Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2010
Member: 1271770 Status: Offline Thanks: 120
| Help to unlock N95 8gb Hello, i have this problem to unlock this phone, this is the log: CHeck FlaSHING BUS: Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 069FB6CD7D1EEBC0B9359B8E63CBE61870D154D4 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08600116177000526F70F4B7D4AAD0896670888B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Read all certs Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 069FB6CD7D1EEBC0B9359B8E63CBE61870D154D4 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08600116177000526F70F4B7D4AAD0896670888B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for BootCode: DualLine 32Bit OMAP2420_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.14.0, Algo: BB5 Adding FUR Client (APE, State: Start)... APE FUR Ready! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,APE]: 0x00EC004000000000, Samsung, ONENAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported OMAP2420_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.14.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE PASUBTOC Certificate... Writing APE ALG Certificate... APE Algorithm Ready! Adding FUR Client (APE, State: Ready)... FUR Control Message Problem -> FUR Control Message Checksum Error Failed to add FUR Client -> Failed to add APE FUR Client, Response Problem Prepare phone failed with message -> Failed to Initialize FUR Protocol Failed to Read All Certificates -> Failed to Boot / Prepare Phone Create RPL from phone RPL Creation started... Processing CMT Part... Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only Booting CMT... APE_SYSTEM_ASIC_ID: 24200705 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 069FB6CD7D1EEBC0B9359B8E63CBE61870D154D4 APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 08600116177000526F70F4B7D4AAD0896670888B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR Searching for BootCode: DualLine 32Bit FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4 Searching for BootCode: DualLine 32Bit OMAP2420_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.14.0, Algo: BB5 Adding FUR Client (APE, State: Start)... APE FUR Ready! If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,APE]: 0x00EC004000000000, Samsung, ONENAND Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported OMAP2420_XSR15_alg.fg, Type: Algorithm, Rev: 512.11.14.0, Algo: OMAP2420 UNISTORE-II-1.5.1 ALG Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE PASUBTOC Certificate... Writing APE ALG Certificate... APE Algorithm Ready! Adding FUR Client (APE, State: Ready)... Failed to add FUR Client -> No answer from CBUS Prepare phone failed with message -> Failed to Initialize FUR Protocol Failed to Create RPL from phone -> Failed to Boot / Prepare Phone Unlock NCK calculation new method: BB5 Unlock Started... BB5 Unlock Failed -> Phone not detected (FBUS) Unlock NCK calculation old method: BB5 Unlock Started... MCU Version V 06wk41v59 MCU Date 22-05-08 Product RM-320 (Nokia N95 8GB) Manufacturer (c) Nokia IMEI 356842021475152 Mastercode 3066554113 Warning: Failed to read SP Info, Assuming defaults Simlock Server Simlock Key Simlock Profile Simlock Key Cnt 0 Simlock FBUS Cnt 0 Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical BB5 Unlock Failed -> Failed to read Security Block PM308 Recalculation: BB5 Unlock Started... MCU Version V 06wk41v59 MCU Date 22-05-08 Product RM-320 (Nokia N95 8GB) Manufacturer (c) Nokia IMEI 356842021475152 Mastercode 3066554113 Simlock Server SIMLOCK SERVER Simlock Key 2600200000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26002F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 26002F Reading Security Block... Read Security Block Problem -> Failed to read PM 308, this is critical BB5 Unlock Failed -> Failed to read Security Block Please what can i do????. Thanks for all |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2009
Member: 1064967 Status: Offline Thanks: 56
| You Cant Dessasembly the Phone.... Quit the Flex and only logic board realize the Unlock. Other Tips is.... 1).- Check Phone 2).- Dont wait and Direct Unlock NCK (New Method). B.R. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
