Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2008
Member: 888715 Status: Offline Thanks: 165
| e71 unlock problem Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.04, (Jun 10 2012 18:37:23, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: Card Firmware Revision: Card is activated Box is activated Started box selftests procedure USB Voltage 4,90v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,75v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 98 Avaiable Physical Memory: 148.860MB Avaiable Virtual Memory: 1.912GB Avaiable Pagefile: 880.232MB Initializing FBUS... All initialized - Ready to work BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... MCU Version V ICPR71_09w22.9 MCU Date 16-10-09 Product RM-346 (Nokia E71) Manufacturer (c) Nokia IMEI 359357038640117 Mastercode 3645544732 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 64710F Reading Security Block... Security block OK and saved to "RM-346_359357038640117_17.7.2012_134621.SecurityBlock .PM" WARNING: "19300106A89400525CAA191B8C9F28A8FBC76DDA.C0002152 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19300106A89400525CAA191B8C9F28A8FBC76DDA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Prepare phone failed with message -> Failed to get CMT Configuration Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone) BB5 Unlock Failed -> Failed to obtain Phone Unique Data BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) BB5 Unlock Started... MCU Version V ICPR71_09w22.9 MCU Date 16-10-09 Product RM-346 (Nokia E71) Manufacturer (c) Nokia IMEI 359357038640117 Mastercode 3645544732 Simlock Server SIMLOCK SERVER Simlock Key 2081000000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 20810F Simlock [3,1] State: CLOSED Type: MCC-MNC Data: 64710F Simlock [4,1] State: CLOSED Type: MCC-MNC Data: 64710F Reading Security Block... Security block OK and saved to "RM-346_359357038640117_17.7.2012_135058.SecurityBlock .PM" Determining PA Simlock... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19300106A89400525CAA191B8C9F28A8FBC76DDA CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. CBUS Request Error -> CBUS Response wrong header Prepare phone failed with message -> Failed to get CMT Configuration BB5 Unlock Failed -> Failed to Boot / Prepare Phone |
| | #2 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2005 Location: TUNISIA
Member: 190067 Status: Offline Thanks: 270
| Quote:
i think you can take you time to read this All Supported models for the unlock - Updated [ 25 JUNE 2012 ] | |
| | #4 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,689
| you can read the hash easily via usb following the instructions about removing battery and go on: looks like the fbus cable you are using is too long BR Alex |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks: 421
| When you have a new phone and donīt know what security it is, just try rpl unlock method, if phone is sl2 surely will be unlocked, and if is sl3 there will be an error and phone will not be unlocked, this method is safe and secure to do. Try it !!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| $50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 07-09-1999 22:08 |
