02-25-2010, 18:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | E71X startup faild ,please help i have tried to change e71x to rm-346 e71 phone imei 1234567..... anyhow , i have downgrade it back to its original frimware , wrote rpl and original backedup pm and phone now imei fixed . thought it still give me contact retailer. when trying to write back pm again , after sx4 it say faild write 309 adress Write PM Finished, Record written OK: 199, Record written NOT OK: 33 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 i have full backedup pm 0-512 have backedup - create rpl from phone. and backedup - read all certs. please anyone can help me fix this prob thx |
02-25-2010, 18:30 | #2 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 IMEI Spare 3A65780502146305 IMEI SV 3365780502146325F4000000 PSN MCG394855 Product Code 0564434 Module Code 0203918 Basic Product Code 0564435 PSD 0000000000000000 LPSN 0 WLAN MAC 002548BD9758 RETU 15 TAHVO 22 AHNE 11 HW 1001 RFIC 17141715 DSP MPD_pb71_08w35.00_rm324 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Selftests to proceed: 25 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_SLEEPCLK_FREQ_TEST Failed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_EXT_DEVICE_TEST Failed ST_CDSP_RF_BB_IF_TEST Failed ST_CDSP_RF_SUPPLY_TEST Failed ST_CDSP_TX_IQ_TEST Failed ST_CDSP_TXC_DATA_TEST Failed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_WCDMA_TX_POWER_TEST Failed ST_CDSP_RX_IQ_LOOP_BACK_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 25, Tests passed: 13, Tests not passed: 12 |
02-25-2010, 18:47 | #3 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | Started Phone Security Analysis... MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 Reading Security Block... Security block OK and saved to "RM-462_356875020413659_25022010_193955.SecurityBlock. PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "0D600107A07900524A45C72AD437BBC395E240F3.C0000D65 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! SX4 Authorization / SD Repair Procedure Started.... "0D600107A07900524A45C72AD437BBC395E240F3.C0000D65 " Exists, That is good... MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 Reading Security Block... Security block OK and saved to "RM-462_356875020413659_25022010_194624.SecurityBlock. PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! WRITE NOW VIRGIN SX4 PM which CONTAINS PM FIELDS 1 and 309! [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,25] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 80 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 0, Record written NOT OK: 33 |
02-25-2010, 19:10 | #5 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | d/l other pm from here http://forum.gsmhosting.com/vbb/show...00&postcount=5 same problem Code: SX4 Authorization / SD Repair Procedure Started.... "0D600107A07900524A45C72AD437BBC395E240F3.C0000D65" Exists, That is good... MCU Version V 08w35.03.26 MCU Date 04-03-09 Product RM-462 Manufacturer (c) Nokia IMEI 356875020413659 Mastercode 3151516342 Reading Security Block... Security block OK and saved to "RM-462_356875020413659_25022010_200726.SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! WRITE NOW VIRGIN SX4 PM which CONTAINS PM FIELDS 1 and 309! [1,0] Written, Length: 114 bytes, Status: Not accepted, Code: 19 [1,2] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,6] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,8] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,13] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,16] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,18] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,20] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,24] Written, Length: 84 bytes, Status: Not accepted, Code: 19 [1,25] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,26] Written, Length: 110 bytes, Status: Not accepted, Code: 19 [1,28] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,29] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [1,31] Written, Length: 98 bytes, Status: Not accepted, Code: 19 [1,34] Written, Length: 80 bytes, Status: Not accepted, Code: 19 [1,35] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,37] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,40] Written, Length: 16 bytes, Status: Not accepted, Code: 19 [1,41] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 19 [2,0] Written, Length: 452 bytes, Status: OK [4,1] Written, Length: 80 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,26] Written, Length: 132 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 12 bytes, Status: OK [8,1] Written, Length: 12 bytes, Status: OK [8,2] Written, Length: 128 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,6] Written, Length: 