Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 08-15-2013, 12:50   #16 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,176
Originally Posted by [Rod] View Post
i' using windows 7 64 bits, and i see it like u say. even software detect nand. but when i press unlock phone always not found
it will found as NAND disk , Please see again first post i hope you will understand .
and for unlock use NSS .
Old 08-15-2013, 20:18   #17 (permalink)
Member: 31028
Thanks Meter: 53
made it drivers problem.
regards
Old 08-16-2013, 05:37   #18 (permalink)
Member: 137489
Thanks Meter: 68
what drivers did you use because i have the same problem
Old 08-16-2013, 16:49   #19 (permalink)
PIRATOSS's Avatar
Member: 91917
Thanks Meter: 46
salam plz i can t root lumia 800 can you help me plz
Lumia No TP Root Procedure Started...
If phone is alive, It will be automatically swithced to OSBL mode.
If software can't switch to OSBL mode, or phone is generally DEAD do folllowing:
1. Turn OFF device, wait 15 seconds afterwards
2. Eject USB cable, wait 10 seconds
3. Press and hold Volume-UP button
4. Insert USB Cable. OSBL should be booted.
Booting CMT...
[Dispositivo compuesto USB]: WinUSB Port opened OK!
BB5 USB Boot Rom not Detected -> Timeout, no any compatible USB device detected.
Failed to Boot CMT -> No compatible USB devices detected
Prepare phone failed with message -> Failed to Boot CMT
Write Root Data Failed -> Failed to Boot OSBL
Failed to Root Phone -> Rooting Failed
Booting CMT...
Booting CMT...
Old 08-16-2013, 17:26   #20 (permalink)
Member: 31028
Thanks Meter: 53
Gerti the ones on the first post qcusb installed vmware player with winxp to have a clean windows installtation. PIRATOSS did u install zune? seems that u have no drivers installed even in normal mode.
regards
Old 08-16-2013, 18:11   #21 (permalink)
Member: 1803407
Thanks Meter: 6
Anyone tell me.. . After I ordered the unlock. Wasn't this part of the above.
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address: 0x001F4200
FAT16 partition size: 0x0927C000
Reading FAT16 raw...Done.
Searching locations...Done.
Found 2 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Reading sector 1...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
PHONE UNLOCKED !!!!!!!!!!!!!
Last edited by czzchen; 08-16-2013 at 18:18. Reason: Use cyclone box to root after use the Nss to unlock yes or no .Anyone can answer me .thanks
Old 08-19-2013, 18:07   #22 (permalink)
ihsan.khan.gsm's Avatar
Member: 1489021
Sonork: 100.1620946
Thanks Meter: 769
what say about xglod like c101 its too free like lumia
Old 08-21-2013, 18:24   #23 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
Originally Posted by wgmmmx1 View Post
Just lumia 800 is free.
ans:
1. Yes all models Lumia 800 are supported all network.
2. No is not permament after flash phone need do root and unlock again but this is not a problem becosue activation is unlimited and always after flash can unlock phone again.
Hi,
support LUMINA 800 RM-819 ? no list on Cyclonebox software
Old 08-21-2013, 18:56   #24 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
SOLVED
thks
chek this
Old 08-21-2013, 19:08   #25 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
Work on W7 64 tested with 2 phones now RM-819
Old 09-04-2013, 15:42   #26 (permalink)
Member: 1386647
Sonork: Acuemen
regards
Hi There! what drivers did u use,i downloaded the ones frm first post but it just doesn't work i have win 7 32 bit, phone is being detected as qualocom and also as NAND DISK, any advice plz.?
Looking for phone...Not found!
Can't read IMEI, backup will be skipped.
Looking for NAND disk...Not found.
Things to check:
1. Is the phone connected?(Plug to the USB)
2. Is it in the correct mode?(Try to switch to OSBL mode)
3. Have you installed the Qcom loader ?(Use the Install button)
Old 09-06-2013, 05:18   #27 (permalink)
descarado's Avatar
Member: 774392
Thanks Meter: 17
Power on pone, connect this phone in zune(normal) mode, scan after detect procced to unlock , install Zune first, drivers auto detect and install for w7
Old 09-14-2013, 02:02   #28 (permalink)
rorcorporation's Avatar
Member: 1664131
Sonork: 100.1636755
Thanks Meter: 36
the link for download nsspro not exist.. only redirecting to log from lumia 800 unlocked..
