Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-18-2012, 09:03   #1 (permalink)
Member: 434480
Help Need Backup full rpl E5 RM-632 [SOLVED]
I have nokia E5 this phone have problem restrat, i try upgrade but still same so i try full erase Before this i backup all certificate and full pm 0-512. after full erase and upgrade i restore all cerficate and full PM but phone now show contact retailer and i try analyze security HWC & CCC is Coruppted, anybody have backup full rpl for E5 rm-632???
Dynamic Camera Configuration Analyze/Repair Finished!
Started Phone Security Analysis...
MCU Version    V ICPR82_11w16.3.10
MCU Date    13-03-12
Product        RM-632 (Nokia E5-00)
Manufacturer    (c) Nokia
IMEI        354859041143307
Mastercode    1176126510
Reading Security Block...
Security block OK and saved to "RM-632_354859041143307_5182012_25153 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
CMT_SYSTEM_ASIC_ID:    000000030000022600010007600C192102031104
CMT_EM_ASIC_ID:        00000C35
CMT_EM_ASIC_ID:        00000C30
CMT_PUBLIC_ID:        1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48
CMT_ASIC_MODE_ID:    00
CMT_ROOT_KEY_HASH:    916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC:    E693EF0D
CMT_SECURE_ROM_CRC:    AC22615B
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.48.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.48.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
 !!!!! HWC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
 !!!!! CCC IS CORRUPTED, ANOTHER REASON OF SECURITY TEST FAILED !!!!!
Restarting MCU...
Step 3 : Analyzing Security Block
"1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48.C0002BA8" Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
Checking ECC KEYS...
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Warning: At least one Certificate Test failed, but no Local Generic RPL File found, Put it in SX4 folder.
Last edited by ptt; 05-18-2012 at 11:39. Reason: ADD [CODE] [/CODE] TAG TO THE LOG
Old 05-18-2012, 09:26   #2 (permalink)
Member: 1742117
brother you need pm file1-309 backup
:d.......................................
The Following User Says Thank You to ..::G$M-UNLOCK::.. For This Useful Post:
Old 05-18-2012, 09:30   #3 (permalink)
Member: 434480
ok thank you i will try
Old 05-18-2012, 09:39   #4 (permalink)
Member: 434480
sir this file same in sx4 foleder in cyclone and i already repair this pm with repair sd keys
Old 05-18-2012, 09:50   #5 (permalink)
Member: 1742117
answer is in log
Last edited by ptt; 05-18-2012 at 11:42. Reason: CHANGE FONT SIZE & COLOR - NOBODY IS BLIND HERE
Old 05-18-2012, 10:12   #6 (permalink)
Member: 1742117
if not solve
brother you need E5 without NPC DATA.rpl did u copy hwc and ccc to ur backup rpl? if not before do any think make copy of rpl and open in note ped edit and save and write
after that write rpl and write pm 1-309
Old 05-18-2012, 10:25   #7 (permalink)
Member: 434480
ok i'm sorry sir i try authorization and write pm for you but still contact service
MCU Date    13-03-12
Security block OK and saved to "RM-632_354859041143307_5182012_41945 PM.SecurityBlock.PM"
SX4 Status: Authorized
[1,0] Written, Length: 116 bytes, Status: OK
[1,2] Written, Length: 12 bytes, Status: OK
[1,4] Written, Length: 112 bytes, Status: OK
[1,6] Written, Length: 12 bytes, Status: OK
[1,7] Written, Length: 216 bytes, Status: OK
[1,8] Written, Length: 112 bytes, Status: OK
[1,13] Written, Length: 12 bytes, Status: OK
[1,16] Written, Length: 208 bytes, Status: OK
[1,18] Written, Length: 208 bytes, Status: OK
[1,20] Written, Length: 208 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,26] Written, Length: 112 bytes, Status: OK
[1,28] Written, Length: 12 bytes, Status: OK
[1,29] Written, Length: 12 bytes, Status: OK
[1,31] Written, Length: 208 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 376 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,37] Written, Length: 4 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,40] Written, Length: 16 bytes, Status: OK
[1,41] Written, Length: 184 bytes, Status: OK
[1,42] Written, Length: 4 bytes, Status: OK
[1,43] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 184 bytes, Status: OK
[1,45] Written, Length: 184 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 4 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,3] Written, Length: 36 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 35, Record written NOT OK: 0
Restarting MCU...
Checking SIMLOCK...
Analyze finished!
maybe i'm worng can you help me how step by step to repair my phone i have certificate and pm full backup???
Last edited by ptt; 05-18-2012 at 11:43. Reason: ADD [CODE] [/CODE] TAG TO THE LOG -- CHANGE FONT SIZE & COLOR IN QUOTED PART
Old 05-18-2012, 10:26   #8 (permalink)
Member: 434480
do you have this file??
Last edited by ptt; 05-18-2012 at 11:43. Reason: CHANGE FONT SIZE & COLOR IN QUOTED PART
Old 05-18-2012, 11:29   #9 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
How is possible your backup don't content HWC/CCC Data?
Can you attach so I can check. Maybe it's problem with wirting
Old 05-18-2012, 11:43   #10 (permalink)
Member: 434480
I only read all certificate in cyclone and i only have this rpl file
File Type: rar RM-632_3548590411433075122012_65231 PM.rar (6.4 KB, 149 views)
Old 05-18-2012, 11:49   #11 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Do you have also *.crt files?
You need write all of them.
They will be named like:
1E40000BC4A40344D0054D4A69CD5D5CBBF1FA48.CMT.NPC.C RT
Old 05-18-2012, 12:01   #12 (permalink)
Member: 434480
like this sir, how write this file???
Old 05-18-2012, 12:26   #13 (permalink)
Member: 434480
Thank Mr. Karwos i write crt and my phone back normal
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 1 06-02-1999 16:23
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 05-26-1999 11:35
Page generated in 0.54061 seconds with 12 queries
