Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 10-18-2009, 09:23   #1 (permalink)
Crazy Poster
Member: 917156
help Cyconebox
Box Maintenance procedure started at 16:22:03
Handling device: [Cyclone Team], [Cyclone Bootloader]
Bootloader: Cyclone Secure Bootloader v2.08, (Nov 14 2008 12:05:50), Type: Signed Production Application, For HW Rev E
Service Tag: FEF36F534EE9A475047CDEE39E0A4489
Connecting to Cyclone Server
Cyclone Server (1.0.0.485), Cyclone Box Team 2008, 2009 - Ready.
========= Box Info =========
Box SN: C0002551
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: Unknown
Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty
Box registration status: Registered OK
Updating Security Area...
Security Area Update Skipped, Not allowed
Updating Main Firmware...
Main Firmware Update Skipped, Not allowed
Disconnected from Cyclone Server
Box Maintenance finished successfully
Old 10-18-2009, 09:32   #2 (permalink)
Crazy Poster
Member: 917156
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags
Box Serial Number: C0002551
Initializing security card...
Card Serial Number:
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.00v PASSED
MCU Voltage 3.28v PASSED
Box Selftests Failed -> Core Supply Voltage test failed, 2.16v is out of valid range
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Old 10-18-2009, 09:34   #3 (permalink)
Crazy Poster
Member: 917156
Buy a new box does not know what the problem ah ask for help
Old 10-18-2009, 09:34   #4 (permalink)
Member: 498957
what is the problem mate....?
Old 10-18-2009, 10:25   #5 (permalink)
Member: 732630
read this can help you.
Box Selftests Fail, What to do....
Old 10-18-2009, 11:17   #6 (permalink)
Crazy Poster
Member: 917156
Card is activated
Box is activated
USB Voltage 4.97v PASSED
Box Selftests Failed -> Core Supply Voltage test failed, 2.14v is out of valid range
Old 10-18-2009, 23:31   #7 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Shen690
Your box is new ? is under warranty ?
Do you try to conect a phone and try to read phone info ?
If is under warranty, and you cant work properly, then you must contact your reseller to exchange your box.
This error can be a HW fault ( in this case you canīt work with the box ) or an resistor calibration error ( in this case you can work wit the box )
Old 10-18-2009, 23:58   #8 (permalink)
ptt
ptt's Avatar
Member: 348680
@ Shen690
If your box, not under warranty or IF you contact your reseller and he AUTHORIZE to open the box, you can check if the internal voltage regulator of the AT32U3A1512 ( IC1 ) ( The big 100 pin IC ) is OK: at PIN # 12 you must have 3,3V and at PIN # 11 you must have 1,8V. If you get this values, then is only calibration resistor error, and nothing to worry......
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP FuriouS TeaM FuriouS TeaM Products 66 08-27-2010 13:20
help [ANSWERED] mariusgsm76 Nano-Box 2 04-01-2010 11:33
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 2 2 03-29-2010 12:46
can i lock/unlock 5030 rm-542 with cyconebox? xiakaijun Cyclonebox 1 03-29-2010 01:18
When Cyconebox can unlock 7100s? natchamon Cyclonebox 11 07-15-2009 06:44
Page generated in 0.34683 seconds with 11 queries
