Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 10-08-2012, 18:08   #1 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
Arrow my cyclone reloaded not showing full product list
hello friends , i am new user for cyclone reloded, i bought it few days ago, i have many other tool box ,but i found cyclone is tougher than other for operating, i am feeling some difficulties while operating it, i have installed many firmware in my hard drive but in cyclone soft product list only 5-7 models showing , i have set path from setting option of firmwares , but after scanning it shows again 5-7 models, i checked with mx, ufs and advance box, at there all product models are showing and working very well , but in case of cyclone i dont know what happens, i have searched forum , read whole manuals , but i did nt find any related issue of mine, so friends please help me , what should i do ,so the whole nokia model list shows on product list , plz help
Old 10-08-2012, 18:43   #2 (permalink)
Member: 541042
Thanks Meter: 519
ADD right Pfad to Firmware into Settings
Old 10-08-2012, 19:37   #3 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
sorry i didnt understand u, can u clear it, and smthng i want to say to u that i have added right path in setting tab, plz help help
Old 10-09-2012, 08:20   #4 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
please reply , i need it urgent, please supporters , where r u. plz help me
Old 10-09-2012, 15:22   #5 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
see this.
BR.
Arsalan gsm2000.
Old 10-09-2012, 22:25   #6 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
- Make 100% sure that you have the Path / s settings correct
- Make sure that every FW folder (RM-xxx) have inside the corresponding INI / VPL file
- Close the Cyclone Soft, go to the Cyclone program folder and delete "BB5.CacheV2" file, open the soft again and check.....
The Following User Says Thank You to ptt For This Useful Post:
Old 10-10-2012, 07:07   #7 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
thanks for ur reply MR PTT, i have done as u said except ini/vpl file in RM folder, here i have screen shot of my problem
now u tell me what to do
Old 10-10-2012, 07:19   #8 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
Old 10-10-2012, 07:40   #9 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
yes i did sir , but the problem is same
Old 10-10-2012, 22:02   #10 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
Check if your Not Listed FW Folders (RM-xxx) have the corresponding "INI or VPL" file inside (besides the MCU, CNT, PPM)
Old 10-11-2012, 03:41   #11 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
yes sir i checked, in some RM-*** folders vpp/INI file is not present but in some folders it is present , but the model is not showing in software whose ini/vpp file is present in RM-*** FOLDER, plz sir plz plz help me
Old 10-11-2012, 17:42   #12 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
helo team please listen my problem also, i know u all are busy in ur work, but plz supporter i have no other option than u, it should be very kindness of urs , if u will help me, bcoz at this time i m feeling like looser ,
Old 10-11-2012, 18:48   #13 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Dear saw my post first OR contact me pm.
BR.
Arsalan gsm2000.
Old 10-18-2012, 03:50   #14 (permalink)
jaggaamrit's Avatar
Member: 244558
Thanks Meter: 85
My problem is not solved yet, plz help
Old 10-18-2012, 10:20   #15 (permalink)
Member: 18642
Thanks Meter: 44
I have a similar situation. BB5.CacheV2 file already erased. It did not help.
When you first use the "Flash" tab for BB5, I see:
" Found 248 product. Filtering BB5 Product - wait."
and then
"1 Product left after filtering. Ready."
It's strange because in the Phoenix do not have these problems.
Page generated in 0.27785 seconds with 8 queries
