06-21-2011, 15:00 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: portugal
Member: 31417 Status: Offline Thanks Meter: 1 | help my custumer fone imei dead [ Solved ] r , and my fone itīs dead , i try fastrepair , and my ofone work , but imei MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? Warning: Failed to read SP Info, Assuming defaults i try rpl but error, i try pm , code 19 error , i desisperasty can we helpme , iutī+s first time 1 kill fone and not resolion for probleme , i try erevy |
06-21-2011, 15:39 | #3 (permalink) |
Member: 31417 Status: Offline Thanks Meter: 1 | help my custumer fone imei dead Code: Started IMEI Recovery... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1500011506368D524C4B0253F44FE0AE279E7979 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Looking NPC for 1500011506368D524C4B0253F44FE0AE279E7979... Found 1500011506368D524C4B0253F44FE0AE279E7979.DowngradeRepair.NPC.CMT.crt Backup current NPC... Written to "1500011506368D524C4B0253F44FE0AE279E7979_21-06-2011_153306.Recovery.NPC.CMT.crt" Erasing NPC... Writing NPC... IMEI Recovery Finished Failed to set Local Mode -> Mode not accepted my fone not power on , beep and nothing , then i try fast repair another Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1500011506368D524C4B0253F44FE0AE279E7979 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits CMT NPC Ok CMT NPC Erased Restarting MCU... Backing up simlock... MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? Simlock backup OK, saved to RM-356_12345610654321_21-06-2011_153511.SLBackup.PM Backup simlock thread finished, continuing... Applying downgrade patch... phone live but imei IMEI 12345610654321? Last edited by ptt; 06-21-2011 at 16:06. Reason: add CODE Tag |
06-21-2011, 16:01 | #4 (permalink) |
Member: 31417 Status: Offline Thanks Meter: 1 | revolved thanks team , i resolve my problem thids form, I put rpl wihot npc , and than I whrite certificate npc Code: Analyze finished! MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452361F0000000 CNT v 50.2010.06.1_001_000_U01, 17-03-10, vanilla, RM356 PSN MIK595566 Product Code 0576051 Module Code 0203558 Basic Product Code 0552692 PSD 0000000000000000 LPSN 0 APE SW V 50.0.005 APE Variant V 50.0.005V 50.0.005 V 50.0.005 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1105 RFIC 17141716 DSP ICPR72_10w05 Failed to read info -> Failed to read SP info Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1500011506368D524C4B0253F44FE0AE279E7979 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1500011506368D524C4B0253F44FE0AE279E7979 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Processing 1500011506368D524C4B0253F44FE0AE279E7979_24-10-2010_215655.NPC.CMT.crt... CMT NPC Erased CMT NPC Written Write CMT NPC Certificate finished Restarting MCU... All files processed OK! MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 IMEI Spare 3A95330973447100 IMEI SV 3395330973447160F0000000 CNT v 50.2010.06.1_001_000_U01, 17-03-10, vanilla, RM356 PSN MIK595566 Product Code 0576051 Module Code 0203558 Basic Product Code 0552692 PSD 0000000000000000 LPSN 0 WLAN MAC C8979F01072B APE SW V 50.0.005 APE Variant V 50.0.005V 50.0.005 V 50.0.005 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1105 RFIC 17141716 DSP ICPR72_10w05 Failed to read info -> Failed to read SP info SX4 Authorization / SD Repair Procedure Started.... "1500011506368D524C4B0253F44FE0AE279E7979.C0001C6B" Exists, That is good... MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 Reading Security Block... Security block OK and saved to "RM-356_359339037441705_21-06-2011_155507.SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: OK [1,18] Written, Length: 98 bytes, Status: OK [1,20] Written, Length: 98 bytes, Status: OK [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: OK [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,44] Written, Length: 182 bytes, Status: OK [1,45] Written, Length: 182 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 32, Record written NOT OK: 0 MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 IMEI Spare 3A95330973447100 IMEI SV 3395330973447160F0000000 CNT v 50.2010.06.1_001_000_U01, 17-03-10, vanilla, RM356 PSN MIK595566 Product Code 0576051 Module Code 0203558 Basic Product Code 0552692 PSD 0000000000000000 LPSN 0 WLAN MAC C8979F01072B APE SW V 50.0.005 APE Variant V 50.0.005V 50.0.005 V 50.0.005 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1105 RFIC 17141716 DSP ICPR72_10w05 Failed to read info -> Failed to read SP info SX4 Authorization / SD Repair Procedure Started.... "1500011506368D524C4B0253F44FE0AE279E7979.C0001C6B" Exists, That is good... MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 Reading Security Block... Security block OK and saved to "RM-356_359339037441705_21-06-2011_155540.SecurityBlock.PM" SX4 Status: Authorized [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 Write PM Finished, Record written OK: 3, Record written NOT OK: 1 MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 IMEI Spare 3A95330973447100 IMEI SV 3395330973447160F0000000 CNT v 50.2010.06.1_001_000_U01, 17-03-10, vanilla, RM356 PSN MIK595566 Product Code 0576051 Module Code 0203558 Basic Product Code 0552692 PSD 0000000000000000 LPSN 0 WLAN MAC C8979F01072B APE SW V 50.0.005 APE Variant V 50.0.005V 50.0.005 V 50.0.005 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1105 RFIC 17141716 DSP ICPR72_10w05 Simlock Server SIMLOCK SERVER Simlock Key 2680100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26801F Auto Selecting Flash Files on User Request... Product Code: 0576051 This is Valid BB5 Product No variant found with given Product Code, selecting first one MCU Version V ICPR72_10w04.5 MCU Date 22-03-10 Product RM-356 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI 359339037441705 Mastercode 437331014 IMEI Spare 3A95330973447100 IMEI SV 3395330973447160F0000000 CNT v 50.2010.06.1_001_000_U01, 17-03-10, vanilla, RM356 PSN MIK595566 Product Code 0576051 Module Code 0203558 Basic Product Code 0552692 PSD 0000000000000000 LPSN 0 WLAN MAC C8979F01072B APE SW V 50.0.005 APE Variant V 50.0.005V 50.0.005 V 50.0.005 APE Test eno_version APE HW 256 APE ADSP 256 RETU 16 TAHVO 22 AHNE 11 HW 1105 RFIC 17141716 DSP ICPR72_10w05 Simlock Server SIMLOCK SERVER Simlock Key 2680100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26801F Auto Selecting Flash Files on User Request... Product Code: 0576051 This is Valid BB5 Product No variant found with given Product Code, selecting first one Last edited by ptt; 06-21-2011 at 16:06. Reason: add CODE Tag |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
