Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #17 (permalink) |
| Junior Member Join Date: Nov 2008
Member: 905933 Status: Offline Thanks: 0
| what happen with this? Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1520010304A67B56CDB2543E676096683CDC41A6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D APE Subsystem Not Found CMT NPC Ok CMT HWC Ok CMT CCC Ok CMT R&D Ok CMT VARIANT Ok CMT PAPUBKEYS Ok CMT KEYS Ok Restarting MCU... Read all certificates finished Certificates backup thread finished, continuing... Backing up simlock... Starting PM read in range 308-308... [308] Reading 9 records [308,0] Reading 50593801 bytes Failed to read PM -> Failed to read PM Record 308,0 Starting PM read in range 120-120... PM Read OK, Time taken 0.0s Simlock backup OK Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm237__07.21.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 1520010304A67B56CDB2543E676096683CDC41A6 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 191EC665DFAAF68F rm237__07.21.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 3.25Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898100000000, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 4.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Flashbus Write baud set to 4.0Mbits Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 86.610s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm237__07.21.mcusw proccess cannot be done,why? |
| The Following User Says Thank You to de_rich For This Useful Post: |
| | #18 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 23
Member: 117496 Status: Offline Sonork: 100.83919 Thanks: 84
| Quote:
| The Following User Says Thank You to karwos For This Useful Post: |
| | #20 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2005 Location: CAMBODIA Age: 33
Member: 168347 Status: Offline Thanks: 6
| Error cmt even used connector Dear all Cyclone What's pluge cable direct and pluge with box. I think is the same when write flash is alway shown error cmt but I flash with jaf it ok. why not correct like this as you write down TX2=3 or TX2=10 I also tick different but the same result. Please solve out problem. |
| | #22 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks: 701
| Quote:
BB5 phones Yellow Adaptor must be used for bb5 phones flashing to avoid CMT error as thats cause from TX2 line dont insert cable direct | |
| The Following User Says Thank You to NADEEM GONDAL For This Useful Post: |
| | #23 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 283134 Status: Offline Thanks: 9
| Same problem here,cant flash BB5 units.... Sample i have here 6300 hang on start-up,i tried to flash with cyclone but it goes dead.So i flash it with jaf and phone alive again. Im trying to read certificate with cyclone again but failed Here is the logs: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.03, (May 1 2009 17:13:05, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT Box Serial Number: C0xxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D00xxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.99v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.32v PASSED VBAT Voltage 4.82v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.75v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Booting RAP... Failed to Read All Certificates -> Failed to Boot / Prepare Phone |
| The Following User Says Thank You to the eraser For This Useful Post: |
| | #24 (permalink) |
| first make sure u using Yellow Adaptor of Cyclone BOX And secondly dont change any other present settings if needed only change TICK or UnTICK tx2 line option when needed |
| | #25 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2003 Location: 梧州市
Member: 23253 Status: Offline Thanks: 944
| MCU Version V 05wk07v48.2 MCU Date 04-10-07 Product RM-180 Manufacturer (c) Nokia. IMEI 353089020918245 Mastercode 1031445342 IMEI Spare 3A35800902192804 IMEI SV 3335800902192804F9000000 PPM V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 PSN CIJ206164 Product Code 0531463 Basic Product Code 0530940 PSD 0000001700000000 APE SW V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokia APE Variant V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokia APE HW 256 APE ADSP 16054 RETU 32 TAHVO 53 AHNE 22 HW 5001i,(V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 PCI i,(V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 UEM V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 UPP V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 RFIC 150a160f DSP rolf_espresso_05wk07v29p1 LCD V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 BT V 5.0819.4.0.1, 07-05-08, RM-180, (C)Nokiaj4.V 5.0819.4.0.1-APAC1, 07-05-08, RM-180, (c)Nokian256o16054 Failed to read info -> Failed to read extended info |
| The Following User Says Thank You to ttlin5188 For This Useful Post: |
| | #26 (permalink) |
| I purchased this box that was first or 2nd week of april,till now i couldnt flash BB5 phones.Obcourse im using yellow adoptor,posible and default settings already tried. |
| | #28 (permalink) |
| Junior Member Join Date: Oct 2008
Member: 878603 Status: Offline Thanks: 1
| where to tx2 adaptor 4 cyclone box hi cyclonebox is tx2 adaptor for cyclone box available seperate.because i think the one that came with my box is faulty.where can i buy it from |
| The Following User Says Thank You to tufyy1234 For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
| whats the error -> Failed to Write PM -> Access violation at address 005AE2F5 | Y.P.Y | Cyclonebox | 6 | 03-09-2010 21:12 |
| 5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 14:17 |
| Failed to Write CMT NPC Certificate N81 | bleck | Cyclonebox | 18 | 07-26-2009 04:33 |
| Failed to write CMT cert data (3) | hasnain | Cyclonebox | 3 | 04-15-2009 12:10 |
