Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #46 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2008 Location: PAKISTAN Age: 23
Member: 772820 Status: Offline Sonork: BE MASTERMIND Thanks: 14
| i have tried with alot of version but still same i have checked every thing cable phone adapter every thing is correct but still in same jaf can flash it then why not cyclone or mt nokia |
| | #47 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,688
| If you are using the tx2 adapter check it then: open the RJ45 socket section. redo all the soldering on the pcb retry the flash BR Alex |
| | #48 (permalink) |
| but there is every thing is fine i have checked all if any hardware inside then why should jaf box can flash |
| | #49 (permalink) |
| Error 3 is TX2 line error. You can try 2 ways a) Unthick whee says "use TX2" and flash the mobile b) Replace the TX2 adapter (there is on the market the Cyclone V2 adapter By GPG) BR Alex |
| | #51 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2002 Location: Earth Age: 43
Member: 17189 Status: Offline Thanks: 25
| hi there since you are recommending an adapter for the box no problem how many volts (5v or 9v)?? direction on + n - ?? coz I am using a 5v and trying to flash a 6700 and unlock it now nothing got well the mcu process failed thanx in advance |
| | #52 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Sep 2006 Location: On Vacation !!! Age: 36
Member: 348680 Status: Offline Thanks: 411
| Quote:
The TX2 adapter is this one who comes with your Box and MUST be used when works with BB5 phones. ![]() The DC socket is for extermnal VPP ONLY, but not need to use it, you can use VPP " Box INT 5V ". BR | |
| | #53 (permalink) | |
| MR ptt Quote:
![]() the thread is all about the adapter.... ![]() very funny suddenly som smart *** don't reply if you are not certain... thanx anyway | |
| | #54 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 577658 Status: Offline Thanks: 1,680
| Code: rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 90.563s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm495__07.95.mcusw Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1EE00008D8977D56C9EC23612800F0941763CE9B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm495__07.95.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1EE00008D8977D56C9EC23612800F0941763CE9B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm495__07.95.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.50.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 0.250s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm495__07.95.mcusw i too facing same problem please help somebodyy.yaaar please i cant flashe all bb5 sets they r going dead.please help cyclone team Last edited by ptt; 04-21-2010 at 15:56. Reason: add code tag |
| | #57 (permalink) |
| as wel as all says the problem in tx2 line that is 3rd pin i have checked all but same all bb5 phones booting ok but could not flash in cyclone when dct4 or dct4++ all of working well there is only one mistake in cyclone team that is bb5 flashing problems best regard saifali_mirani |
| | #59 (permalink) | |
| Junior Member ![]() ![]() Join Date: Jul 2008
Member: 808204 Status: Offline Sonork: eagleyezzz Thanks: 2
| Quote:
SIR, my cycone always shows "FBUS" interface error" while flashing most of the bb5 phones, specially 5130 2700.... Error comes out after successful flashing in the end while factory settings n read info. In this case handset remain unflashed. if i try to reflash it problem starts with start CMT part only. but same phone can be flashed easily by other flashung tools. where could be the prob TX2 or box itself. | |
| | #60 (permalink) |
| @ Manish Bhave Check / redo solders of the TX2 Adapter Check / redo solders of the "Service" socket Maybe you have some corrupted files in your Cyclone program folder, check this thread, and try as sugested: Bb5 sl2 not unlocking [SOLVED] BR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
| whats the error -> Failed to Write PM -> Access violation at address 005AE2F5 | Y.P.Y | Cyclonebox | 6 | 03-09-2010 21:12 |
| 5800 KILLED Block Write Failed -> Failed to write CMT cert data (3) [SOLVED] | x_gsm | Cyclonebox | 22 | 02-14-2010 14:17 |
| Failed to Write CMT NPC Certificate N81 | bleck | Cyclonebox | 18 | 07-26-2009 04:33 |
| Failed to write CMT cert data (3) | hasnain | Cyclonebox | 3 | 04-15-2009 12:10 |
