Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 23
Member: 117496 Status: Offline Sonork: 100.83919 Thanks: 84
| *** Failed to write CMT cert data (3), Programming Status Error *** If you encountering such problem during flash programming, then this is: 90% TX2 problem, 10% phone hardware problem. Usually, it's JUST tx2, so check following things: - YOU NEED attached TX2 adapter to use UFS/JAF cables, otherwise this problem will occur! - Check settings of TX2 Pin in Main Software. Attached adapter using Service Pin 3, so TX2 will work only after setting THIS PIN (is set by default). You can of course set other pins, after needed cable mods. - Finally make sure if your cable is ok. Last edited by karwos; 03-27-2009 at 21:08. |
| The Following 32 Users Say Thank You to karwos For This Useful Post: | =_AYYOUB_=, adam92se, alwi7666, aswancamel, BAHRI PhoneWala, blolyxx, clearcom, DaWizard, galaxe44, gily1, gsmkiller173, gurdeep.s1988, jhoesteve, mamun_q, mil rookie, misterG, morton1984, oscarjr85, quakefabi, RAVI_SINGH, rizkypratama999, romar, sakib07, Sammart, SAN INFOTECH, shruti, siya afai, SkyMobile05, soshan, togivhelai, umarnlw, VAHID GSM |
| | #2 (permalink) |
| Btw, while faulty TX2, APE phones will not be booted too, till APE secondary and algo boot needs be sent using Tx2 (or you might try unchecking TX2 and using old loaders but this is not the way at all. ) |
| The Following 8 Users Say Thank You to karwos For This Useful Post: |
| | #5 (permalink) |
| If you are using BB5 JAF/UFS cables then it is 100% needed. For DCT4 you can plug it directly. |
| The Following 4 Users Say Thank You to karwos For This Useful Post: |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2008 Location: G̣ dầu -tây ninh
Member: 896966 Status: Offline Sonork: 100.1607398 Thanks: 77
| cab MT 10pin have use for cyclone ? |
| The Following User Says Thank You to gsmtayninh For This Useful Post: |
| | #11 (permalink) |
| Junior Member Join Date: Apr 2009 Location: bohol, philippines
Member: 1009698 Status: Offline Sonork: cyclonebox Thanks: 11
| what if ufc cable,, thus is it necessary to use adapter??? |
| The Following User Says Thank You to shine89 For This Useful Post: |
| | #12 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Nov 2004 Location: 29700A53 - BB PIN
Member: 91045 Status: Offline Sonork: 100.1577222 Thanks: 1,679
| YES if USing JAF version of UFC adaptor is needed For All Operations on BB5 Phones but for DCT4 can pluf it directly |
| | #13 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2003
Member: 45571 Status: Offline Thanks: 75
| How to write back backup crt? i tried but i can only select one file at a time and backup is more than one file maybe around 6 files.Should i select it one by one then write? |
| The Following User Says Thank You to fretburner For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
| whats the error -> Failed to Write PM -> Access violation at address 005AE2F5 | Y.P.Y | Cyclonebox | 6 | 03-09-2010 21:12 |
| 5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 14:17 |
| Failed to Write CMT NPC Certificate N81 | bleck | Cyclonebox | 18 | 07-26-2009 04:33 |
| Failed to write CMT cert data (3) | hasnain | Cyclonebox | 3 | 04-15-2009 12:10 |
