10-16-2010, 17:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2009
Member: 1090041 Status: Offline Sonork: 100.1594914 Thanks Meter: 50 | help me my cyclone box error box has failed one or more selftests diagnostics.this may be temporary failure,or permament HW damage.contact support if any problem with using this device wii occur. pls help me WBR ANW |
10-19-2010, 03:48 | #5 (permalink) |
Member: 1090041 Status: Offline Sonork: 100.1594914 Thanks Meter: 50 | box selftest error log is box has failed one or more selftests diagnostics.this may be temporary failure,or permament HW damage.contact support if any problem with using this device wii occur. |
10-19-2010, 11:29 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | The complete Log of the Box Selftest, not the "warning" it must be like this : Code: Card is activated Box is activated Started box selftests procedure USB Voltage 4.95v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.76v PASSED VBAT Voltage 3.39v PASSED ......... ......... Initializing FBUS... All initialized - Ready to work |
10-19-2010, 18:51 | #7 (permalink) |
Member: 1090041 Status: Offline Sonork: 100.1594914 Thanks Meter: 50 | box selftest error log is box has failed one or more selftests diagnostics.this may be temporary failure,or permament HW damage.contact support if any problem with using this device wii occur. Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.47, (Oct 13 2010 00:16:30, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: ......... HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: .............. Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.12v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.99v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled Box Selftests Failed -> VPP Supply Voltage test failed, 0.18v is out of valid range Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work PLS Help me ANW Last edited by anw; 10-19-2010 at 18:57. |
10-19-2010, 21:34 | #8 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Is your Box under warranty ? Check post #3 of this thread: http://forum.gsmhosting.com/vbb/f528...hat-do-812599/ You can still use your box selecting "Phone" in the "VPP" options. BR |
10-25-2010, 15:19 | #9 (permalink) |
Member: 1090041 Status: Offline Sonork: 100.1594914 Thanks Meter: 50 | Sir PTT i don't have experience hard ware repair.this problem which ic remove or change.pls give me photo.my box is old hw. pls help me thanks for reply WBR ANW |
10-25-2010, 16:33 | #10 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | 1š You can try resoldering U5 ( LM1950 / CS8240 located behind Service socket ) if this dont solve the problem, then you need to change the U5... you can remove U4 (used for switch ext VPP) and use it to replace U5, doing this you recover the Internal Box VPP function, and loose the ext VPP function... BR |
10-25-2010, 22:42 | #13 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Which IC have your Box ? You thell "my Box is old HW" and old HW revision use : LM1950 / CS8240 ( 3 of that IC`s ) and New HW revision use : LM3526 ( 2 of that IC`s ) You must look for the IC`s on Top side of the PCB ( Not the smart card Side ). BR |
12-06-2010, 13:33 | #15 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | You can check both IC`s Datasheet to see if they are the same check at http://www.alldatasheet.com BR |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
