07-03-2011, 06:00 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Stop WAR on GSM Business
Member: 328416 Status: Offline Thanks Meter: 42 | E5 Contact Retailer........ solution please Code: Started Phone Security Analysis... MCU Version V ICPR82_11w16.3 MCU Date 19-05-11 Product RM-632 (Nokia E5-00) Manufacturer (c) Nokia IMEI 35485xxxxxxxxxxxx Mastercode 213541433 Reading Security Block... Security block OK and saved to "RM-632_354859xxxxxxxxx714_03072011_010200 م.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SIMLOCK PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. -- SIMLOCK PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block WARNING: "24E00016EBA403443E62EB6F0C53302177ED581B.C0002504" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 24E00016EBA403443E62EB6F0C53302177ED581B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! New_RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.02 (C) 2011 Karwos Labs Custom loader running OK! Working... Readed OK, Saving to "24E00016EBA403443E62EB6F0C53302177ED581B.C0002504" Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! |
07-03-2011, 06:59 | #3 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Manila,Philippines
Member: 1536588 Status: Offline Sonork: 100.1613366 Thanks Meter: 480 | Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. if fails RPL only solution.... |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
