Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #16 (permalink) |
| Temporary banned !! ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2006 Location: www.intimeunlock.com
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks: 620
| About SX$ auth Q: Can I use SX-4 to unlock new "SL3" phones ??? A: No Q: Can I use SX-4 to upload unlocked PM 308 and PM 120 to N96, 5800, and other phones which have firmware protected PM 308 ??? A: No Q: Can I use SX-4 to fix PM 308 or Corrupted Certificate problems that causes my phone to automatically shutdown by itself every so often ??? A: No Q: If I full erase my PM, then use SX-4 Server to write my good friend's Full PM backup without PM 308, then proceed to unlock my phone using the "No TP Unlock" Solution, will my phone be 100% OK ??? A: No. Although your phone will be unlocked, and SX-4 will enable you to write RF Tunings and Battery Calibration, but you will still not have a COMPLETE 100% working PM 308. In this case, your phone will shutdown every so often. Q: My phone has damaged earpiece, can I use SX-4 Server to fix this? A: No Q: My phone has broken LCD (cracked) because my girlfriend threw it out the window. Can I use SX-4 Server to fix the phone? A: Let me think... No! Q: Why is it that I always get: Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Disconnected from Cyclone Server Failed to Authorize SX4 -> Failed to receive mutual Data 2 from server A: Because your phone cannot be Authorized by the SX-4 Server. Most probably your PM 308 is not good or your Certificates (RPL) are corrupted. Follow Up Question: But this is the reason why I wanted to use SX-4 Server so I could write the good PM 308 file!!! Is there no other way??? A: Writing PM 308 does not require SX-4 Authority. If you cannot write to PM 308, then most probably you have one of those new phones with new firmwares that disable writing to PM 308 (like N96, 5800 etc...). Q: So what is the use of the SX-4 Server if it cannot do all these things especially fixed a cracked LCD??? A: It is primarily used for writing RF Tunings and Battery Calibration. With it you can write full PM 0-xxx for phones with non protected PM 308. It can also fix some problems you may encounter afer writing a GOOD RPL to the phone. For this specific problem, we have upload some default PM 1 and PM 309 for most phones in our server. Q: I keep getting error messages in the software, is it a Server Problem or is my phone really not possible to Authorize? A: According to our server logs for the past few days, around 70% of the LOGS are from phones which have Security Failures such as bad PM 308 or bad RPL. So most probably, you are one of the 70%. Q: So how can a phone Qualify for SX-4 Authorization? A: * If the phone has 100% good certificates (RPL) and 100% good PM 308 and PM 120 for new phones, then you can use SX-4 Server to Authorize the phone if you want to upload new PM 1 and PM 309 to it. * If the phone was fully erased, then re-flashed with a compatible firmware, then a good RPL was written to it... You can use SX-4 to Authorize the phone to accept your FULL PM backup (except for phones with protected PM 308). Q: So a phone has to be 100% working before I can SX-4 Authorize it??? Why would I want to SX-4 Authorize a 100% working phone without problems??? A: You don't. The main thing is, SX-4 Authority is not for fixing DAMAGED SECURITY Certificates. It is not for SP Unlocking any BB5 Phone. It is not for Fixing PM 308 or PM 120. So if you plan to use our SX-4 Server, be sure you know what it is for. If you don't know what SX-4 Authority is for, then most probably you will never need it. But for those who knows what it is for and have used it before, then I can assure you that our Server is working well these days... ;o) Q: Ok ok... but still this SX-4 Server cannot fix my broken LCD even if the crack is just very very very small??? A: Hmm... Please buy a hammer, and hit it to your head ;oP Thanks to Xshadow for this funny but perfect faq about sx4 Last edited by moulnisky; 09-17-2009 at 01:04. |
| | #17 (permalink) |
| Q: HELLO CYCLONE TEAM this 2630 v57.20 from orange was unlocked before with cyclone in that time super dct4 was not released.in that time phone has not signal.now with super dct4 i again unlocked it but still doesnt have signal. is there any salution for this phone? A: flash the phone to remove previous patch then unlock again with new cyclone release |
| The Following User Says Thank You to hasnain For This Useful Post: |
| | #18 (permalink) |
| *** Failed to write CMT cert data (3), Programming Status Error *** If you encountering such problem during flash programming, then this is: 90% TX2 problem, 10% phone hardware problem. Usually, it's JUST tx2, so check following things: - YOU NEED attached TX2 adapter to use UFS/JAF cables, otherwise this problem will occur! - Check settings of TX2 Pin in Main Software. Attached adapter using Service Pin 3, so TX2 will work only after setting THIS PIN (is set by default). You can of course set other pins, after needed cable mods. - Finally make sure if your cable is ok. Btw, while faulty TX2, APE phones will not be booted too, till APE secondary and algo boot needs be sent using Tx2 (or you might try unchecking TX2 and using old loaders but this is not the way at all. ) |
| | #19 (permalink) |
| Q: I have working BB5 phone and after unlock got imei 123456754321? now what to do ? A: first see this ::.. F.A.Q About CycloneBox ..:: Before performing any operation Always make RPL backup make "RPL phone backup like UB" with cyclone also make plain RPL backup with cyclone. NOTE: don't start any operation before backup otherwise u need RPL + tablets of HEADACHE |
| | #20 (permalink) |
| contact service Q : My mobile(BB5) shows contact service on screen ? A: 1. check the imei , is it ok or 1234567654321? if ok than go to step 2 if not ok than u need RPL 2. check simlock data , is it ok too or 00000000000 if ok than go to step 3 if not ok than u need RPL also on few models u can do it through different process 3. do SX4 auth and write PM field 1 and 309 or do sx4 alternative security bypass and write these pm fields if still not helped than full erase than flash than write backup than do sx4 and write full pm |
| The Following 2 Users Say Thank You to hasnain For This Useful Post: |
| | #21 (permalink) |
| Q : My mobile(DCT4+) shows contact service on screen ? A: 1: check the imei is it ok or like this ????????????????? if it is ????????????????? than write RPL ater that unlock ur mobile if needed 2: if ur imei is ok than check the simlock area is it corrupted or not if corrupted than just u need unlock. 3. if SP area is not corrupted ad imei is ok than check by full erase than flash than pm than full factory settings than unlock 4. if still same than hardware |
| | #22 (permalink) |
| Dct4 ask/rpl Q: how to read ask file of DCT4 for RPL and after that how to request RPL and after that how to write using cyclone ? A: 1- Click on "Nokia DCT4/WD2/BB5" Service Tool 2- Go to DCt4/WD2 tab 3- Go to Security tab, then do "Read UEM IMEI", and a the end of the proces, you must get "UEM IMEI: the imei of your phone" copy this number 4- Close DCT4 Tool, then go to "credits" and do a "check credits" if you can see your credits, then continue ( if get error, maybe server down) 5- Copy your IMEI, where say "IMEI", select ASIC ( e.g asic for 1112 is asic 11), then press calculate, and you get your RPL ( save it to your PC, remember where save) 6- Open DCT4/BB5 tool, go to dct-4 tab, in secuity tab, press "write RPL" (select your RPL), and thats all.. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
