Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() Join Date: May 2008
Member: 764475 Status: Offline Sonork: 100.1574238 Thanks: 368
| e72 after write rpl Failed to read SP info Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Simlock... Handling as SL3 Simlock Data Handling as SIMLOCK2 Format Reading Security Block... Security block OK and saved to "RM-530_351513048761164_12072012_230219.SecurityBlock. PM" 15 Digits NCK Found Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key NOT ACCEPTED ! Writing WMDRM PD Data... WMDRM PD Data NOT ACCEPTED ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 23F0000B83790344F2D8EA90101C46D4821B2298 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0058 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! MCU Version V ICPR82_11w16.3.4 MCU Date 17-08-11 Product RM-530 (Nokia E72) Manufacturer (c) Nokia IMEI 351513048761164 Mastercode 113514627 IMEI Spare 3A15150384671106 IMEI SV 3315150384671166F0000000 PSN 0 PSD 0000000000000000 LPSN 0 WLAN MAC D8753354C6BA APE SW 081.003 APE Variant 081.003081.003.36.01081.003.C00.01 APE Test v0.a038 APE HW 256 APE ADSP 256 RETU 40 TAHVO 00 AHNE 11 RFIC |Vapaus_5.1 | Aura_?.? DSP ICPR82_11w16 Failed to read info -> Failed to read SP info |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Tirana-Karachi-Instanbul Age: 36
Member: 388033 Status: Offline Sonork: 100.1624864 Thanks: 971
| write the full PM that you Back Up before erasing flash using SX 4 then all will be okay!!! |
| | #3 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: ( Protected ) Thanks: 247
| Just power on the phone with sim and check... If fail just full erase the phone flash according product And restore rpl |
| | #5 (permalink) |
| IMEI: 351513048761164 Simlock send - SUCCESSFULL!!! SuperDongle send - SUCCESSFULL!!! CMLA send - SUCCESSFULL!!! WMDRM PD send - SUCCESSFULL!!! V ICPR82_11w16.3.4/17-08-11/RM-530 (c) Nokia IMEI: 351513048761164 Operator: 2440700000000000 Operator Name: AT&T;U.S.A. (3650) Profile bits: 0000000000000000 Sim Status: Not locked SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! |
| | #6 (permalink) |
| Started Phone Security Analysis... MCU Version V ICPR82_11w16.3.4 MCU Date 17-08-11 Product RM-530 (Nokia E72) Manufacturer (c) Nokia IMEI 351513048761164 Mastercode 113514627 Reading Security Block... Security block OK and saved to "RM-530_351513048761164_14072012_211040.SecurityBlock. PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- |
| | #9 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2003 Location: Tirana, ALBANIA Age: 32
Member: 44223 Status: Offline Thanks: 184
| same situation here i dont have PM backup before i just buy new RPL after i write it ..Failed to read SP info. how to solve this without backup of pm and certs ....??? thanks |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 12-10-2012 04:46 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 11 | 06-26-1999 06:22 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