Old 07-14-2014, 11:31   #29 (permalink)
Member: 504184
Thanks Meter: 54
Post Nokia Lumia 800 unlock successfully 100 % working tutorial
I have just unlocked nokia Lumia 800 by following the below tutorial.
100% tested by me.
here is the log
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:32:14, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Reloaded Flasher Interface (c) 2012 KarwosLabs
Box Serial Number: B000223A
HW Revision: D, Suitable for: Production, Case: Reloaded Box Casing, MCU Manufacture Time: 2012, wk01 / 2011, wk27
Box is activated
Started box selftests procedure
USB Voltage 4.99v PASSED
MCU Voltage 3.27v PASSED
Core Voltage 1.76v PASSED
VBAT Voltage 0.03v PASSED
VBAT Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.97v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 92
Lumia No TP is ACTIVATED!
Avaiable Physical Memory: 1.931GB
Avaiable Virtual Memory: 1.791GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
MCU Version V 03.70
MCU Date 14-04-09
Product RH-122 (Nokia 1661)
Manufacturer (c) Nokia
IMEI 355205**********
Mastercode 1165561434
Setting Local Mode...
Local mode Set
Asic 11
HW Signature EE8D884B984AF454
Simlock Server SIMLOCK SERVER
Simlock Key 2343300000000000
Simlock Profile 8000000000030002
Simlock Aux 000B0000
Simlock IMEI 00003552050332625600
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 23433F
Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 23486F
Autodetecting SP Type...
Autodetection Finished
Proceeding with RSA Unlock...
Asking card to sign HW Signature...
Signed OK (FAF313E697F2969D70DC022CC65081E2762EB044)
Calculating SP...
Writing SP...
New SP Accepted OK!
Phone unlocked OK!
Booting CMT...
[USB Composite Device]: WinUSB Port opened OK!
[Nokia USB Connectivity]: WinUSB Port opened OK!
Switching to RAW Mode...
OSBL Details
Protocol: v1.0
Version: v256.4
Build: 10
Timestamp: 29/09/2011 14:38:56
OSBL Bootloader Ready
USB&UART Tracing set
RSA Signature Calculated for QCB Boot, Writing...
OSBL Certificate Details
Magic: WP70
Version: 0
Signer Server ID: 0x98031573
Signer Timestamp: 28/09/2011 14:52:12
Signer S/N: 23
Signer User ID: 10046114
Auth Level: Care
Data Encryption: 0
Image Index: 0
Asic Index: 0
Type: Image Write
Hashtable Parsed OK
Certificate Accepted
[ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200
Write taken 0.359s (Average speed: 19408.40kBits/s)
Restoring Modem from BACKUP_RAMFS_IMAGE...
Restore OK
Restarting MCU...
Rooting Finished!
After this I have unlocked with NSS tool.
here is the log.
Searching locations...Nothing found.
Searching restore locations...Nothing found.
Originally Posted by NADEEM GONDAL View Post
Instructions:
1. Go to WP7 -> Simlocks Tab
2. Select Product and click ROOT!
3. Press and hold vol+ ke plug USB cable install driver
It should go this way:
4. Download and install NSS from this link
http://forum.gsmhosting.com/vbb/f528...4/#post9632072
5. Open NSS go in simlock tab
Turn off phone Press and holp Vol+ key and plug cable after install driver .
In Simlocks -----WP7
Click Unlock and If there is Error
Go in Advance setting tab and tick the option Lumia unlock-Alternative ..
then back WP7 tab and click unlock again
Unlocked
REGARDS
Old 08-08-2014, 09:22   #30 (permalink)
Member: 2236592
Hi, newbie here, will it work using Windows 8 PC ?
Page generated in 0.41286 seconds with 8 queries
