03-07-2010, 12:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Saudi Arabia
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | E65 only blue display ......?need pp file for e65 [ Solved ] Last edited by ptt; 03-12-2010 at 02:37. |
The Following User Says Thank You to alavukt For This Useful Post: |
03-09-2010, 07:11 | #4 (permalink) |
Freak Poster Join Date: May 2006 Location: Romania
Member: 271484 Status: Offline Thanks Meter: 33 | Cyclone team don't change flex,ic,lcd.......if is hang on bluescreen ,must be flash with "eno" file from support!But before just verified those components.Have nice day! |
The Following User Says Thank You to neo25_gsm For This Useful Post: |
03-09-2010, 12:22 | #5 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | Hi frds i check the lcd,ic,flex all ok yes this hang with blue screen.i need this file "eno" i hope problem solve flash with this file........................? |
03-09-2010, 17:21 | #6 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | cyclone team plssssssssssssss help me.e65 blue display only.................very urgent |
03-09-2010, 17:28 | #7 (permalink) |
No Life Poster Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711 Status: Offline Sonork: 100.1597405 Thanks Meter: 1,779 | here blank e65 ppm:GSMSandwich © |
The Following User Says Thank You to MARVZ_TG For This Useful Post: |
03-10-2010, 07:11 | #8 (permalink) |
Member: 271484 Status: Offline Thanks Meter: 33 | http://forum.gsmhosting.com/vbb/f299...-nokia-683410/ flash only that file as "pmm" and then full flash with latest version,must works!(i mention for me is tested with JAF).Good luck. |
03-10-2010, 19:33 | #9 (permalink) |
Member: 784971 Status: Offline Sonork: tech4ksa Thanks Meter: 23 | thx all need anther help this mobile. now smps short need jumper solution (remove smps).......anybody hav pls post her |
03-11-2010, 21:14 | #12 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | the better way to thanks,,,,click thanks button,plzzzzzzzzzzz |
The Following User Says Thank You to alkhaleejmobile For This Useful Post: |
i need PP file for nokia 1110i rh-93 made in india | hafidi2007 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 07-13-2013 14:42 |
e66 call in out ok but only blue display need help | /\/\A/\/| | Nokia Hardware & Hardware Repair | 7 | 03-29-2010 22:04 |
E65 only blue screen | Mounir | Nokia Hardware & Hardware Repair | 0 | 03-18-2009 13:44 |
need flash file for e65-1 rm-208... 3.0615.3 31-01-08 | CHAPRAN | Nokia Hardware & Hardware Repair | 3 | 06-21-2008 11:45 |
7250i no graphic 0n display only blue display | pratik_1111 | Nokia Hardware & Hardware Repair | 2 | 10-22-2007 21:41 |
