06-24-2011, 10:35 | #1 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1600491 Status: Offline Thanks Meter: 0 | Error with newly bought cyclone box... |
06-24-2011, 11:12 | #3 (permalink) |
Member: 1600491 Status: Offline Thanks Meter: 0 | Box Firmware: Cyclone Nokia Application v01.62, (Jun 5 2011 22:22:07, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005E86 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D00800CC Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.98v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.80v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.98v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Handling device: [Cyclone Team], [Cyclone Box] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Failed to disable VBAT -> No answer from CBUS Failed to read info -> Phone not detected and in ststus its shows no phone attached. |
06-24-2011, 11:34 | #6 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Quote:
The Following User Says Thank You to Mr.3. For This Useful Post: |
06-24-2011, 11:48 | #7 (permalink) |
Member: 1600491 Status: Offline Thanks Meter: 0 | i updated the box now but gettin the following errors Handling device: [Cyclone Team], [Cyclone Box] CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe) Failed to disable VBAT -> No answer from CBUS Failed to read info -> Phone not detected |
06-24-2011, 12:36 | #8 (permalink) |
Member: 1600491 Status: Offline Thanks Meter: 0 | New screen shot after updating the box... Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.63, (Jun 21 2011 14:16:44, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005E86 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D00800CC Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.98v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.17v PASSED VBAT Voltage 4.93v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.95v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to read info -> Phone not detected in status phone not attached. |
06-24-2011, 12:48 | #11 (permalink) |
Member: 1600491 Status: Offline Thanks Meter: 0 | i am tryin to connect nokia 7610.i have tried with and without the tx2 cable but getting a pop up screen stating phone not detected at FBUS interface and than Failed to read info -> Phone not detected in status phone not attached. |
06-24-2011, 13:00 | #13 (permalink) |
Member: 1600491 Status: Offline Thanks Meter: 0 | i hav already tried checking flash bus i am gettin the following screen shot Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.63, (Jun 21 2011 14:16:44, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005E86 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D00800CC Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 4.98v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.80v PASSED VBAT Voltage 1.29v PASSED VBAT Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.97v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Failed to read info -> Phone not detected Sending User Abort Signal... CBUS Request Error -> User abort Failed to read info -> Phone not detected Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: 20692069206920692069206920692069 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V Flash Loading Failed -> Loader is not ready Failed to Check DCT4 Flashing Bus -> Problem with sending Flash Loader |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
