Easy tutorial to Unlock Lumia 800 ;) 1 Attachment(s) Instructions: 1. Go to WP7 -> Simlocks Tab 2. Select Product and click ROOT! 3. Press and hold vol+ ke plug USB cable install driver It should go this way: http://img809.imageshack.us/img809/8343/l0ol.jpg 4. Download and install NSS from this link http://forum.gsmhosting.com/vbb/f528...4/#post9632072 5. Open NSS go in simlock tab http://img838.imageshack.us/img838/9480/1qzn.jpg Turn off phone Press and holp Vol+ key and plug cable after install driver . In Simlocks -----WP7 http://img21.imageshack.us/img21/535/4h2c.jpg Click Unlock and If there is Error http://img407.imageshack.us/img407/5535/l89b.jpg Go in Advance setting tab and tick the option Lumia unlock-Alternative .. http://img9.imageshack.us/img9/9585/c0q9.jpg then back WP7 tab and click unlock again http://img24.imageshack.us/img24/5674/16c3.jpg Unlocked http://img843.imageshack.us/img843/2636/04g6.jpg REGARDS ;) |
Nicely explained, thanks |
And what about nokia deloader version of lumia ???? |
Yes, you can unlock now Without TP by rooting... |
its free or use any credit like sl3 |
You need got 60 credits on cyclonebox account and update box after all is free and unlimited |
just lumia is free or also sl3 |
Hi there, got 2 questions. 1. Is it valid for ANY Nokia Lumia 800 from any network? 2. The unlock is permanent? Or if I update the software you lose it? |
Just lumia 800 is free. ans: 1. Yes all models Lumia 800 are supported all network. 2. No is not permament after flash phone need do root and unlock again but this is not a problem becosue activation is unlimited and always after flash can unlock phone again. |
Yes correct first flash after root and unlock :) |
WORKING !!!!!!!!!! Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:34:19, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Key Flasher Interface (c) 2012 KarwosLabs Box Serial Number: A000013A HW Revision: E, Suitable for: Production, Case: Orange Key Casing, MCU Manufacture Time: Green PCB Rev. 4 2012 wk33, MCU 2011 wk09 Box is activated Started box selftests procedure All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 3.1023GB Avaiable Virtual Memory: 1.795GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Lumia No TP Root Procedure Started... If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [USB Composite Device]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [USB Composite Device]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.0 Version: v256.4 Build: 10 Timestamp: 9/29/2011 4:38:56 PM OSBL Bootloader Ready USB&UART Tracing set RSA Signature Calculated for QCB Boot, Writing... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 9/28/2011 4:52:12 PM Signer S/N: 23 Signer User ID: 10046114 Auth Level: Care Data Encryption: 0 Image Index: 0 Asic Index: 0 Type: Image Write Hashtable Parsed OK Certificate Accepted [ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200 Write taken 0.437s (Average speed: 15944.20kBits/s) Restoring Modem from BACKUP_RAMFS_IMAGE... Restore OK Restarting MCU... Rooting Finished! Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Reading FAT16 raw...Done. Searching locations...Done. Found 2 locations to modify, processing: Reading sector 0...Done. Modify sector...Done. Updating sector...Done. Reading sector 1...Done. Modify sector...Done. Updating sector...Done. Modification written. Please follow those steps: 1. Disconnect USB cable and remove the battery 2. Insert not supported simcard and power on the phone 3. If asked for PIN code, enter 00000000 4. If asked for PUK code, enter 0000000000 5. After unlock success, connect to USB, enter OSBL mode 6. Press Unlock again to restore the phone to original PHONE UNLOCKED !!!!!!!!!!!!! |
after rooting 2 lumia 800 i plug while vol + pressed install drivers but softwares cannot see phone anymore, any ideia why? regards |
i' using windows 7 64 bits, and i see it like u say. even software detect nand. but when i press unlock phone always not found |
