04-09-2010, 07:59 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: GSMHOSTING
Member: 444451 Status: Offline Sonork: 100.1593581 Thanks Meter: 29 | E72 flashing help [ Solved ] Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.30, (Apr 5 2010 02:12:53, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk13 Box Serial Number: C00xxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D2000617 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.91v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.76v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.81v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 137 products, Filtering BB5 Products - wait... 91 Products left after filtering. Ready. Retrieving Variants for Product RM-530 - wait... 42 Variants Retrieved Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPUv11_algo_xsr16.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.6 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Testing TX2 Line... TX2 Line OK! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm530_023.002_prd.core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPUv11_algo_xsr16.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.6 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Skipping erase on user request Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... CBUS Request Error -> CBUS Response wrong header Block Write Failed -> Failed to write data data (1) Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm530_023.002_prd.core.fpsx Last edited by ptt; 04-10-2010 at 11:46. Reason: add code tag |
04-09-2010, 08:33 | #3 (permalink) |
Member: 444451 Status: Offline Sonork: 100.1593581 Thanks Meter: 29 | NO Sir Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.30, (Apr 5 2010 02:12:53, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk13 Box Serial Number: C000xxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D2000617 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.84v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.76v PASSED VBAT Voltage 1.41v PASSED VBAT Voltage 4.86v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.77v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 137 products, Filtering BB5 Products - wait... 91 Products left after filtering. Ready. Retrieving Variants for Product RM-530 - wait... 42 Variants Retrieved Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA Prepare phone failed with message -> Not found required CMT Secondary Loader Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA Prepare phone failed with message -> Not found required CMT Secondary Loader Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAPUv11_algo_xsr16.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.6 Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Testing TX2 Line... TX2 Line OK! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm530_023.002_prd.core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Processing Flash Image Failed -> Not found required Secondary Loader Failed to Process all Image files -> Failed to process rm530_023.002_prd.core.fpsx Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm530_023.002_prd.core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Processing Flash Image Failed -> Not found required Secondary Loader Failed to Process all Image files -> Failed to process rm530_023.002_prd.core.fpsx Last edited by ptt; 04-10-2010 at 11:45. Reason: add code tag |
04-09-2010, 09:14 | #4 (permalink) |
Member: 444451 Status: Offline Sonork: 100.1593581 Thanks Meter: 29 | Untick TX2 can"t chack flashing bug Tick TX2 flash same product code.Show this error Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND EraseArea[0,CMT]: 0x008E0000-0x0E77FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.203s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm530_023.002_prd.core.fpsx |
04-09-2010, 09:48 | #6 (permalink) |
Member: 444451 Status: Offline Sonork: 100.1593581 Thanks Meter: 29 | THANKS moulnisky and CYCLONE TEAM Success E72 flashing Very fast care on customer Code: Started box selftests procedure USB Voltage 4.91v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.77v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 137 products, Filtering BB5 Products - wait... 91 Products left after filtering. Ready. Retrieving Variants for Product RM-530 - wait... 42 Variants Retrieved Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.9.50.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.9.50.0, Algo: XSR 1.6 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Failed to Create RPL from phone -> Phone not detected RPL backup thread finished, continuing... Backing up simlock... Simlock backup problem -> Phone not detected Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm530_023.002_prd.core.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.9.50.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.9.50.0, Algo: XSR 1.6 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND EraseArea[0,CMT]: 0x008E0000-0x0E77FFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 1.203s Writing all blocks... Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 113.953s Flashing Speed: 7100.35 kBit/S Restarting MCU... Processing rm530_023.002_prd.core.fpsx (APE)... Processing rm530_023.002_41.02_APAC_QW2_prd.rofs2.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_41.02_APAC_QW2_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.9.50.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.9.50.0, Algo: XSR 1.6 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x08240000-0x0CDBFFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.406s Writing all blocks... Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 59.968s Flashing Speed: 7171.73 kBit/S Restarting MCU... Processing rm530_023.002_41.02_APAC_QW2_prd.rofs2.fpsx (APE)... Processing rm530_023.002_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.9.50.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.9.50.0, Algo: XSR 1.6 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0CDC0000-0x0E77FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.157s Writing all blocks... Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 8.891s Flashing Speed: 7126.00 kBit/S Restarting MCU... Processing rm530_023.002_C00.01_DEFAULT_prd.rofs3.fpsx (APE)... Processing rm530_023.002_U000.000_prd.uda.fpsx (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102011104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 19700111F95E03446408D9071DA25585767E4A3E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT_BOOT_ROM_CRC: 3E273BF6 CMT_SECURE_ROM_CRC: 37BE26FA rm530_023.002_U000.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.9.50.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005800000121, Samsung, ONENAND RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.9.50.0, Algo: XSR 1.6 Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0E780000-0x1F13FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 1.360s Writing all blocks... Programming Status OK! All blocks written OK! Time taken 7.437s Flashing Speed: 5248.27 kBit/S Restarting MCU... Processing rm530_023.002_U000.000_prd.uda.fpsx (APE)... All images processed OK! Processing post flash tasks... Reading info... MCU Version V ICPR82_09w46.5 MCU Date 22-01-10 Product RM-530 Manufacturer (c) Nokia IMEI 355239033365516 Mastercode 454677516 IMEI Spare 3A55320933635501 IMEI SV 3355320933635531F8000000 PSN CFL991738 Product Code 0586218 Basic Product Code 0573568 PSD 0000000000000000 LPSN 0 WLAN MAC 00BD3A66EB43 APE SW 023.002 APE Variant 023.002023.002.41.02023.002.C00.01 APE Test 0.021 APE HW 256 APE ADSP 256 RETU 40 TAHVO 00 AHNE 11 HW 0803 RFIC |Vapaus_5.1 | Aura_?.? DSP ICPR82_09w46.2_RIO Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 04-10-2010 at 11:45. Reason: add code tag |
cyclone team need help [ Solved ] | m_naeem | Cyclonebox | 5 | 04-09-2010 23:14 |
Help cyclon team | kalser | Cyclonebox | 9 | 04-08-2010 19:38 |
e72 flash error | shak360 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-08-2010 17:02 |
Cyclone team.. CYclone Box No support Nokia 1112 rh92 SW 6.46 | residentdenuevo | Cyclonebox | 8 | 07-08-2009 13:04 |
