02-23-2010, 11:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 400705 Status: Offline Thanks Meter: 31 | E72 flashing failed Processing Flash Image Failed -> RAP Not Responding Failed to Process all Image files -> Failed to process rm530_022.007_prd.core.fpsx My cables are brand new, use them every day (and a lot), tx adapter's also fine, pins set properly.. Usb flashing fails either with: Failed to prepare BB5 USB Connection -> Failed to initalize CMT ADL preloader Failed to Process all Image files -> Failed to prepare BB5 USB Flashing Flashed with JAF - everything is 100%.. Is there a problem with flashing E72 with cyclone in general? |
02-25-2010, 15:26 | #2 (permalink) |
Member: 400705 Status: Offline Thanks Meter: 31 | Moulnisky, SiRoYa, Honey, anyone!!!!! do you guys care to respond? I've got 5 e72 phones here - all of them fail to flash with the same errors!!!! Either usb or fbus.. Can i get some help here? |
02-25-2010, 22:04 | #6 (permalink) |
Member: 400705 Status: Offline Thanks Meter: 31 | i've tried to flash it with usb - it failed with: failed to prepare BB5 USB Connection -> Failed to initalize CMT ADL preloader Failed to Process all Image files -> Failed to prepare BB5 USB Flashing i've tried to flash it with dead usb - it fails to boot RAP i've tried to flash it with fbus without tx2 adapter, "tx2" unchecked - failed with: processing Flash Image Failed -> RAP Not Responding Failed to Process all Image files -> Failed to process rm530_022.007_prd.core.fpsx tried with tx2 adapter, pin10 - same thing. Though it started flashing on pin3 the procedure failed after erasing certs, while loading cmt, now the phone's dead. I have 5 pieces here - all of them gave me the same result (i didn't push it - one dead phone is more than enough for me). I've also tried to reinstall cyclone - didn't help either.. Any thoughts? |
02-26-2010, 04:04 | #7 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: my dream
Member: 664744 Status: Offline Thanks Meter: 156 | Quote:
Code: Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm530_023.002_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: FCA70C RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 0B900104E96C0344E13DAB8C8747CDDFB980D1BA RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0058 - 0000 0121 [Samsung ] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: FCA70C [ADL] Verifying communication to device OK. RAP PAPUBKEYS is blank/erased. Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: 660D81A4455F6F7F9B81D5D10F5336B14B50635E (RAP Certificate 175 v.1) written. Programming completed in 28.203 s Processing file: rm530_023.002_40.02_APAC_QW1_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 61.13 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 75.50 MB Flash programming ... Programming completed in 17.140 s Processing file: rm530_023.002_C00.01_DEFAULT_prd.rofs3.fpsx as PPM [BB5,XSR 1.6] size: 7.55 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 25.75 MB Flash programming ... Programming completed in 2.078 s Processing file: rm530_023.002_U000.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 4.65 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 265.75 MB Flash programming ... Programming completed in 3.157 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia USB Generic, ID: 1D3DA8BA [ADL] Verifying communication to device OK. Flashing completed in 1 min 44.687 s Phone Type: RM-530 (Nokia E72-1) SW Version: V ICPR82_09w46.5 22-01-10 RM-530 (c) Nokia Imei plain: 35523903592301-5 Product Code: 0586210 ApeCoreSw: 023.002 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355239035923015 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 1 min 45.953 s | |
02-26-2010, 12:54 | #8 (permalink) |
No Life Poster Join Date: May 2004 Age: 54
Member: 66136 Status: Offline Thanks Meter: 200 | I have many cars for my work, and with the car number 1 I can't take some goods, and don't workd good, but I can use an other car for this goods, so I go to the reseller of my car number 1 and tell him : what is this bad car the reply of this suplier is verry easy : if you don't like my car don't use it, and how many money you win with my car and my reply for this suplier is : sorry best Regards, JAVA Good. |
02-26-2010, 18:40 | #9 (permalink) |
No Life Poster Join Date: Oct 2002 Age: 39
Member: 16107 Status: Offline Sonork: 100.58402 Thanks Meter: 26,411 | E52 , E72 , X3 etc have new loaders which are not supported by cyclonebox wait for new update ! wbr SiRoYa |
The Following 3 Users Say Thank You to SiRoYa For This Useful Post: |
E72 Flash Err Please Help Me | SYRYA TEL | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-17-2010 07:52 |
E72 Flash on USB but failed in FBUS! | yobb | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-15-2010 12:56 |
E72 Flash Error | gazsy | Genie Universal | 1 | 01-13-2010 14:10 |
nokia E72 flashing supported? | Rashky | Universalbox | 3 | 11-26-2009 13:48 |
Benq e72 Flashing ROM & More general help | djkee | HTC & Smartphones ( WM Without Touch) | 0 | 01-15-2009 07:02 |
