Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008
Member: 801055 Status: Offline Thanks: 7
| E-70 RM-10 dead after flash Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:23, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002DB5 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DC0000F8 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,93v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,80v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,85v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,79v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1023.1023MB Avaiable Virtual Memory: 1.713GB Avaiable Pagefile: 1023.1023MB Initializing FBUS... All initialized - Ready to work Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4D3A2D41D952D8276C1178CB709489DB6445527E APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 05600109AD985451E22F01B9F4F7D977C94A4173 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 934BAFC08E9C7E8E99878E3AD8AC3C198071CBB4 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Scanning avaiable products... Processing C:\Program Files (x86)\Nokia\Phoenix\Products\... Processing C:\Program Files (x86)\Common Files\Nokia\DataPackage\Products\... Processing C:\ProgramData\Nokia\Packages\Products\... Found 153 products, Filtering BB5 Products - wait... Failed to Substitue INI Variant Data -> Access violation at address 006A5962 in module 'Cyclone.exe'. Read of address 00000000 79 Products left after filtering. Ready. Retrieving Variants for Product RM-10 - wait... 53 Variants Retrieved Processing pre flash tasks... Read RPL operation not possible for Old USB Flashing Method Pre flash tasks finished, continuing... Processing rm10_m128_h20_kz_prod_306330904_c00_combined.bin (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4D3A2D41D952D8276C1178CB709489DB6445527E APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 05600109AD985451E22F01B9F4F7D977C94A4173 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm10_m128_h20_kz_prod_306330904_c00_combined.bin, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 934BAFC08E9C7E8E99878E3AD8AC3C198071CBB4 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x00530AA9, NOR EraseArea[0,CMT]: 0x006A0000-0x006EFFFF, NOR EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR Waiting 320s for erasure finish... Erase taken 39.608s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT ADL Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Programming Status OK! All blocks written OK! Time taken 31.543s Flashing Speed: 8589,44 kBit/S Restarting MCU... Processing rm10_m128_h20_kz_prod_306330904_c00_combined.bin (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4D3A2D41D952D8276C1178CB709489DB6445527E APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 05600109AD985451E22F01B9F4F7D977C94A4173 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm10_m128_h20_kz_prod_306330904_c00_combined.bin, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1710 UNISTORE-II-1.2.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 934BAFC08E9C7E8E99878E3AD8AC3C198071CBB4 Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5C7C2BDE2E6456F2BD186CE0F16555246134EB8B Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0007FFFF, NAND EraseArea[0,APE]: 0x00080000-0x000803FF, NAND EraseArea[0,APE]: 0x000C0000-0x0377FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.843s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE ADL Certificate... Writing APE SOS+XZIP Certificate... Writing APE PASUBTOC Certificate... Writing APE PAPUBKEYS Certificate... Skipping APE PAPUBKEYS Certificate (already sent)... Writing APE SOS*CORE Certificate... Programming Status OK! All blocks written OK! Time taken 43.119s Flashing Speed: 6283,46 kBit/S Restarting MCU... Processing rm10_m128_h20_kz_prod_306330904_v01_variant.bin (CMT)... Processing rm10_m128_h20_kz_prod_306330904_v01_variant.bin (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100708 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 4D3A2D41D952D8276C1178CB709489DB6445527E APE_ROOT_KEY_HASH: 49A97E826B93BA20B7ED0B082475C00500000000 APE_BOOT_ROM_CRC: 1DFD6613 APE_SECURE_ROM_CRC: 2C872FD4 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 05600109AD985451E22F01B9F4F7D977C94A4173 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm10_m128_h20_kz_prod_306330904_v01_variant.bin, Type: Flash Image, Algo: BB5, OMAP1710 UNISTORE-II-1.2.1 ALG, BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 100Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC2250 (Samsung), Size: 8MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 934BAFC08E9C7E8E99878E3AD8AC3C198071CBB4 Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC00A100800015, Samsung, NAND FlashContent[0,APE]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC00A1 (Samsung), Size: 128MBytes, VPP: 21V h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 5C7C2BDE2E6456F2BD186CE0F16555246134EB8B Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x02180000-0x0377FFFF, NAND Waiting 320s for erasure finish... Erase taken 0.312s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 26.520s Flashing Speed: 4352,05 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 04-06-2012 16:22 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-16-1999 12:20 |
| 5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 07-07-1999 12:27 |
| Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 06-25-1999 08:21 |