4 bytes, Status: OK [8,7] Written, Length: 8 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 16 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 1 bytes, Status: OK [11,7] Written, Length: 2 bytes, Status: OK [11,8] Written, Length: 2 bytes, Status: OK [11,9] Written, Length: 2 bytes, Status: OK [11,10] Written, Length: 2 bytes, Status: OK [11,11] Written, Length: 2 bytes, Status: OK [11,12] Written, Length: 1 bytes, Status: OK [11,13] Written, Length: 1 bytes, Status: OK [11,14] Written, Length: 1 bytes, Status: OK [11,15] Written, Length: 1 bytes, Status: OK [11,16] Written, Length: 1 bytes, Status: OK [11,17] Written, Length: 1 bytes, Status: OK [11,18] Written, Length: 1 bytes, Status: OK [11,19] Written, Length: 2 bytes, Status: OK [11,20] Written, Length: 2 bytes, Status: OK [11,21] Written, Length: 1 bytes, Status: OK [11,22] Written, Length: 1 bytes, Status: OK [11,23] Written, Length: 4 bytes, Status: OK [11,24] Written, Length: 4 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 1 bytes, Status: OK [11,30] Written, Length: 1 bytes, Status: OK [11,31] Written, Length: 1 bytes, Status: OK [11,32] Written, Length: 1 bytes, Status: OK [11,33] Written, Length: 1 bytes, Status: OK [11,34] Written, Length: 1 bytes, Status: OK [11,35] Written, Length: 1 bytes, Status: OK [11,36] Written, Length: 1 bytes, Status: OK [11,37] Written, Length: 1 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 4 bytes, Status: OK [11,44] Written, Length: 4 bytes, Status: OK [11,45] Written, Length: 4 bytes, Status: OK [11,46] Written, Length: 1 bytes, Status: OK [11,47] Written, Length: 16 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 20 bytes, Status: OK [11,51] Written, Length: 10 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 20 bytes, Status: OK [11,54] Written, Length: 10 bytes, Status: OK [11,55] Written, Length: 1 bytes, Status: OK [11,56] Written, Length: 1 bytes, Status: OK [11,57] Written, Length: 1 bytes, Status: OK [11,58] Written, Length: 1 bytes, Status: OK [11,59] Written, Length: 1 bytes, Status: OK [11,60] Written, Length: 1 bytes, Status: OK [11,61] Written, Length: 1 bytes, Status: OK [11,62] Written, Length: 1 bytes, Status: OK [11,63] Written, Length: 1 bytes, Status: OK [11,64] Written, Length: 1 bytes, Status: OK [11,65] Written, Length: 1 bytes, Status: OK [11,66] Written, Length: 32 bytes, Status: OK [11,67] Written, Length: 32 bytes, Status: OK [11,68] Written, Length: 2 bytes, Status: OK [11,69] Written, Length: 2 bytes, Status: OK [11,70] Written, Length: 2 bytes, Status: OK [11,71] Written, Length: 2 bytes, Status: OK [11,72] Written, Length: 2 bytes, Status: OK [11,73] Written, Length: 2 bytes, Status: OK [11,74] Written, Length: 2 bytes, Status: OK [11,75] Written, Length: 2 bytes, Status: OK [11,76] Written, Length: 2 bytes, Status: OK [11,77] Written, Length: 2 bytes, Status: OK [11,78] Written, Length: 2 bytes, Status: OK [11,79] Written, Length: 2 bytes, Status: OK [11,80] Written, Length: 2 bytes, Status: OK [11,81] Written, Length: 2 bytes, Status: OK [11,82] Written, Length: 2 bytes, Status: OK [11,83] Written, Length: 2 bytes, Status: OK [11,84] Written, Length: 2 bytes, Status: OK [11,85] Written, Length: 2 bytes, Status: OK [11,86] Written, Length: 2 bytes, Status: OK [11,87] Written, Length: 2 bytes, Status: OK [11,88] Written, Length: 2 bytes, Status: OK [11,89] Written, Length: 2 bytes, Status: OK [11,90] Written, Length: 2 bytes, Status: OK [11,91] Written, Length: 2 bytes, Status: OK [11,92] Written, Length: 2 bytes, Status: OK [11,93] Written, Length: 2 bytes, Status: OK [11,94] Written, Length: 2 bytes, Status: OK [11,95] Written, Length: 2 bytes, Status: OK [11,96] Written, Length: 2 bytes, Status: OK [11,97] Written, Length: 2 bytes, Status: OK [11,98] Written, Length: 2 bytes, Status: OK [11,99] Written, Length: 2 bytes, Status: OK [11,100] Written, Length: 2 bytes, Status: OK [11,101] Written, Length: 2 bytes, Status: OK [11,102] Written, Length: 2 bytes, Status: OK [11,103] Written, Length: 2 bytes, Status: OK [11,104] Written, Length: 2 bytes, Status: OK [11,105] Written, Length: 2 bytes, Status: OK [11,106] Written, Length: 2 bytes, Status: OK [11,107] Written, Length: 2 bytes, Status: OK [11,108] Written, Length: 2 bytes, Status: OK [11,109] Written, Length: 2 bytes, Status: OK [11,110] Written, Length: 2 bytes, Status: OK [11,111] Written, Length: 2 bytes, Status: OK [11,112] Written, Length: 2 bytes, Status: OK [11,113] Written, Length: 2 bytes, Status: OK [11,114] Written, Length: 2 bytes, Status: OK [11,115] Written, Length: 2 bytes, Status: OK [11,116] Written, Length: 4 bytes, Status: OK [11,117] Written, Length: 4 bytes, Status: OK [11,118] Written, Length: 1 bytes, Status: OK [11,119] Written, Length: 