Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 08-08-2012, 13:23   #1 (permalink)
Member: 1361078
e52 after flash dead
before flash only vibrate but after flash totaly dead plz help me how to solve
here is log
Card Serial Number: D0060131
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.91v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.88v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.86v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.636GB
Avaiable Virtual Memory: 1.900GB
Avaiable Pagefile: 3.617GB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm469_091.004_prd.core.fpsx (CMT)...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Failed to Boot CMT -> Failed to get First Boot Block
Processing Flash Image Failed -> Failed to Boot CMT
Failed to Process all Image files -> Failed to process rm469_091.004_prd.core.fpsx
Booting CMT...
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104
CMT_EM_ASIC_ID: 00001040
CMT_EM_ASIC_ID: 00001030
CMT_PUBLIC_ID: 17F0011171400E49CFFD02046762A8968E4B9A5C
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT_BOOT_ROM_CRC: 3E273BF6
CMT_SECURE_ROM_CRC: 37BE26FA
CMT Ready!
rm469_091.004_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020004000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020004000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200040 (ST), Size: 256MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 85F252E351E225CAFC4DFBC8041EABD2823E3500
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0B13FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.766s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 28.47s
Flashing Speed: 31088.89 kBit/S
Processing rm469_091.004_prd.core.fpsx (APE)...
Processing rm469_091.004_21.01_Taiwan_prd.rofs2.fpsx (CMT)...
rm469_091.004_21.01_Taiwan_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x07300000-0x09CFFFFF, ONENAND
Erase taken 0.203s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 10.703s
Flashing Speed: 31725.91 kBit/S
Processing rm469_091.004_21.01_Taiwan_prd.rofs2.fpsx (APE)...
Processing rm469_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
rm469_091.004_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x09D00000-0x0B13FFFF, ONENAND
Erase taken 0.109s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 2.266s
Flashing Speed: 31203.06 kBit/S
Processing rm469_091.004_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm469_091.004_U002.000_prd.uda.fpsx (CMT)...
rm469_091.004_U002.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x0B140000-0x0F27FFFF, ONENAND
Erase taken 0.297s
TurboCache Loaded!
All blocks written OK! Time taken 2.625s
Flashing Speed: 32034.79 kBit/S
Processing rm469_091.004_U002.000_prd.uda.fpsx (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Old 08-08-2012, 16:57   #2 (permalink)
Member: 1361078
still no answer after a long time where r u mr moulinsky plz help me i m waiting of your answer
Old 08-08-2012, 19:43   #3 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Sonork: 100.1624864
did you try to flash ENO firmware on that phone then you full flash it with version above you already flashed it!!!
Old 08-09-2012, 10:58   #4 (permalink)
Member: 1361078
yes i do but the problem still same
Old 08-09-2012, 20:23   #5 (permalink)
Member: 1361078
i send u the teamviwer data
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-07-2000 21:24
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.41958 seconds with 11 queries
