |
04-12-2011, 01:53 | #14 (permalink) | |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Dtc4 wd2 Quote:
Hi bro. I agree with you once I bouth cyclone I throw many boxs more than 5 years jaf ufs3 and 8 clone hwk becose cyclone is completly nokia supporter. use another box to flash and unlock dtc4 and wd2 is not an answer and not from you ser MR3 its' not smart solution we are now grow up we are not a childs excuse me ser MR3 I preffer downgrad only for bb5 not for us. So we nned unlock dtc4 wd2 even dtc3 why not!!!! Also I preffer unlock bb5+ by server with imei althow expenseve so as to alive market REGARDS | |
04-15-2011, 01:22 | #15 (permalink) |
Freak Poster Join Date: Jan 2010 Location: philippines Age: 37
Member: 1219937 Status: Offline Thanks Meter: 35 | same here i cannot flash 5300 same error Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm146__07.20.mcusw |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