4 bytes, Status: OK [11,120] Written, Length: 4 bytes, Status: OK [11,121] Written, Length: 4 bytes, Status: OK [11,122] Written, Length: 4 bytes, Status: OK [11,123] Written, Length: 16 bytes, Status: OK [11,124] Written, Length: 4 bytes, Status: OK [11,125] Written, Length: 2 bytes, Status: OK [11,126] Written, Length: 2 bytes, Status: OK [11,127] Written, Length: 1436 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [31,4] Written, Length: 26 bytes, Status: OK [44,0] Written, Length: 1 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [96,0] Written, Length: 24 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 79 bytes, Status: OK [107,2] Written, Length: 79 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [107,26] Written, Length: 12 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,8] Written, Length: 104 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [208,1] Written, Length: 4 bytes, Status: OK [217,0] Written, Length: 32 bytes, Status: OK [291,0] Written, Length: 92 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 19 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,5] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [309,22] Written, Length: 12 bytes, Status: Not accepted, Code: 19 [313,0] Written, Length: 615 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [329,0] Written, Length: 8392 bytes, Status: OK [334,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4514 bytes, Status: OK [354,0] Written, Length: 13 bytes, Status: OK [355,0] Written, Length: 7335 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK Write PM Finished, Record written OK: 178, Record written NOT OK: 33 Last edited by acyl2000; 02-26-2010 at 07:04. Reason: wrap message |
02-26-2010, 07:08 | #7 (permalink) |
No Life Poster Join Date: May 2009 Location: destination SL3 brute force
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | try full erase your phone then flash to eno files.. flash to original product code firmware e71x write 1-309 pm.. heres the files http://www.4shared.com/file/13617649...1x-RM-462.html eno files: http://forum.gsmhosting.com/vbb/showthread.php?t=914516 |
02-26-2010, 07:33 | #8 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
and about eno file , i cant find for this rm-462 can i use other e71 eno file ? btw even phone start to startup failed , its not going into test/local mode , just flashing white. when it was on rm-346 it did went to local mode. | |
02-26-2010, 07:43 | #9 (permalink) | |
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | Quote:
do you have original flash file rm462? | |
02-26-2010, 07:56 | #10 (permalink) | |
i have full backup of pm before changed version 0-512 also have backup rpl and also have backup all certs i wonder what are the certs i backedup and how can they help ? i will d/l any e71 eno file about earase file i cant find a correct file for it can you help me with it thx | |
02-26-2010, 08:05 | #11 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 58
Member: 947561 Status: Offline Thanks Meter: 14,052 | If you have another E71X (I don't have any back-ups of this model) rpl back-up, please post it here and may be you won't need to erase the phone BR Alex |
02-26-2010, 08:08 | #12 (permalink) |
Member: 1021855 Status: Offline Sonork: BLACKBERRY INSIDE Thanks Meter: 600 | donwload here: http://forum.gsmhosting.com/vbb/show...6&postcount=44 |
02-26-2010, 08:16 | #13 (permalink) | |
when phone came here it was 100% working , i tried changing software to 346 to get other lang in it. here are the backups please try and help me what to do with how to thx | |
02-26-2010, 08:20 | #14 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IT POINT Ankleshwar
Member: 756719 Status: Offline Thanks Meter: 80 | Quote:
i did it before...just hit the tnx button | |
The Following 2 Users Say Thank You to jasperali For This Useful Post: |
02-26-2010, 08:27 | #15 (permalink) | |
i posted all logs all security checks all rpl write pm write sef tests ... if i knew whats wrong i wouldnt post ask for help .... i did all i found on forum before posting i called my frineds ask for help before posting .... work on this phone few hours before posting so regular format is not helping. also phone not going to test/local mode even if its turned on and say cotact retailer. | |
Nokia N70 Startup failed please help | mansoorat | Nokia Hardware & Hardware Repair | 4 | 10-17-2009 23:17 |
3110c flash faild please help me..... | ..::jothikrish::.. | Nokia Base Band 5 ( BB-5 ) | 6 | 07-06-2008 10:23 |
L7 mp3 playback faild please help me | sajithcellular | Motorola Hardware Repair | 0 | 10-09-2007 09:54 |
N80 Flashing Succesfull But Startup Failed !!! Please Help | browny2k4 | Nokia Base Band 5 ( BB-5 ) | 2 | 10-17-2006 08:02 |
