Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-11-2009, 03:14   #1 (permalink)
DaWizard's Avatar
Member: 61557
Exclamation E65 After write Full PM Contact Retailer How to Fix
@nadeem my friend
How can i fix my problem, i write a Full PM to my E65 and it went to Contact Retailer. 1st the problem is when i turn on the phone only nokia but with out sim card its ok, i try to write pm and it went to Contact Retailer, how can i restore it back to normal?
Thanks in advance
The Following User Says Thank You to DaWizard For This Useful Post:
Old 06-11-2009, 04:09   #2 (permalink)
tropa_pipz01's Avatar
Member: 84972
do you have back up of your pm????? try to put it back
Old 06-11-2009, 04:36   #3 (permalink)
Member: 710668
Originally Posted by DaWizard View Post
@nadeem my friend
Thanks in advance
maybe it over write your original PM DATA...
u must restore it back...
to be safe, make a "SELF TEST"..
then post your logs...
Old 06-11-2009, 05:10   #4 (permalink)
Member: 996684
did u write PM without 120 & 308 field or full PM from another phone?
Old 06-11-2009, 05:51   #5 (permalink)
DaWizard's Avatar
Member: 61557
Yup it's modified PM but still contact retailer, but i will restore the RPL file i backup and i will post the logs here, i try to use selftest and st security is the error, you think guys i can restore it back using the RPL i've backup?
Old 06-11-2009, 05:59   #6 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
just write this pm file and post the results.
Old 06-11-2009, 06:08   #7 (permalink)
Member: 996684
if u have rpl backup then restore it. hope so it will solve ur problem
Old 06-11-2009, 07:50   #8 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
post here phone self test after writing PM
Old 06-11-2009, 10:40   #9 (permalink)
DaWizard's Avatar
Member: 61557
ok man copy i will do post the result here
Old 06-11-2009, 19:06   #10 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
The phone was already on nokia logo..
Normally this happens after a wrong upgrade/downgrade of the phone.
Make the self-test of the mobile and check what is wrong.. look at the infos as well.
If everything looks OK then go on with the full job.
Make all the back-ups you can then full erase, emo, flash, rpl, sx4, full PM no 308.. if it keeps being in CS then you need to buy RPL.
Alex
Old 06-12-2009, 12:34   #11 (permalink)
DaWizard's Avatar
Member: 61557
Alex
Man,
How can i full erase? Procedure please
What do you mean by EMO?
Old 06-12-2009, 13:01   #12 (permalink)
Aishur's Avatar
Member: 28188
ENO not EMO is a special firmware with the lowest version, it does not start the phone and it is just for the preparation.
Post the selftest as required above
Old 07-04-2009, 05:38   #13 (permalink)
Member: 174457
I have exact Prblm. on E65 Ver. V 1.0615.25. APE s/w. not matched with MCU s/w.
I try different versions ,I think onyway is to go back to Previous Ver.
nokia 5300 after writing full pm contact service achintya Nokia Base Band 5 ( BB-5 ) 2 11-07-2009 14:11
6300 After Write PM Contact Service how to restore back- SOLVED DaWizard Cyclonebox 6 07-30-2009 05:14
problem after unlocking 6630 contacted reseller how to fix i have pm and rpl files majestic36 Nokia Base Band 5 ( BB-5 ) 8 03-21-2009 22:01
after writing rpl, still contact retailer unlock expert tech allGSMunlock MultiOnline Remote Server 3 07-09-2008 18:33
<<< After Write Bb5 Rpl, **contact Retailer** >>> VsH-GsM MT-BOX 18 02-24-2007 15:19
Page generated in 0.51179 seconds with 12 queries
