05-25-2014, 22:29 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 801055 Status: Offline Thanks Meter: 20 | E90 unlock... log Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002DB5 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DC0000F8 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,91v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,80v PASSED VBAT Voltage 1,36v PASSED VBAT Voltage 4,75v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,79v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 99 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.724GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 1E3332291FEA8EA926B459AFDC053841823E7C41 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19A00004145200586581FEF6C4EB856C3F917C14 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... BB5 Unlock Started... MCU Version V 400.41.03 MCU Date 09-02-09 Product RA-6 (Nokia E90) Manufacturer (c) Nokia IMEI 353659011386493 Mastercode 2323413121 Simlock Server SIMLOCK SERVER Simlock Key 2320100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23201F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23201F Reading Security Block... Security block OK and saved to "RA-6_353659011386493_25-05-2014_232817.SecurityBlock.PM" WARNING: "19A00004145200586581FEF6C4EB856C3F917C14.C0002DB5 " Not Exists, Will read it... Reading CYC file from phone... Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 1E3332291FEA8EA926B459AFDC053841823E7C41 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19A00004145200586581FEF6C4EB856C3F917C14 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Sending Auxiliary Loader... Auxiliary Loader Sent! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs Custom loader running OK! Working... [LdrDebug] RAPxx CommonBoot Startup... V1.06 (c) KarwosLabs 2011 [LdrDebug] --- Debug Channel --- [LdrDebug] Target: RAPIDO CPU [LdrDebug] ARM MCU ID Ret: 0x4107B366 [LdrDebug] ReadRomID Ret: 0xF2C6EBAD [LdrDebug] ReadSysReg(0) Ret: 0x55555555 [LdrDebug] ReadSysReg(1) Ret: 0xAAAAAAAA [LdrDebug] ReadSysReg(2) Ret: 0x00000001 [LdrDebug] ReadSysReg(3) Ret: 0x00000226 [LdrDebug] ReadSysReg(4) Ret: 0x00010006 [LdrDebug] ReadSysReg(5) Ret: 0x0400A019 [LdrDebug] ReadSysReg(6) Ret: 0x48005214 [LdrDebug] ReadSysReg(7) Ret: 0x00000000 [LdrDebug] ReadSysReg(8) Ret: 0x467C0000 [LdrDebug] ReadSysReg(9) Ret: 0x400C1921 [LdrDebug] ReadSysReg(10) Ret: 0x01011103 [LdrDebug] ReadSysReg(11) Ret: 0x0000000A [LdrDebug] ReadSysReg(12) Ret: 0x00000000 [LdrDebug] ReadSysReg(13) Ret: 0x55555555 [LdrDebug] ReadSysReg(14) Ret: 0x55555555 [LdrDebug] ReadSysReg(15) Ret: 0x55555555 [LdrDebug] ReadSysReg(16) Ret: 0x55555555 [LdrDebug] Keys Copied Neither CYC file and exists or failed to read it from phone (Failed to Read Die ID (1)! Please send LdrDebug information to developer.) BB5 Unlock Failed -> Failed to obtain Phone Unique Data |
05-25-2014, 23:27 | #3 (permalink) |
Member: 801055 Status: Offline Thanks Meter: 20 | dosent worj either Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:31:40, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0002DB5 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: DC0000F8 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,91v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,80v PASSED VBAT Voltage 1,34v PASSED VBAT Voltage 4,73v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,75v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 99 Lumia No TP is NOT ACTIVATED! (1) Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.764GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 1E3332291FEA8EA926B459AFDC053841823E7C41 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19A00004145200586581FEF6C4EB856C3F917C14 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... BB5 Unlock Started... MCU Version V 400.41.03 MCU Date 09-02-09 Product RA-6 (Nokia E90) Manufacturer (c) Nokia IMEI 353659011386493 Mastercode 2323413121 Simlock Server SIMLOCK SERVER Simlock Key 2320100000000000 Simlock Profile 0100000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23201F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23201F Reading Security Block... Security block OK and saved to "RA-6_353659011386493_26-05-2014_002631.SecurityBlock.PM" Determining PA Simlock... Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 1E3332291FEA8EA926B459AFDC053841823E7C41 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101011103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 19A00004145200586581FEF6C4EB856C3F917C14 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: F2C6EBAD CMT_SECURE_ROM_CRC: C86E6189 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support with selected Unlock Method... Selected Unlock Method: NCK Calculation (old method) BB5 Unlock Failed -> Unsupported Rootkey Hash for selected Unlock Method, this is critical |
