Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 708 | Failed to Create RPL from phone Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Not Found CMT CCC Not Found CMT HWC Not Found CMT VARIANT Not Found CMT PARTNERC Not Found Restoring from Recovery Mode... CBUS Request Error -> CBUS Response wrong header FAILED to Restore from Recovery Mode. Possible reasons: 1. Not attached yellow TX2 Adapter 2. Using 5-pin Cable (not TX2 Enabled) In either cases, check cable/adapter, and write NPC Certificate Manually using "Write Cert" and writing NPC Backup from "StoredFiles". Restarting MCU... Failed to Create RPL from phone -> Failed to restart MCU RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Processing rm495__07.97.mcusw (CMT)... Booting CMT. |
![]() | #5 (permalink) |
Moderator ![]() Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,118 | @Br.Ihsan , if u use cyclone old box then attach yellow tx2 cable . if u use cyclone reloaded then it's a hardware problem . flash ic problem . @Teplok , flash ic faulty . |
![]() | #6 (permalink) | |
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 708 | Quote:
yes im use old cyclone box and tried also attach yellow addepter but still same .any way my pro is solved with others tools | |
